AVS › AVS Forum › Video Components › Home Theater Computers › HTPC vs PS3 video playback quality
post #1 of 20
Hi all, I hope I'm posting this in the right section.
I own both a ps3 and a HTPC. I use Xbmc for video playback on the htpc.
If playing the same HD video file, same format, same everything on both devices, would one give me better quality than the other? Some people say ps3 is better for video playback(ignoring Blu-rays) and some people say HTPC. Was wondering if there is a definitive answer?
post #2 of 20
They should look exactly the same, playing the same file. If one looks better than the other, something is configured wrong on one of the devices.
Streaming Netflix, hands down the PS3 is far better than HTPC.
post #3 of 20
post #4 of 20
My HTPC is better than my PS3 on blu-ray and DVD playback. I am using an I5 processor and Radeon 7770 GPU and playing movies with MPC-HC using madVR with jinc 3+ AR and smooth motion and LAV.
The older model PS3 I have is better with Netflix, but I no longer use streaming, so, I can say it was better a year ago with different components in the HTPC.
In my experience a HTPC and a PS3 always produce visibly different results.
post #5 of 20
Yeah. My PC has i5 as well but a nvidea gtx 680 4GB gfx card. Guess that's similar to what you have.
I'm also going through an onkyo av reciever. You don't by chance know if this will effect gaming graphics at all? Probably the wrong forum to be asking in.
post #6 of 20
Your computer may be overscanning the picture, thus the ps3 looks better since you are getting the whole resolution. Or vice versa.
post #7 of 20
On Xbmc you can adjust the scan and its set to overscan off so hopefully should be ok. Not sure about gaming.
post #8 of 20
From my own experience the ps3 beats my htpc in picture quality.
My htpc is basic.. Asus itx board.. I3 2100, 8gb ram, 50gb ssd. I use mediabrowser to play my media. I use the Lav splitters following assassins guide. All my intel drivers are up to date.
I have couple mkv x264 TV shows I acquired from the web.. One in particular on my htpc shows really bad banding in dark scenes... Skin in dark scenes kinda looks Fluorescent in moon light.... Same file streamed to my ps3 using ps3 media sever shows a lot less banding and skin looks a lot more natural in dark scenes.
Now full 1080p mkvs look great on my htpc so I'm assuming the ps3 just does a better job with lesser quality 720p TV show encodes.
My tv is a panny vt25 and was isf calibrated by lions av. All my devices are fed through my pioneer amp with hdmi so it can't be a problem with one of the TVs inputs not being calibrated properly.
Just my two cents
post #9 of 20
My main HTPC is a very nice setup. But honestly if there is any difference in playback, it is minimal. I'm on a Panny 60VT50, so any differences should be very obvious.
There's a big convenience difference though. I by far prefer to view ripped movies through WMC/Media Browser over the PS3. But again this is a convenience thing, not a quality thing.
post #10 of 20
Do you have any problems with screen burn on the plasma?
post #11 of 20
No burn-in, no IR (image retention). Been great. No regrets after almost a year with the set.
post #12 of 20
I used my 2008 panny plasma for almost 5 years as my main PC monitor and haven't had a single problem with burn in. I'm also a huge console gamer, but I did make sure to have screensavers and turn on pixel orbiting.
post #13 of 20
It is strange. I have a 2011 GT30 and that had IR...a lot more so than my 09' GT15 (I believe)....And my newest 65ST50 has zero.
Almost like every year is hit or miss. And maybe per model/size.
post #14 of 20
If you have a CPU, RAM and GPU which can play a DVD or DVD iso using MPC-HC with the madVR renderer using jinc 3 +AR upscaling and smooth motion, (if your display is 60Hz) it will produce a better image than a PS3. Anyway it clearly produces the best sd I have ever seen. I also like blu ray better on my computer.
Additionally, I am using a 2008, 58" panny plasma with no burn in. I thought the plasma burn in discussion had been dropped a long time ago. If burn in exists on plasma TV's one would need to leave a static high contrast image on the display for an extremely long time.
post #15 of 20
I have all this set up. Though not too sure on the smooth motion...Didn't bother to try and play with that. Is there certain settings? I had tried SVP and didn't really care for it, but I guess the smooth motion is a bit different.
Also I have used madvr for a long time now, but when applying the above settings I noticed another leap in picture improvement.
Madvr is fantastic.
And on the plasma, yea it is odd. Most years that I have seen through friends/family are great...except for the 2011 model I have. Also I remember in the GT30 thread a few others had mentioned the IR.
post #16 of 20
SVP is something else and I did not like the results.
madVR version 0..86 has smooth motion: http://forum.doom9.org/showthread.php?p=1616520#post1616520
Once you have this version of madVR please post and I or someone else will suggest the settings. Smooth motion will need to be enabled. You will be asked and indicate OK.
post #17 of 20
SVP is frame interpolation... it is the same technology used in modern flat panels. It estimates motion between real frames and creates new frames which makes it look like the framerate has been increased. Most people don't like this effect. It works ok with sports, animations or documentaries, but not film (IMO).
FRC (frame rate conversion) is basically only for those who have 60Hz displays. Since film is 24p, it needs to be converted to play on a 60Hz display because 24 is not a multiple of 60. The conversion process causes judder that is most noticeable when the camera pans across a scene. FRC removes this judder and essentially makes it look like how a film will look on a display that supports 24p.
BTW, the link above is for v0.86... v0.86.1 is the latest version. The latest version will always be in the first post of that thread at doom9.
For the best results, enable FRC in the smooth motion section, and uncheck 'don't use linear light for smooth motion frame blending' (if your GPU can handle it).
post #18 of 20
I do have that version already.
Maybe I was asked during the install and didn't notice.
post #19 of 20
Thanks, I agree with frame interpolation...never really liked it on LED/LCD tv's with 120hz. Mixed feelings with my plasma and SVP enabled.
So anyways, now that I understand that FRC is under the smooth motion section of madvr's settings....I tried enabling and something bad happened (I forget exactly I'll have to try it again later today).
Do I want it enabled and select "only of there would be motion judder without it..."?
I may have selected enable smooth motion AND enabled the don't use linear light thing at the same time...
Edit: Actually I remember the issue I had, with smooth motion and the linear light thing checked I had some bad skipping video. Perhaps I need to tweak the settings. I have an i5 760 and a Nvidia GTX 460.
post #20 of 20
I am not sure about your GPU for jinc 3. Last month Renethx wrote:
Madshi may add more GPU intensive, good algorithms in future, but for now HD 7770 is a nice inexpensive choice for all kinds of sources with Jinc3+AR / Jinc3+AR in a HD / full HD display, except for downscaling 4K UHD 60fps under Catmull-Rom+AR+LL (4K UHD 60fps is extremely rare anyway). GTX 650 Ti is another good choice (although I prefer AMD).
Edited by renethx - 2/3/13 at 1:08am
See if you can get Madshi or Renethx to advise you on whether you GPU is adequate. I think Renethx has posted a list of recommended GPUs but I can not find the list now.
Edited by Postmoderndesign - 3/15/13 at 6:45am
