AVS › AVS Forum › Video Components › Home Theater Computers › Is my Motherboard shot?
post #1 of 2
Ok so long story short 2 identical HTPC with the exception of the case. Started having issues with one of them and after running a bunch of diagnostics I pulled the HD to copy over all my media to the other HTPC. After copying the data I could no longer get that HTPC to boot up. I can't even get it to post. I have unplugged the HD's, removed the memory and when I apply power all the fans start, some of the LED's on the MB light up but I get no beeps.
post #2 of 2
Did you try swapping the on-board battery?
