So I finally decided to try a few bluray iso's and they play great locally. However, over the network they seem to suck, and by suck I mean it is impossible to watch with it constantly stuttering.
I believe this is due my CAT5 in-house wiring. I can stream all of my compressed h264 files but anything above 20gbs has a bit of stutter. These ISO's are unbearable.
Is it possible to fish a cat 6 cable if I Pull it along with my cat5 cables? The router and switch are both located in the basement, and where I plan to stream from is located on the 2nd floor. I have a few rooms where I can experiment and see if I can pull it through, but I'd rather not try that.
The switch is gigabit, so that is ready to go. All NIC's have gigabit ports. But the house was built in 1998, so the cabling is all CAT5, not cat5e, which is my bottleneck (I think).
. Some toolless jacks from monoprice and an hour or so later they were GigE jacks. It took longer on the basement side to unwind everything and get that hooked up to the switch.
