So do Hz ratings really make any difference..
From what I have read, the hz rating is very important when watching sport. The problem today is that TV manufaturers are quoting "real motion" or some made up name they have rather than true native hz rates. From what I have been told, this is more important as you increase the size of your TV.
I looked at the Sharp 640u in BB and it was absolutely horrible when they had a football game on., the ball was pixelated and all in all a very bad picture.
The 240hz Sharp 847 that I saw in another store looked much better and a 600hz top pf the range Panasonic plasma looked even better in terms of the puck, soccer ball or american football not pixelating.
If I remember back a few years I'm sure I read that this was all BS. The Sky TV feed at the time didn't go above 100hz so in theory it shouldn't make any difference as long as you bought a 100hz or higher TV.
Scouring the web it seems, neither BluRay or DirectTV go above 120hz so technically this shouldn't make any difference?
I'm wondering if its just psychological, the sources used at the shops or if there really is a good reason to consider the hz rating.
Anyway apprechiate your thoughts and experience..
