post #1 of 1
Hi all,
I'm new to the projection world... just bought my self a benq W7000, now the thing is I need a screen... found a 120'' Granview cyber series with manual pull down with soft close... can anyone tell me if they've used or know if these are good products, seems pretty good made of 4 fiberglass layers to avoid waves over time in it... this to be installed in a 16' wide x 23' long room... projector would be placed around 17' from projection screen. as for mounting the projector I found a universal bracket Anchor mount model # ACM PM12 BK, seems pretty easy to install and seems well made
here's a view of the wall the screen will be placed as you can see the ceilling is not done yet... it will be suspended ceilling to come
