AVS › AVS Forum › Audio › 2 Channel Audio › DAC Comparison: Integrated Amplifiers vs PC Sound Cards vs Stand-Alone DAC's
DAC Comparison: Integrated Amplifiers vs PC Sound Cards vs Stand-Alone DAC's - Page 2
post #31 of 51
Originally Posted by trackfan View Post
... What's the opinion of the folks on this board on these three configurations?
1) Integrated Amp w/DAC
2) High-end PC Sound Card
3) Stand-alone DAC
Originally Posted by mcnarus View Post
None of the above. 2 and 3 are likely wastes of money.
1 and 3 are OK; agreed that 2 is a waste.
I agree with Arny that the best choice is an AVR.
post #32 of 51
Trackfan, a pro audio active crossover is used to provide better isolation between the speaker system drivers and better control over them. Biamplified systems use an active crossover to control the drivers in the speaker enclosure, for instance. When you see large arrays of guitar amps and speakers, for instance, at a concert, you can bet that there are active crossovers in the system. They also allow for adjustments to be made to the crossover frequencies. Pro audio systems that use active crossovers do not have passive crossovers in them like virtually all home audio speakers. In order to use one in a home audio environment you would have to disconnect the passive crossover inside the speaker enclosures and connect the drivers directly to the active unit. In general, there is no practical place for active crossovers in home audio.
DSP is another thing entirely. It works in the digital domain. An active crossover works in the analog domain right at the speaker where any crossover works.
Finally, if what you want is a biamplified or triamplified system like those big concert speaker arrrays, then you need to use active crossovers. Biamplifying a speaker system with a passive crosssover is pretty silly since you are applying signal to both sides of the crossover with both amplifiers. Only an audiophile would do that. A pro audio engineer would know better.
post #33 of 51
Rubbish. Guitar and bass speaker systems are almost always simple multiples of the same drivers with nary a xover to be seen at all. Some BG speakers use a tweeter, but very, very few are active.
Rubbish. I have been running active systems at home for years, whether my own design or a modified commercial unit. All of the advantages of using active xovers are just as relevant in a domestic system as they are in PA.
Rubbish. A xover using a DSP is no less active than one that is all analogue. An active xover is simply one that separates frequency bands at line level rather than doing it as speaker level (post power amp). Using a DSP also allows the possibility of FIR filters, phase correction etc which are difficult or impossible to do in the analogue domain.
post #34 of 51
You're wrong on this. Practically any two-way speaker can be bi-amped and have it's built-in passive crossover by-passed with one of these:
All it takes is removing the jumper and some rudimentary carpentry skills.
Right at the speaker? The analog active crossover that I have is in between the preamp and the power amps, not between the power amps and the speakers.
Edited by trackfan - 3/21/13 at 7:21am
post #35 of 51
Originally Posted by arnyk View Post
Products like the MiniDSP and Behringer DQX 2496 or DCX 2496 may provide you with a more flexible, powerful solution.
It seems that there are many MiniDSP products to choose from on their rather confusing website. Would you mind providing a link to the product you would recommend?
I agree with your evaluation of their web site.
I don't have any hands-on experience with the MiniDSP products, and don't want to become a shill for them. ;-)
Any recommendation would be specific to some detailed set of requirements.
post #36 of 51
You don't mention the efficiency of your speakers. If they fairly efficient (say >88dB) you might take a look at this amp:
http://www.nuforce.com/index.php?option=com_k2&view=item&id=306:dda-100&Itemid=370
It is claimed to keep the sound in the digital domain right to the speaker terminals. I've got one and it does sound exceptionally clean with no audible flaws I can hear. I also appreciate the minimalist styling and small size, but these factors don't affect sound quality.
post #37 of 51
What carpentry skills do you think are required?
post #38 of 51
The skill to modify the back of the speakers to accept this terminal by use of a router and/or jigsaw. Granted, this might not be an option for folks who have commercially manufactured speakers that they plan on selling one day, and therefore don't want to make any permanent modifications. However, I'm going to go out on the limb and guess that most of the folks on this site have enough do-it-yourself experience to handle a job like this.
post #39 of 51
Passive biamping, which is what you're describing is possible via the method you describe, but provides no practical or audible benefit over powering the speaker conventionally via a single amplifier channel.
post #40 of 51
You're mistaken, I'm talking about biamping using an active crossover. The pasive crossover inside the speaker would be disconnected from the tweeter and woofer. The signal would travel from the speaker terminal cup directly to the tweeter and woofer via seperate pairs of binding posts. Why do you think I said the jumper would have to be removed? There would be no need to remove it if you're still going through the speaker's crossover. To be more precise in my language, I guess I should have said doing this requires rudimentary carpentry skills and electrical skills.
post #41 of 51
Now that I can see where you are coming from, I will point out what others will no doubt shortly confirm, which is the electronics skills required to convert a well-designed speaker from using a passive crossover to one with equal or better performance using an active crossover are non-trivial.
While you can get fair performance with a simple off-the-shelf active crossover, most modern speaker's crossovers are tuned to compensate for the characteristics of the drivers. Doing this right at the minimum requires having an acoustical measurement setup, which in recent times has become something that is not impossible for the home constructor to obtain, but costs some bucks and takes time and effort to learn how to use,
I've been down this road with some success, but its nothing I'd recommend to someone with only rudimentary electronics skills except as an educational project. To get a speaker that sounds better than it did with a well-designed passive crossover takes more than rudimentary electronics skills going in, but if you do it right you will have more than rudimentary electronics skills coming out! ;-)
post #42 of 51
There's no doubt that the carpentry and electrical modifications are the easy part, while getting the crossover adjusted properly would be the hard part. Doing it right would likely require the instruments you mentioned, but it can be done. FYI, I've never done this to a speaker myself. My only experience with active crossovers is for crossing over my main speakers to a subwoofer while leaving the main's crossover intact.
post #43 of 51
You're mistaken, I'm talking about biamping using an active crossover. [/B].
I did misread what you said. I also agree with Arny that implementing an active conversion in a commercial passive speaker is non trivial.
post #44 of 51
I think if I were ever going to go that route, I would build a speaker that didn't have a crossover in it to begin with. It does make speaker building simpler when all you have to do is slam a tweeter and woofer in a box.
post #45 of 51
If that's all you think there is to designing good speakers, you have a lot to learn.
post #46 of 51
Building a good speaker cabinet defintely requires more than rudimentary carpentry skills, but what's so complicated about it? Please share your great knowledge and wisdom.
post #47 of 51
Cabinet building is relatively straightforward, especially if it's no more than a six sided box. The rest simply reinforces your ignorance of the subject matter.
post #48 of 51
Hi Trackfan,
The complications are in the design. The size and shape of the box has a tremendous effect on the sound, and need to be "tuned" to the performance specifications of the drivers. Then, if you are building a ported speaker, the port length and cross-section need to be compatible with the drivers and box. Then there is internal cross-bracing to eliminate resonances, and optional fill for damping. It goes on and on . . .
It's a fascinating aspect of audio, though. There is free software available that allows you to design a "virtual" speaker, and then will show you the frequency response, SPL output and other qualities. Visit the "DIY Speakers and Subs" forum. Look at the flat-packs and the SEOS kits. You can build some truly great 'pre-designed' speakers for not a lot of money. Or you can learn to design your own. There is also a good discussion on passive-vs-active crossovers.
post #49 of 51
No kidding, there are some great kits to be had.
Both my 2 ch and my 5.2 HT speakers were
built by my hand, but designed by guys that have
been doing it for a long time with commercial
success. These out perform speakers that
cost many times the dollars I have invested.
In my mind the kits offered these days are the
best value for the $ in this hobby.
post #50 of 51
If there is no crossover in the cabinet, there would nothing else to do to the box except install the tweeter, the woofer, the termnals, the acoustic foam/stuffing and a port if it's a vented design.
post #51 of 51
Originally Posted by MarkHotchkiss View Post
Hi Trackfan,
The complications are in the design. The size and shape of the box has a tremendous effect on the sound, and need to be "tuned" to the performance specifications of the drivers. Then, if you are building a ported speaker, the port length and cross-section need to be compatible with the drivers and box. Then there is internal cross-bracing to eliminate resonances, and optional fill for damping. It goes on and on . . ..
I'm familiar with everything you've pointed out. Perhaps, I wrongly assumed that these concepts would be common knowledge for the folks on this message board.
FYI, I'm more knowledgeable on this subject than my number of posts might indicate, but your civility and helpfulness are really appreciated. It's a lot more refreshing when people use message boards like this to share information instead of snipe and hurl sophomoric insults.
