AVS › AVS Forum › HDTV › HDTV Technical › Help me with this HDCP issue :(
post #1 of 3
First of all hello everyone
I dont know where to ask this question !
I will try to make it short
I bought Panasonic TH-L32U20R
Tried many gpus from Nvidia and ati using hdmi-hdmi or dvi-hdmi (not nvidia 600 series)
then borrowed Gigabyte GTX 670 from friend ( he had same tv and he told me he get HDCP not supported Issue or nvidia panel)
I installed it on my pc and got HDCP supported in Nvidia panel, after one day I bought 6790 and gave 670 to friend (He sold it that they)
on 6790 I couldnt get display , swapped hdmi-hdmi to dvi-hdmi same issue, then i changed port on my tv and got display
Next day took it to panasonic center and they replaced it with another one
Started using GPU-s from amd and nvidia and then bought GTX 660 (non ti, Club3d)
NO HDCP, and at 2nd day night while playing game suddenly Display gone :'(
tried another port got display turned of pc
next morning started pc got display
then I tried DVI to VGA connection and no display, then again tried HDMi-Hdmi connection and no display
I returned gpu to shop and LCD to panasonic
after one month they gave me replacement
and I sold that and got Brand new UA40EH5000 samsung
it has only two hdmi no dvi or analog, but HDMi 1 is HDMI/DVI
I started using onboard HDMi (dh55hc) and cyberlink bd advisor showed hdcp enabled
today I bought 5770 used and its not giving HDCP (on cyberlink bd advisor, as catalyst doesnt give info on hdcp)
I unplugged gpu and now using HDMi on board, atleast it didnt got any problem
and now getting HDCP on cyberlink advisor
One thing, Whether it stated hdcp or not, I always got audio with video like some people had issue with
also I can play blurays (iso downloadeD) on cyberlink power dvd as well as other softwares as some people get hdcp error on powerdvd12
post #2 of 3
Since you're concern involves a computer, you might try this in the Home Theater Computers section.
post #3 of 3
OK thanks
Posting there
  Back to Forum: HDTV Technical
