Hey guys,
So I'm building my dedicated theater in one of my bedrooms and well, I have read and read quite a bit on these forums about materials, construction techniques, sound proofing, etc etc but since I'm a total noob to this I am still confused. Another big factor is the materials I can get here in Panama and also the language/translation issues with the people who are doing the work.
I guess what I really want to confirm at this stage is if the material and setup I'm planning on using is optimal (of course with my budget in mind) and works or if I'm doing something that will be a total waste.
I am attaching a photo of the design my brother drew up based on what I told him I wanted. It's basically 2x4 wood for the base/support with 3/4" plywood as a wall. We don't have that pink stuff here in Panama so I was thinking of using the fiberglass boards that come already wrapped with aluminum on top (like this one http://goo.gl/SrvV6 or this one http://goo.gl/NozMb). Then on top of that I was going to put gypsum board for proofing and even maybe cover up to a little above ear level with GOM which I'd have to import. Does this sound right? Or is it not going to work? Overkill?
My walls are brick/concrete walls and I don't have a problem with sound getting out or bothering the floors above or below (I already used to watch movies here when it was a bedroom with the same setup I'm going to use and cracking the volume) but of course I don't mind making that even better. What I'm trying to really achieve I guess is to have good audio quality inside and proof it from outside noise... trying to get the DBs low as possible which I think this setup works for that apart from having new doors installed with the adequate sound proofing and seals.
So yeah, any guidance, opinions, critics, or just saying Im doing this totally wrong is welcome. I've been going back and forth on it and I just cant figure it out on my own due to my lack of knowledge on this and any type of home building DIY
Ignore TV on this one, I've decided to go with a BenQ and AT screen.
