Hi grhopper ,
Thank you for your help
What I am asking as far as the stand , is basically how much room or space is under the bottom of the tv when it is sitting on your { a } stand.
I just want to know is there would be enough room for my WD 750 router , for example the router that I have is about 1.5" high and if it would fit under the middle of the stand them that would be perfect. Sorry I did not explain myself better.
If the back is plastic , then that will be very good for the tv ( any size ) , I was trying out the LG 8600 series last year and the back was metal and after about 3 hours of being turned on it would fall out of calibration , then I touched the back and noticed it was very hot.
Needless to say the LG was returned. I have a 6 year old XBR2 40" and the back is plastic and I can have it on all day and the back barely gets warm , the plastic will dissipate heat where as metal might retain it.
Of course there are many factors involved such as adequate ventilation and the types of cooling fans used in the tv itself.
Anyway I do thank you again for answering # 2 , you know very time they add features , sometimes they take away , I am glad you know that the "On Timer" and "Sleep" timer are still there. It is also worth noting that Samsung was right in going back to 4 HDMI , 3 was not enough.
So , thanks again , post when you can
Take care
Gary  
