I have a Sony 95ES projector and am trying to set it up with a Harmony 900 remote. My problem is that I cannot get the remote to turn the projector off properly. I've tried going into the remote device settings to set it up for a "double power off", but that doesn't work. So, the only way to get it to work is to change the activity setting to power off when it leaves the activity, which works if I turn it off, but also turns off the projector if I switch activities, which is not the desired result. So I'm trying to figure out if there is a way to turn off the power off confirmation on the Sony unit. If I could do that then all would be ok. Is this possible?
AVS › AVS Forum › Display Devices › Digital Hi-End Projectors - $3,000+ USD MSRP › Sony 95ES and Harmony 900 Remote
