AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Marantz SR7400 display not working
post #1 of 6
Hello
I own a Marantz SR7400 AVR and it has been working great for a long time. But a couple a days ago the display on the front stopped working and is completly blank. I searched around and could not find any answers other than to open it and look for bad fuses. So I opened it but could only find 1 fuse. I took it out, but it both looks ok and measures ok with a voltmeter.
I also tried resetting the unit by holding the select and s.direct buttons for a couple of seconds. The unit does reset, but it doesn't help with the display problem. It seems to work fine otherwise. I can use the OSD and sound is coming out as it should.
Does anyone have any ideas what I can try next other than to send it in for service?
post #2 of 6
may be wrong but i believe u can turn off the display.Maybe it was turned off accidentally. just something to check.
post #3 of 6
Yes, I forgot to mention that I already tried that. That was actually my first thought aswell.
post #4 of 6
So it is still working but no display?
Yours may have a feature common to other Marantz: Pure Direct?
If both of the above are correct, then you or someone playing with the receiver/remote accidentally selected this Pure Direct feature. Then, all video is turned off, except for one LED to indicate Pure Direct is on, while the music is playing smile.gif!
(I tried to watch a DVD with Pure Direct selected: no picture on TV. Marantz really means no video in the OM ^-^)
post #5 of 6
No it's the small display on the front of the unit that is not working. I can see video and the menu just fine.
post #6 of 6
Does anybody know if there is a fuse behind the front panel? As I said earlier I could only locate one fuse, but another one might be hidden somewhere. I just don't want to disassemble the whole thing for nothing.
