AVS › AVS Forum › Video Components › Home Theater Computers › asrock fma85x itx aftermarket cooler... owner users please
post #1 of 10
Running a10 5700 in a isk300-150 . The stock cooler is overwhelmed. The back of the mono does not work for backplate coolers.
Anybody else with a similar setup?
Edited by hazna - 3/18/13 at 2:08am
post #2 of 10
I mention this often but an a8/a10 in a small case is not a good idea. From my experience you are going to need a large aftermarket cooler which will necessitate a larger case.
post #3 of 10
Try to downclock CPU. CPU is less important in video playback, GPU is everything.
post #4 of 10
The case is behind my tv Vesa mounted.
post #5 of 10
Renethhx,
Is there a guide for under clocking?
Actually the temps are ok around 41 just the noise is bothering...
post #6 of 10
I don't think this is going to work well for you given the amount of heat and lack of airflow generated by the HTPC and HDTV in a cramped space.
post #7 of 10
Renethhx,
Have you clicked the hyperlink in my my post? (There is nothing terribly difficult; just move the slide bar to the left a little bit. smile.gif)
Have you adjusted the fan speed in BIOS > H/W Monitor > CPU Fan Setting? (Select "Automatic mode" and set "Target CPU Temperature to, say, 60 and "Target Fan Speed" to, say, Level 3).
Edited by renethx - 3/18/13 at 8:34am
post #8 of 10
Sorry hyperlink did not show on my phone. Thanks.
The biggest problem I have is mounting an after market cooler. The back of the matherboard has chips where the backplate is supposed to go.
Edited by hazna - 3/18/13 at 11:57am
post #9 of 10
isn't 60c high?
post #10 of 10
Maximum operating temperature of A10-5700 is 71.3°C. So 60°C is pretty safe. (If the temperature reaches 71.3°C, CPU will throttle down automatically to avoid damage anyway.)
