AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Onkyo 875 speaker level problem
post #1 of 2
Hi Guys,
I have a weird problem with my Onkyo 875.
I recently moved to a new home. And my reciever stood still for a couple of days.
I plugged it in, and all the previous settings were there, but wanted to run Audessy because my room changed.
Did the setup, all was well, tweaked it with a SPL meter.
But then...I powered down the reciever down, so not in standby mode, and the next day all my levels were completely off...and the main display gave weird readouts as well.
Normally the levels are shown with 0.5db increments, this time it read in 0.6db or 0.7db increments depending on th channel selected. But on my onscreen display the readout was in 0.5db increments.
So on the receiver display it was +1.7db and onscreen +1.5db
When I put my receiver in standby mode the speaker levels remain the same, but when I power the receiver down and turn it back on then they are changed. All my other settings remain intact, inputs,distances etc.
Hope you guys can help.
Thanks in advance!
post #2 of 2
FYI, I already did a hardware reset on my system, but to no avail.
Is there anybody with advice ?
