So, I had a free license for Windows 8 Pro from MS Dreamspark due to my degree program and I needed to learn it anyway. I figured it would work well with my HTPC since I don't really need a desktop there. I had read there were performance increases, but I wasn't expecting this.
I can't do ultrafast in my BIOS because I'm running a discrete graphics card, but I'm not sure how much faster it would get. My max boot time from cold into the metro UI is 15 seconds although it's usually less than 10. I've timed it as low as 3 before.
Once inside the OS, there' very little ram usage. I'm staring at the screen right now and it's using 665 MB of ram, granted with nothing running but Win 7 was over double that. Everything is super smooth as well.
As an added bonus, it finally fixed the hand shake issues as I had with my ATI card. Whenever I would turn off the TV, I would lose sound to my receiver. Some driver versions wouldn't work and the ones that did required me to create a dummy VGA monitor, but that caused horrible resizing problems when I turned the TV back on. I reinstalled Win 7 a couple times because of it and tried several different drivers. Win 8 has worked first try and no dummy monitors.
There are things not to like about it, but I'd say give it a shot on an HTPC and see what you think.
