I am wondering if any tech types can weigh in on a situation that recently occurred.
While sitting around the other day an obnoxious noise emanated from one of my theater speakers like a death throe.
It was then silent.
I checked the Cine Nova multi channel amp and the light corresponding to the dead speaker was lit.
I took the dead Klipsch RC-7 speaker to my local repair shop and explained what had transpired.
The cones are fused and no longer move.
The tech there said it sounded as though a burst was sent from the amp and fried the speaker.They put the blame directly on the amp.
I am now wondering if this might occur with the other channels of this amp and remaining functioning speakers.
I have never heard of this and wonder if this type of occurrence does happen on occasion, if so it makes home theater a very costly hobby.
The amp module has finally been repaired and is en route back to my location. I have also had the speaker repaired, luckily parts were still available. I am hopeful that Earth Quake will eventually spring for the repairs to the speaker.
Earth Quake stated maybe a source component caused the failure. I have now had the pre amp tested for anything unusual and have spoken at length with Marantz's tech department about this issue. It is their conclusion that the failure resides solely within the amplifier which in turn caused the speaker to blow. I have also had conversation with the repair depot that fixed the speaker; they have the same opinion as well.
I then contacted the two other source component companies in my system, Blu ray player and my digital HD cable service both state their products could have in no way caused the issue that occurred to the amp and speaker unless they were connected directly to the amp, which they were not.
My dilemma is do I trust this amplifier enough to put it back in to service? I have not used the amp since the failure took place. I am very hesitant to re instate it after I re install the module. Earthquake has been unable to provide any assurances that this fault will not occur again to the amp or speakers connected to it or how to prevent such a failure, or what they are prepared to do in regards to compensation should this occur again.
The service depot made up some inline fuses for me to add to the positive side of each speaker terminal at the power amp outputs. I am bi wiring but they state only the woofers require this type of fused protection.
Will this fuse system stop another occurrence should it occur?
Should the amp factory not be able to have diagnosed the failure and know what the issue was and how to avoid another occurrence going forward?
Would or will another amp manufacturer fare any better?
I was at my local hi fi dealer recently and was explaining to him the issues as I see them.
He states that by inline fusing I will be altering the sound output.
He also had $90.00 fuses that are claimed to not alter the sound.
But using the lower grade wiring and inline fuses will degrade the sound to some degree he states.
There is also no guarantee that fusing would prevent another of these issues should it ever arise, at least not to the amp.
I will probably get the module back next week and have no idea what the next step will be other than putting the amp back together.
It seems there is no way to pin point what caused the issue whether it was a freak occurrence within the amp or something else.
The amp is still on warranty and there is a possibility of a return if it was their product that caused this issue.
Would another amp fail as well
In decades of listening and multiple audio products this has never happened but I do not ever want this type of failure to ever occur again.
Ideas?
It was then silent.
Ideas?
