AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk]
Official Samsung PNxxF8500 Series Discussion Thread [No Street Price Talk] - Page 129
post #3841 of 11459
Originally Posted by arenaman View Post
That is the question isnt it, do you take that chance and roll the dice wink.gif there are sets out there without the band, I tried my hardest to get one to show up with the F8500 I saw in teh store and no matter what I couldnt get pops or bands to show up. Im taking that clip that you posted with me next time and Ill let you know the results......
post #3842 of 11459
Originally Posted by Oplasmic View Post
OK, I've received my second 60F8500 after returning the first for the brightness pops and scratch on the screen filter. This one seems to be much better. My problem is this...I don't have any apps. My first one was loaded with all the basic apps and this one has none...except for the web browser app. I'm online wireless and my auto update is on. Is there a setting on the TV I'm missing because I can't find it. Any help would be appreciated.
I had the exact same issue today with my new 64F8500. If you go into the smart features menu there is an option to reset the smart hub. Once I did this all of my apps appeared. It did take a few minutes for everything to load. If you can't find the reset option let me know and I can give you the exact location. I am not in front of my set right now.
post #3843 of 11459
I had to do a reset on my smart hub. Just go to menu and then to smart features and reset is clear at the bottom.
post #3844 of 11459
Originally Posted by airgas1998 View Post
so are you seeing this band with a still image or do you have to engage it with the proper material? namely like the above you tube dse test.
I see the band with a steel image too. Not only in panning scenes. Mostly in snow scenes plus blue sky scenes. I am reading that others swapped their sets and got band free new tvs. I am concerned about the issue. Dont know what to do...
post #3845 of 11459
Thanks everyone...I figured it out. I kind of went the long way about it though. I did a full reset of the TV and then did the setup again. Apparently I missed the Smart App accept/agree check in the setup menu. Don't know how that happened.rolleyes.gif Thanks again!
post #3846 of 11459
I debated for weeks about whether or not to switch the set. I was so hung up on the various issues I could never enjoy my new TV. It sounds like you are in the same boat. It isn't worth losing sleep over and if you can't have a pleasant viewing experience because of the banding then the only option is to swap it or return it. I have definitely learned there is no perfect TV on the planet. No matter what you get there will always be some minor issue. Banding that is visible is a major issue in my mind. It all comes down to what is acceptable for you because you are the person watching the TV.
post #3847 of 11459
+1
I feel exactly the same. Its crappy to even be put in that situation by a product, but you'll feel better if you do something about it whilst you still can.
post #3848 of 11459
If you are concerned then exchange the set, at least thats what I would do...
post #3849 of 11459
Originally Posted by ljmart View Post
just write down all your settings before the update. you can go in the 10pt white bal and check each interval number to see what red, green, blue values have been changed. since they weren't on your report they may not be anything but zeros, but i kindof doubt it!! that way you can plug all back in as calibrated pre update...
Dont forget to write down the color space - custom settings too.
post #3850 of 11459
There are levels below the user menu that might be changed. There are levels below the service menu that might be changed. Most probably any firmware change will be deep down in the electronics and not obvious in the settings of either the user or service menus. Off hand, I cannot think of any in the past seven years where changes in the user menu were made by a firmware update. However, even if settings are not obviously changed, picture quality can be effected.
Larry
post #3851 of 11459
Originally Posted by barth2k View Post
I'm grateful for all the early adopters who took one for the team, namely, mois.
I know Chad does touch ups for a low cost........ I am not sure about other calibrators out there?
post #3852 of 11459
I know most of those in this thread and the lurkers a like are greatful for the "sacrifices" mae by those who got htings done early. No one, could have known that they would have gotten something out so quickly. Esepcially when you ahve a tour coming though sometimes its worth the risk.....
post #3853 of 11459
can someone with knowledge on the subject tell me in their opinion what tv is better out of the 65hx950 and the samsung 8500. I ask because the sony viewing angle is getting to me, is the 8500 on the level of the sony when viewing the sony from straight on please help for i have a limited time to return the sony and exchange. Also how bright is the sammy and pq compared to the sony and the pros of the sammy to sony
Edited by cdjocp - 4/26/13 at 6:01pm
post #3854 of 11459
Quick question about the F8500's horizontal band issue - is this issue isolated or more prevalent on any particular size?
post #3855 of 11459
it appears to be dominant on the 64" for those who have/had the issue.
post #3856 of 11459
OK, thanks for the info. I'm considering pulling the trigger on a 60".
post #3857 of 11459
I ended up swapping my set today and am happy to announce there is no horizontal banding in the screen. Glad I swapped sets because the banding was a real issue for me. It sounds like this band is a real issue for you too. Swap the set and hopefully you get one that doesn't have the banding. By the way my set had all kinds of issues and that was part of the reason for switching it out. I am a happy camper now!!
post #3858 of 11459
Originally Posted by jackobots View Post
Floridaman, what size is your F8500?
post #3859 of 11459
64
post #3860 of 11459
post #3861 of 11459
Deleted, posted in wrong thread.
Edited by Chad B - 4/26/13 at 9:13pm
post #3862 of 11459
I'm interested in knowing where you purchased your TV, if you don't mind letting that info become public. I ask, as it appears an important part of purchasing this TV is the ability to easily swap it out if needed. What national retail stores are easiest to work with on a TV swap?
post #3863 of 11459
Was in a local BBY earlier this evening and each of their 60" and 64" floor models had the band issue, although the 60" was slightly harder to see. I wonder if it was a bad production run or something, and if so, if its possible for a Sammy tech to fix the TV if it is not possible to find one without the band in your local area.
post #3864 of 11459
I'm getting a swap now, 1 dead pixel and the band, it would just bug me and I'm not paying £3000 to put up with it.
post #3865 of 11459
Please inform us when you get the new set if you have the band. Thanks
post #3866 of 11459
Ok, are you swapping too?
post #3867 of 11459
Originally Posted by surfmlb View Post
I will probably just run the WOW calibration then probably watch nothing static for first 100 hours. After that, then rerun the WOW again unless there are some better suggestions on here from the Pro's.
Any suggestions on which Blurays to watch that show maybe the deepest blacks etc...? cool.gif
Watchmen is a good one as well
not a great movie...but tons of thematic material for testing of blacks and shadow detail
Warren
post #3868 of 11459
Best Buy and I am a Premier Silver Member which gives me a 60 day return period.
post #3869 of 11459
What is a "Premium Silver Member?" Do you have a link to the part of the BB website that describes that or could you let us know more about it?
post #3870 of 11459
I dont know yet. Havent decided to call them. Things are different here in Greece. The technician is coming, makes a report to samsung central and they decide if its a problem and then swap your tv...
