AVS › AVS Forum › Audio › Audio theory, Setup and Chat › Low center Channel
Low center Channel
post #1 of 5
I hope I'm posting this in the right place, if not I apologize in advance.
Let me start by listing my setup:
Pioneer VSX-33 receiver
Klipsch RF-52 II for Left and Right placed about 6 - 7 ft apart
Klipsch RC-52 II for Center placed above the TV pointing downwards toward the listening position
Sonys for Surrounds placed about 3 feet back from the couch
My problem as the thread title states is that when watching many movies my center sounds dull, muddy, low, whatever you want to call it, while the effects are so loud it could bring the house down (IE. Empire Strikes Back). Oddly enough watching other movies (IE. Predator) the problem is not as noticeable. I have run the MCACC about a billion times, it doesn't seem to get better. The other problem I encounter is that if I turn the center channel up it tends to drown out the mains. At this point I don't know what else to do, its seriously starting to give me a headache and I hate to think I spent all of this money to have to fiddle with setting every time I watch a movie.
post #2 of 5
One word: subwoofer.
None of your existing speakers seem to have the bass dynamic range that I would want to have in a high quality audio system.
post #3 of 5
I forgot to mention I do have a subwoofer its a Veodyne VP-1000.
post #4 of 5
The first thing I would do to is to compare the basic sound of the center to the fronts during the MCACC EQ process. If you can easily tell when the center is being scanned I would try to re-position it until it matched the other speakers as much as possible. If your version of MCACC offers the All Channels Adjust try that along with the other two also under System Setup verify your center isn't set to Large and check the crossover level.
post #5 of 5
How does it sound with MCACC turned off? If you shut MCACC off, you'll want to manually calibrate. Do you own an SPL meter? Do you know how to do a "manual" calibration?
Craig
