AVS › AVS Forum › Video Components › Home Theater Computers › Hdhomerun question
Hdhomerun question
post #1 of 20
I have 4 hdtv in my house was wondering how many tuners do i need been looking into doing this but still a newbie at it this is just going be for watching tv no need to use dvr really.
post #2 of 20
Well that depends on your viewing habits. Are all 4 TVs ever in use? If so, you may want to wait until the new 4-tuner HDHomeRun announced in January comes out (sometime this summer, no exact date yet). Or you'll need to get 2 3-tuner boxes and will need to use Tuner Salad (Windows 7 only, though there are some work arounds for Win 8 I've seen) to increase the 4-tuner limit in Windows Media Center.
The other think to keep in mind is you'll need a box at each TV, whether it's a HTPC (Zotac, Intel NUC, or actual computer) or an extender (Xbox 360) to access the Homerun.
Hope that helps!
post #3 of 20
You also need to say whether you are watching from OTA (antenna), cable requiring cable card, QAM, etc.
For me I have a three tuner CableCard version, and a dual antenna version.
But like Gewbert says, depends on your habits.
post #4 of 20
guess i be waiting for 4 tunner version then and there all 4 in use most of the time.
post #5 of 20
You could also look into the Ceton infiniTV which has 4 tuners. The only catch is I think you have to assign the tuners to a TV/box and that only works in Win. 7 (I don't have so I'm not 100% familiar on the process).
post #6 of 20
4 OTA channels, 4 cable channels... ? You may need two solutions.
post #7 of 20
For live OTA you don't need anything. All your TVs can do that right now.
post #8 of 20
post #9 of 20
Don't forget if you're implementing a DVR solution you'd need a tuner for each active recording.
post #10 of 20
We have 6 TV's and 4 CableCard tuners (Ceton InfiniTV4) and 4 ClearQAM (2x HomeRun duals) for grand total of 8 tuners. We have had 2 or 3 instances when all tuners were in use.... I am really looking forward to InifniTV 6 with 6 CableCard tuners.
post #11 of 20
I have to ask why bother with an HD HomeRun at all if you only want live tv? Am I missing something?
post #12 of 20
How many extenders can be hooked up with a single PC?
post #13 of 20
I don't think there is a practical limit. But Microsoft only supports a max of 5 simultaneous sessions. You'll need a hefty amount of RAM for that, 8GB at least. But I have to say this is one of the most Rube Golberg solutions I've seen in this forum in a long time.
post #14 of 20
Good point. It does say no DVR doesn't it. But if you want to pause LiveTV then you sort of need one. My question is, after being exposed to a PVR would anyone go back to not using one?
post #15 of 20
As soon as you pause live TV, then you're using the DVR. I don't know why anyone would have a DVR and not use it, or how anyone could use a DVR and ever go back to life without one, as you said.
ryu4000, why do you think you need a Homerun for live tv? Why do you not want to use a DVR? Are you going to use extenders, and if so, what do you have in mind? How are you going to get the signal from the PC to all your tv's (wired ethernet, Moca, powerline ethernet)? Is your HTPC going to serve purposes other than just live TV?
post #16 of 20
Unless some of the TVs are actually computer monitors or you want to be able to record shows.
post #17 of 20
The OP said he has four HDTV's and doesn't want a DVR.
post #18 of 20
Yea it be cabletv and just don't care too much for recording shows really i buy mostly blu-ray and rip them to current htpc.The reason i choose the hdhome run is cause it allows me to not have to worry with pcie slot cause one of the extenders doesn't have pcie to begin with it's one of the zotac zbox.all 4 hdtv with there extenders will all be wired ethernet to a hub or switch.
post #19 of 20
PCs can't be Media Center extenders. If you use all extender setup, they can even share tuners if they are watching the same channel.
post #20 of 20
With an HDHR you can get the same thing for OTA but cannot share the same "DVR" which apparently isn't a concern of the OP as the use of a DVR isn't a requirement.
