hello all!
Apologies for the ignorance I am potentially about to display...
I am currently in the process of building a house and had the main level wired for sound (6 spots for speakers. 4 in the living room and 2 in the kitchen, as well as a sub output) and 4 in the lower level which I will use for a media room.
Initially I am looking to the upper level, primarily for music... I just visited the magnolia store where I auditioned the Sonance VP 85 R as well as the Sonance VP 81R - the 85s had a fuller sound (with a nearly 300.00 per speaker premium attached to it)
I plan on using a maurantz sr5006 initially, maybe long term to power the upstairs set up, which I purchased new for a steal a year ago for 200.00.
7-channel amplifier
100 watts per channel into 8 ohms (20-20,000 Hz) at 0.08% THD, with 2 channels driven
Dolby® TrueHD, DTS-HD™ Master Audio, Dolby® Digital Plus, DTS-HD™ High Resolution Audio, Dolby® Digital EX, DTS-ES™, Pro Logic® IIx, Pro Logic® IIz, SRS Circle Surround II, and DTS Neo:6 decoding
in the demo room they were running a McIntosh amp to power the speakers, big difference between this amp at nearly 4K and I know the McIntosh reputation, and a 200.00 (originally 8-900$) Maurantz...
I tested an equivalent Maurantz with these speakers and there seemed to be an appreciable difference in sound quality.
So, here is the question for your folks whom have worked with this (or have knowledge)
Really looking for the most bang for the buck, obviously best sound reproduction possible with the Maurantz (though maybe it is worth investing in high end speakers and plugging in a different amp later)
I had hoped to spend 250 or less for speakers though if I have to cough up 5-600 to REALLY make a difference I will. I am thinking 3 way, but wondering what your thoughts are on speakers (2vs3 way) brand, etc. would love to be able to FILL THE ROOM with Clean, Crisp, pure sound that ROCKS and yet appreciate music at much lower levels at times...
Also, for the downstairs, no receiver yet, but thoughts on mid and surrounds for the media room in ceiling speakers?
Thoughts? and thank you in advance for any answers... if you need more information let me know.
7-channel amplifier
