I have a Mordaunt-Short MS309W and would like to replace the original driver. The problem is when the sub hits certain frequencies, I hear a clanking sound as if 2 glass bottles are hitting each other.
Does anyone have any recommendations as to what would be a fine replacement?
Specifications for the Mordaunt-Short MS309 Subwoofer:
Enclosure Type: Twin downward facing tuned ports.
Frequency Response: 35Hz to 200Hz
Power Rating: 150 watt Active
Drivers: 1 x 10" (255mm) Long throw aluminium CPC cone woofer
Cross-Over Type: Active - variable between 50 - 150Hz
Cabinet Dimensions: Width 370mm
Height 370mm
Depth 370mm
Weight: 15Kg
Here is the back of the amplifier
I was looking at drivers on this site.
Edited by Jnipz - 3/19/13 at 2:10pm
Height 370mm
Depth 370mm
Weight: 15Kg
