Sorry, I've been reading all the other posts but I'm getting more and more confused. I'm starting a new house build in a few weeks and am trying to figure out the best way (at a moderate price, not low ball and not nuts, in the middle) to cool my media closet. It will be in the basement, and I designed it to be 4x4, a door on either side. It will have a lot of equipment, probably too much. 3 desktops (HTPC, mine and my wife's which are set up as stations in areas of the house), Xbox as an extender, receiver, router, modem, probably another couple odds and ends.
So my thinking is a vent in the bottom to let air in, and an exhaust in the top to pull out. Questions would be:
1 - Can anyone recommend a fan size\brand the is extremely quiet (since it would be right under the floor of the main room of the house) and a thermostat that isn't going to cause any spikes or anything clicking on and off?
2 - Is there any kind of intakes with filters to keep dust out?
3 - Should I just vent it to a room? It would be vented into the laundry room but I was worried about it getting too hot in there, and maybe throwing off my normal house temps.
4 - Any way to further soundproof the fan?
5 - Any other suggestions so I do it right the first time? Something better than a plain intake vent? Am I looking at this all wrong?
Thanks for any input, it's really appreciated!
