AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › JVC RS46 or EPSON 5020UB?
post #1 of 4
I have it down to these two projectors - like just about everyone else I have been going through all the information possible. Cannot view either one but I am coming from an Epson 1080UB, I can get the 5020 for 550.00 cheaper than the RS46 but since I intend on keeping it for a few years want the best image possible in 2D. Less tweaking on the Epson from what I have read. I have approx. 1500 hours on the 1080UB in the last 5 years - the other definite plus would be lack of dust in the pj, basically which one is better sealed? Thank you for any advice!
Edited by filmbuff2 - 3/15/13 at 12:37pm
Gear mentioned in this thread:
post #2 of 4
The JVC is better sealed and is better build quality. The JVC also has the better picture for 2D, the Epson is better in 3D.
post #3 of 4
Thank you for the push in the right direction - I just ordered the JVC RS46. Now all I have to do is learn to calibrate the thing Any suggestions?
post #4 of 4
The RS-46 does not have a CMS if you care, but you can still calibrate gray-scale and the gamma. If you want to do it to a near-professional level, you will need the Chromapure package and the D3 colorimeter. Though it depends on how much you want to spend, but that is a good start.
Otherwise, start with the AVS rec 709 disk (free download from this forum), just burn it to a regular DVD on your PC and plop it in your bluray player.
