Hello my friends,
i'm having a strange problem with brightness setting using different calibration disks with different BD Players.
My TV is a 64E8000 and I'm calibrating using 2 BD Players, 1 Samsung C7000 and 1 Oppo BDP103.
On Samsung C7000 i set 51 on brightness setting, this setting works fine on DVE and AVS HD disk, no problems. But when i use the Oppo, i set 39 on brightness setting with DVE and 44 with AVS HD.
This Oppo behaviour is normal? The brightness setting not should be equal in the 2 discs? like the BDP C7000.
Thanks and sorry my bad english!!
, but the brightness variance don't should be less (maybe equal) between discs in a same Player?
