Guys,
We just moved to a new apartment in California (from Seattle) and are setting things up. Already run into a roadblock with my media server networking.
I have an HTPC (intel sandy-bridge core i5 / 4 Ghz) where I store all my media. HD MKV's, M2TS, DVD ISO's & full BD ISO's, amongst other HD & non-HD content. Content ranges from 10mbps to 40mbps. This is setup in my home theater room.
I also have the dune smart D1 that we keep in the bedroom which streams media content from the media server so we can play all our content in the bedroom.
In Seattle I was using Netgear MoCA adapters to stream content from the media server to the dune smart D1. I have two gigabit NIC cards in the htpc and one was dedicated to streaming out data to the dune smart D1.
In my California apartment, much to my shock & horror, I discovered that there is only one coaxial outlet - in the living room. There is no coaxial outlet in the bedroom. This means MoCA is no longer an option.
I have tried d-link 500 mbps powerline adapters in the past but they don't seem to stream anything above 10 mbps successfully, so they are not an option either.
The way rooms are, I can't successfully run an ethernet cable without it literally running on the floor in our feet.
So basically, I'm looking for a non-MoCa, non-Ethernet networking option that will allow me to stream HD Blu-ray content from my htpc to my dune smart d1 in the bedroom.
The distance is about 26 feet, same level.
I haven't heard of powerline adapters faster then 500 mbps in the market; and I dont know of wifi being able to play stutter-free blu-ray content.
Can anyone (possibly in similar situation who successfully implemented a solution) suggest possible solutions to try?
Thanks!!
Thanks!!
