Hi all,
I'm new to the projection world... just bought my self a benq W7000, now the thing is I need a screen... found a 120'' Granview cyber series with manual pull down with soft close... can anyone tell me if they've used or know if these are good products, seems pretty good made of 4 fiberglass layers to avoid waves over time in it... this to be installed in a 16' wide x 23' long room... projector would be placed around 17' from projection screen. as for mounting the projector I found a universal bracket Anchor mount model # ACM PM12 BK, seems pretty easy to install and seems well made
here's a view of the wall the screen will be placed as you can see the ceilling is not done yet... it will be suspended ceilling to come
let me know anyone who have advice on these
