AVS › AVS Forum › Audio › Receivers, Amps, and Processors › AVR-1911 White Noise and Standby
post #1 of 4
Over the last few weeks I have had an issue with my receiver which is symptomised as follows.
I get intense white noise from my left mid surround speaker (I have a 7.1 setup) this lasts from a few seconds to several minutes the receiver then goes into standby mode. The receiver can then be re-started with no further issues for some time simply by pressing the On/Off/Standby button.
This is becoming more frequent.
Any suggestions please
post #2 of 4
Try swapping the L/R "side" surround speakers to confirm it's not a speaker issue.
post #3 of 4
Yes, I tried that. The problem stays with the channel not the speaker
post #4 of 4
Check to make sure you don't have any loose speaker stands touching another speaker post. Or if you have in-wall wiring, check the integrity of that wire with an ohm meter. Otherwise, try resetting the microprocessor (p. 80 OM). If still no joy, you're likely out of the 2 year warranty period, so if purchased with a credit card, check with the issuer to see if they will extend the warranty an extra year (AMEX will as will some MC/Visa).
