AVS › AVS Forum › Video Components › Home Theater Computers › AssassinHTPC Passive Thin ITX Custom Build
post #1 of 14
Completed a passive custom build this week that I wanted to share.
The case is able to mount on the back of a flatscreen using VESA mounts, and is made of solid crafted aluminum. The inside of the case has a heatsink that's mounted to the internal edge, and screws directly into the motherboard.
Here is the full list of components:
Case: Akasa Fanless Chasis
Processor: Intel i3 3220T
Motherboard: Intel DQ77KB
256GB SSD
8GB DDR 3 1600 RAM
Windows 7 Home Premium
Assassin Ultimate Setup + Purchased Power DVD
post #2 of 14
Very nice. How loud is it?? I mean, what temps do you get??
post #3 of 14
Pretty sweet! What was the total cost to build?
post #4 of 14
Very cool. I keep thinking about building a fanless (passive) HTPC for the bedroom. I am also interested in the cost of this.
post #5 of 14
This is exactly what I would want for the bedroom.
Can this playback 1080 movies with no sweat?
Also, as others have asked what was the approx. cost to build this?
post #6 of 14
Nice!
I just picked up a couple of these Euler cases for some DH61AG/i3-2120T/8GB/64GB mSATA I have had sitting on the shelf waiting for the perfect case to come along.
post #7 of 14
It should be perfectly silent -- there are no moving parts. It's always strange turning on a fanless case since there's no audible feedback.
post #8 of 14
I was merely kidding but am interested in the temps..
post #9 of 14
Would there be any storage for this build?? I am guessing that it would be attached to the network and access a Media Server in the house...
post #10 of 14
What are you using to control this? (ir reciever etc...)
post #11 of 14
Temps are around 55 C. Hope to have some screenshots later today for you.
Price is around $750 (cost of the components. Not what we would charge).
post #12 of 14
Interesting case - nice little setup.
post #13 of 14
That is nice! It looks like you might be able to add a couple of USB tuners in those empty holes on the back if you don't use networked tuners.
post #14 of 14
A bit more than I was hoping to see. I will have to keep an eye on the NUC's
