I'm looking at building a DIY home theatre in a house I just bought. I would be converting a suite into a basement HT. The suite has one small 2x3' window with blinds adjacent to the screen but my main use would be for watching movies (2D and 3D) and sports (only 2D in Canada) during the evening as I am busy during the day.
Dimensions: the room is 12x19x9'H (living room) and it has 8'10" of wall space for a screen. I'm thinking of a 100" or less screen so I can put speakers to the left and right of it and mount the screen lower for easy viewing from my recliners.
Q: What screen height should I aim for?
With regards to criteria, I would say my priorities are as follows, in order of importance:
1) Black Level
2) Quietness of Operation During 3D, dark scenes. Having a noticeable noise from the pj would ruin it for me.
3) Color Accuracy
4) Sharpness (could this be increased with the Darblet?)
5) Warranty/Availability/Reliability. I can get the Epson 6020 locally for 3300 which is a big deal for warranty. Not sure about the others.
With those criteria in mind, what would you suggest?
Also is there a consensus on good value screens? I would like to keep this project under $4k.
Just watching Cnet, I am probably leaning towards the X35 if I can find it locally.
Nathan
1) Black Level
3) Color Accuracy
Nathan
