Salerno Subwoofer: SI HT18D4 11Hz LLT... times two!
Building has begun!
I am building two subwoofers, each of the following design:
Driver: Stereo Integrity HT18D4
Box Volume: 22.06 Cubic Feet / 625L (24Cu Ft raw volume minus 1.94Cu Ft for bracing, port, and driver)
Port: 6.25" x 24" w/ 1.5" flare on both ends
Resulting tune: 10.9Hz
Material: 3/4" MDF
Power: Behringer iNuke3000DSP (possibly two)
Estimated weight: approx. 300lbs... EACH!
These subwoofers are named after Forward Operating Base Salerno where I was deployed when I initially designed these beasts. I name them after FOB Salerno because at this location, infrasonic bass was not uncommon, be it from one of our helicopters unloading missiles into the nearby mountain, the howitzer being fired, or the occasional rocket attack courtesey of the Haqqani Network. Initially, these were going to be two sonotube subwoofers. However, I've encountered difficulties in sourcing the sonotube in Germany, and even the German home theater forums have people who either can't get it, or have to pay a lot to get it. And so, the design changed to a box design.
These subwoofers are being designed and built for home theater use, although I expect they will also help music to sound a bit fuller also. The design goal is to achieve flat frequency response to 10Hz at reference levels, although I hope room gain will get me below 10Hz. At the very least, I hope to have meaningful output into high single digits.
The rest of my speakers are Klipsch RF-7 IIs, RC-64 II as LCR, RS-62s for side surrounds, and RB-81s for back surrounds. And so to start, I'll probably cross over my speakers at 40Hz for the mains, and 60Hz for the center and surrounds as a starting point. And so these subs won't be expected to output much above 60Hz.
Due to budget and build area restraints, the subs are being built one at a time. I hope to have the first one operational by 15 Mar, and the second one by 15 April.
Edited by DanLW - 3/14/13 at 2:54pm
Building has begun!
Material: 3/4" MDF
