AVS › AVS Forum › Display Devices › Display Calibration › Mascior's Calibration Disc
Mascior's Calibration Disc - Page 4
post #91 of 343
Just to clarify the differences between my APL patterns and others. My 2%, 10%, and coming soon 5% patterns have a background with a constant 22% stimulus level that never changes. My theory behind this is to see how all stimulus levels from 0% through 100% behave surrounded with a constant 22% stimulus level background. This applies to my grayscale, gamma, and color sweeps. The GCD disc for example (excluding there 1% APL patterns) changes there backgrounds to keep a constant 22% APL on the screen regardless of what stimulus is being displayed. This got me thinking and I decided to do a comparison of my 10% APL patterns vs the GCD 10% APL patterns. The results were surprisingly similar considering the fact that background levels between the two vary. What was even more surprising is how close both gamma's tracked. I uploaded some graphs below:
Before: My disc After: GCD
Edited by mascior - 4/13/13 at 10:53am
post #92 of 343
Mascior,at what apl percentage are your 4% and 2% patterns?
Thanks for working on the 5% for us.We greaty appreciate all your hard work and efforts.smile.gif
post #93 of 343
The 2% APL patterns have a constant 22% stimulus level background and the 4% APL patterns average between 18%-25% APL.
post #94 of 343
How do you get 18-25% average stimulus for the the 4% APL patterns? The ones with the blocks around the edges right? The average stimulus of those has got to be pretty low, maybe 2%.
post #95 of 343
Your probably correct. I wasn't sure exactly if I was measuring my 4% APL patterns properly. It's easy to measure my other APL patterns because the nature of the pattern. Any advise? Thanks in advance.
Edited by mascior - 4/13/13 at 1:23pm
post #96 of 343
Actually I think you are close, are the edge blocks 2% area each and the center 4%? If so then the average stimulus range is 19.1% - 23.1% and the average luminance range (gamma=2.2) is 11.7% - 15.7%
post #97 of 343
Yes, 2% blocks around the perimeter representing the entire grayscale in 5% steps with 4% windows in the center.
post #98 of 343
Hi Zoyd
Can i ask what formula you used to reach the above mentioned figures in respect of both luminance and stimulus?
post #99 of 343
Originally Posted by ndaa75 View Post
Hi Zoyd
I forgot the 95% stimulus block so I was a little off, here are the correct numbers.
for stimulus:
edge blocks+1 central block = 21 * 2% = 42% of total area
average stimulus of 21 blocks ranging from 0 to 1 in 5% increments = 0.5
average stimulus = 42% area * 0.5 + 2% (x 0) = 21% (0% 2nd central pattern)
average stimulus = 42% area * 0.5 + 2% (x 1) = 23% (100% 2nd central pattern)
for luminance with gamma = 2.2 you have to take each 5% level and raise to the power 2.2 before taking the averages:
average luminance of 21 blocks ranging from 0 to 1 in 5% increments = 0.322
average luminance = 42% area * 0.322 + 2% (x 0) = 13.5% (0% central pattern)
average luminance = 42% area * 0.322 + 2% (x 1) = 15.5% (100% central pattern)
post #100 of 343
Love your disc MASCIOR. Finally got it downloaded and i have to say it's very slick, with a great design.
Excellent work, especially for us Chromapure users.
post #101 of 343
Thank you! REV_004 should be out soon with more fun patterns to play with.smile.gif
post #102 of 343
Awesome. My only request would be 75/75 patterns in a section by themselves. You can access them easily enough though, and they are the recommended amplitude and saturation for a VT50.
post #103 of 343
Thanks Chief...
post #104 of 343
Another Chromapure user here with a VT50.
I'd like to see them in one area as well with the 18% and 25% APLs and 5% window size.
post #105 of 343
+1
for oppo 103 + panasonic gt50
post #106 of 343
I'm finished with all of REV_004's rendering and will be authoring for the next couple of days. I put my new 75/75 amp/sat pattern sweeps in there proper window size "sections"(2%, 4%, 6.5%, 4%APL, & 5%APL) on new pages. I added an entire 5% APL (22%) suite in the APL size selection. I also added more calibration options for my existing 4% APL patterns. Made a few cosmetic changes and adjusted some menu structures. All in all I think it turned out pretty good and will be ready for download later on this week!smile.gif
Edited by mascior - 4/15/13 at 4:34am
post #107 of 343
Good job mate.
post #108 of 343
I've found that gamma on plasmas varies primarily as a function of average input stimulus (assuming you are well below where ABL drops it) and your 10% APL as well as 4% APL and the GCD 10% are in a relatively stable range so your results are nice confirmation of that.
post #109 of 343
I checked chads 4% vs the 6.5 and 10 on this disc on my vt50. They were all pretty darn close so I am just using the 6.5% windows and not losing and sleep smile.gif
post #110 of 343
Hi Zoyd,
When you raised each 5% level, what was the formula you used? Im struggling to understand this correctly!
post #111 of 343
5% stimulus => 0.05^2.2 = 0.00137 = 0.137% luminance
post #112 of 343
Hmm, I burnt the AVCHD file to a DVD and the PS3 won't read it. It recognizes it as a data disc...
Wow, just did some research, this is not for the novice is it?
Edited by Ryan25 - 4/15/13 at 5:37pm
post #113 of 343
What software did you use to burn my pattern file to disc? It sounds as though you burned a data disc instead of an image file disc. I have tested both my Bluray and AVCHD versions on a PS3 with no issues. Download ImgBurn(a free download), right click on my file that you downloaded, it should give you burning options, select burn a disc using ImgBurn, and this should allow you to properly burn a copy that would be usable on your PS3. Please let me know if you have anymore questions or issues.
Edited by mascior - 4/15/13 at 8:22pm
post #114 of 343
I'll give it a shot in the morning. Thanks for the info!
post #115 of 343
Just to be certain. If I go into say the 6.5% windows, and choose 75% color. Those are all 100% saturation and 75% amplitude, then of course the 100% windows are 100% saturation and 100% amplitude?
I've been using the 75% amp windows, which of course generally accepted for gamut is 75 amp and 100 saturation. Just wanted to make sure i didnt have a brain fart.
post #116 of 343
post #117 of 343
REV_004 is posted! The AVCHD and Bluray versions are both ready for download. Please let me know of any issues. Thanks.smile.gif
post #118 of 343
Awesome thanks. Your 6.5% windows and 75 Amp 100 Sat windows have been very helpful on my VT50. PQ is great!
post #119 of 343
post #120 of 343
Worked out, wish I had some more technical ability to really get the maximum result. I'm pretty impressed at how close THX Bright was, bumped brightness and sharpness a tad and that was that.
