Small(ish?) Theater Build
post #1 of 12
Greetings all,
We're taking ownership of our new construction in Ashburn, VA in a little less than two weeks. I'm very much looking forward to building a home theater in it. It has a dedicated "media room" in the finished basement that is 19'5" x 11'11" with ~ 8' 5" ceilings. So, its not terribly large in comparison to some of the monster dedicated theaters I see in this forum.
I'm trying to get some inspiration as to what I can accomplish in this space. In retrospect, I probably should have not had the builder finish the space, and then frame it myself, but its already drywalled and wired. I had them prewire in 7.1 with a projector electrical outlet in ceiling. I ended up coming in one night pre-drywall and pulled HDMI/Cat6 in the ceiling (because the LV contractor they force you to go through was absolutely ridiculous about the prices they were trying to charge for pulling HDMI in wall pre-drywall). It is hiding in the ceiling near the electrical outlet.
I plan on the screen being on the right side of the above floorplan and seating on the left. The space on the far right of the floorplan (behind where the screen is going to go) is unfinished storage with HVAC. This is where my rack is going to go for the whole house (networking, servers, A/V gear, HA gear, etc).
What I'm wondering is, has anyone on this forum done a theater in a room this size (links)? I won't be able to put up any sort of major soundproofing since the walls are already up (or am I incorrect in this?) I'd love to do two rows of 3 seats, with a riser in the back of the room. Even a small stage might be nice, but I'm afraid the doors are somewhat in the way for this.
I've already started a dialogue with BIG (since he lives about 15 minutes from me) and plan on utilizing his expertise for this project as well. He's definitely done some amazing builds.
Anyway, looking forward to some comments here and maybe browsing some other similar-sized build threads (I could only find ones that were quite a bit larger than mine. Hmm, that didn't sound right.)
post #2 of 12
How many seats/rows are you planning?
My room is about 12'3 wide and I put in one row of four (1 set of two and 2 individuals) and it is TIGHT. And I have some of the narrower seats, too. I'm thinking that I will have to do some surgery to turn into a row of 4.
My guess is that Big will have some thoughts about putting a stage at the end with the entrance doors.
Good luck. As you know, there are PLENTY of us NOVA guys around. Let me know if you want to drop by some day.
post #3 of 12
I have a similar sized room, but I did an open plan. An idea for the stage is to have a step up/landing outside the theater. I've seen some nice examples. My theater will be about 11' 6" wide when done and it will be tight with a row of 3 ginormous Berkline recliners.
post #4 of 12
Welcome to the NoVA/MD club! wink.gif
My old HT (being a townhouse) was 12' x 15', about the same wide as yours. And my current HT is 15' x 20', about the same length as yours too. So you might have some idea as to how wide & long you could fit whatever you want inside the room. I would say your plan of 2 row of 3 seats is totally doable. The only thing I see is the door where you access the sump area, you just need to make sure you'll have room to open that door at the back. And of course you are already in good hands with Big. (hmmm.... I think may be Big had mentioned something about your HT to me before too.....)
post #5 of 12
I think two rows of three if they are narrow recliners or a row of two and a row in the back of four would work as well. You could also offset the recliners like this: http://www.avsforum.com/t/1411672/chasen-the-dream-theater to do a row of three up front and a row of 4 in the back.
I'd loose the double doors for sound proofing purposes.
post #6 of 12
Yes, many NOVA AVSers out here. All the best with your build. Getting input from BIG is a step towards a great theater smile.gif
I am also in Ashburn and will be starting my own build by end of this month.
post #7 of 12
Your space isn't that much smaller than my recently completed project (~6" less for each dimension), so check out my build thread for some ideas:
Chasen the Dream Theater
To fit more seats in a narrow space, look for seats with a narrow armrest and note that every "loveseat" saves you the ~5" of the armrest.
post #8 of 12
This looks amazing! It definitely gives me confidence that I can build a good looking theater in my small space. It will just take the vision of someone who has done it before (cough cough BIG).
It sounds like he's going to come by in a few weeks after I take delivery of the house to give a consultation and look at the space.
Thanks again for all the links.. if you have any other thoughts please feel free to post them up here!
I'll likely use this space for the build as well once the ideas get flowing!
post #9 of 12
So, we took ownership last month and I have just now settled down enough to start thinking about the HT.
Jeff swung by today to take a look at the space and give some analysis (pretty nice that he lives 20 minutes away from here) and I think I have a game plan.
Since the room is already finished, I'm not quite sure I want to tear it all down and completely soundproof the room. I have some home work to do (need to hook up an AVR in there and a sub and blast it and see just how bad the sound transfer is upstairs and outside. If its too much, then I need to consider gutting and rebuilding the room with proper soundproofing techniques (adding several thousand dollars of expense and time to the project) Unfortunately with this way I will have to redo some HVAC too since there are two supplies and no returns in the space, as well as pull double doors out of the room and put a single sealed door in.
Hopefully, the sound transfer upstairs won't be too terrible (normal viewing in the theater hopefully will not cause too much annoyance upstairs, but we'll see). This way I won't have to worry about completely soundproofing the room and doing all the work above. If that's the case then I can get cracking right now.
The plan is to put some soffits around the room to put some lighting in, as well as use rope lighting around the edge of the soffit to light the ceiling (some moulding will cover up the rope lighting).
Since the other side of the wall that will have the screen on it is my unfinished storage area, I'm going to rip down the drywall on that wall, leave it framed up, and then frame a new wall about 2 feet further back into the unfinished storage area that will become the "real wall". The framing for the old wall will just be used to hang the screen and then hang panels on it to create a false wall. This way I can build my speakers into that small area behind the screen and I'm not limited to using in-wall speakers/subs.
I need to sketchup the space and some of my ideas and post them up, but Jeff's visit was very helpful to consider some other ideas I hadn't thought about before.
Definitely looking forward to stealing some of his time in the next month or so to start on this project!
I'll post photos of where I'm at now and during the entire project as well.
post #10 of 12
I should change the title to "The 'Why Am I Destroying A Perfectly Good Room' Build"...
...I've decided to go all-in with this. I set up a (admittedly crappy) subwoofer and a couple of tower speakers and turned it to where I think I would be watching movies at, and it was ridiculously loud even two floors up.
In retrospect, I should have left this part of the house unfinished and done it myself -- but I was not even thinking about sound proofing at that point. I was just going to hang a projector and a screen and call it a day... until I found this sub forum here. (argh!)
So, I'm going to soundproof the room (clips + channel + dd/gg). I plan on starting demo this evening after work. I'll attach photos of my progress.
I've lined out the general plan above but right now its going to consist of:
- pull up carpet/liner
- pull off/salvage as much trim as I can (might be able to reuse some of it)
- remove doors and cover up so as not to spread drywall dust everywhere
- pull down drywall (all four walls and ceiling)
At that point, I can see what I'm dealing with. I know I have 2 HVAC supplies in the room (one in the front, one near the middle/rear), so I'm going to have to figure out how to get a return into the room (likely a soffit since I plan on building them around the room anyway for lighting). I know the builder used rigid ducting for supplies, so I'll probably try to get rid of that and move the supplies to the front of the room and get a return near the rear. Does this sound right? Would 1 return be enough for 2 supplies? Or do you think this is something I should hire a HVAC guy to come do?
Anyway, here are some before pics of the sound leaking room.
Any comments before I begin? :-)
post #11 of 12
Looks like a fun project. Shame you are ripping up all the work, but it will be worth it. I would:
1) remove all outlet plates
2) remove the door(s)
3) remove all the trim- cut the top if it's caulked with a utility knife and then carefully pry it off. Be bought a special trim puller from Lowes.
And then start taking down the walls. Probably have to unscrew all the screws from the studs. You might be able to salvage a lot of the electrical and lighting in there, if you want.. That stuff can add some cost.
Question: Are you planning on framing in a solid-core 32" door where your large door is now?
Edited by djkest - 5/8/13 at 10:12am
post #12 of 12
Yep. I plan on framing in a solid core door and sealing it.
I also plan on replacing the hollow core door to the sump room with a solid core and sealing that as well.
Since the riser/seating will be by that back sump door, I'm going to lift it to riser height and have it open into the sump room, so it doesn't interfere with seating. I believe it will just barely fit that way.
The general plan is to create soffits to carry 8" flex to the back of the room for a return. The joists run left to right in these photos (north to south in the floor plan). Hopefully I can figure out a way to get both the return and cans in there for accent lighting without eating up too much space.
I'm going to try to salvage as much as possible.
I still have yet to start demo. I keep trying to talk myself out of soundproofing and just build the theater in this space since so much is already done...
