Backstory: I have an Infocus X10 (DLP Projector, circa 2009). Would like to replace it with a newer display unit. Looking into the BenQ W1070. Went to Projectorcentral.com and pulled up both units to compare. Things don't seem to add up. Specifically I was looking at what light output the new BenQ would have. So I set up both calculators to have the same output screen size, same gain, and max zoom (to maximize the light output of each).
The question is, please explain the following:
Infocus X10. 1200 Ansi Lumens, Projecting 100" screen. Image Brightness: 49 FL.
Benq W1070. 2000 Ansi Lumens, Projecting 100" screen. Image Brightness: 40 FL.
Wth?
Links to both calculators:
http://www.projectorcentral.com/InFocus-X10-projection-calculator-pro.htm
http://www.projectorcentral.com/BenQ-W1070-projection-calculator-pro.htm
Am I missing something?
I don't mind if the BenQ is a tick too bright for my room because I'd actually like to add a little ambient light. So, if it's a bit too much, that's ok. Also, I'll be projecting a larger image with the BenQ if I get it, probably 135" or so. So, F-L will drop some. From the numbers they are showing, and prior experience with my current setup, I'd almost be worried about it not being bright enough!
The lenses are very similar aperture ranges, output wattage seems very similar. Either I'm missing something, or the calculator is hosed... I do know that from a screen size standpoint on the X10, it is spot on.
Edited by K-Spaz - 3/19/13 at 4:42pm
Wth?
