AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater
Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater - Page 15
post #421 of 801
Wow. Looks great and I like the colors.
Why did you paint the walls if you're going to cover them up with panels?
post #422 of 801
A good portion of the walls will be covered with panels, but a lot will also be exposed.
post #423 of 801
Big showed me what the plans are when i was up there it is going to look great
post #424 of 801
Picking out carpet is not as easy as I thought it would be. Style, Pricing, padding, square footage!!!! eek.gif
post #425 of 801
Don't forget it always looks different in actual lighting conditions, check out a sample and bring it home.
post #426 of 801
Couldn't agree more.  Also, if considering a pattern, look for pictures of an open area or entire room online.  Sometimes it will look different when repeated over a very large space vs just staring at a sample.
post #427 of 801
post #428 of 801
Landshark, I will need your assistance soon.
post #429 of 801
So your running a 7.2 system? Did you list an equipment list yet? And your side surrounds are firing at the back row? Shouldn't they be more between the first and second row of seating?
post #430 of 801
there are two side surrounds due to the length of the theater.
post #431 of 801
NYGiantsfan,
I wanted to make sure you saw my PM.  Let me know if you need more info.
post #432 of 801
The columns are 10 3/4 inch deep because the speakers are 9 1/2 deep.
We did not use MDF on the walls just molding.
Fabric panels yet to be installed on top, dark brown surrounded by frames painted the cream color.
Make sure you detail the frame building...NYGF can take double the pictures for the purpose of his own learning too.
post #433 of 801
So is it basically a 9 channel theater or the sides are wired together? I guess with direct firing speakers you would want them pointing at the heads of both rows?
post #434 of 801
does that mean 9.2?
post #435 of 801
Originally Posted by smakovits View Post
does that mean 9.2?
It may be 9 speakers + 2 subs, but it is still 7.2 if they send the same signal to two sets of sides. 9.2/11.2 only use front high or front wide
post #436 of 801
I'd argue it's 7.1, since since each sub gets the same signal as well - but I'm picking nits. For another way to think of it, you get 5.1 or 7.1 at the megaplex - but they may have dozens of loudspeakers.
post #437 of 801
True there. Though certain receivers that have dual sub outs will calibrate and process output to each individual sub, (Crossover, Polarity Gain, Levels) which is where the .2 usually comes from. Audessey directly manipulates this, and does so individually for each subwoofer. Usually when people add additional sides, they just replicate the signal, which means they would have the same volume/delay and are calibrated "Jointly", meaning both sets of sides would play at the same time during a "test tone".
Edited by damelon - 7/10/13 at 6:55am
post #438 of 801
+1
+1
Side note. A stand alone DSP, such as a DCX2496, MiniDSP, etc...can easily manipulate the .1 (LFE) channel into X separate signals for stand alone EQ.
For instance, my MiniDSP 10x10 can manipulate one (1) incoming signal into eight (8) outgoing signals, which will allow the user to tweak to their hearts content... Starts to get complicated when attempting something of that magnitude.
However, if NYGF was to have two subs placed in different locations of his theater and they were at different distances from the LP (say one on his front stage 15' away and one behind him nearfield 2' away), a device such as the MiniDSP could be of assistance (assuming one didn't have an XT32 enabled AVR).
post #439 of 801
XT32 does not eq multiple subs separately, and only sees/processes the dual sub outs as one channel. There is no separate distance control, phase, eq handled...
He would need SubEQHT
post #440 of 801
I was under the impression that all AVR's with XT32 had the SubEQ feature? My apologies if that is not the case.
Regardless of AVR capability, IMO I feel anyone would benefit from a product like the MiniDSP given its overall flexibility.
post #441 of 801
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=MiniDSP
Are you talking about something like that ^ or something else ?
post #442 of 801
MiniDSP is specifically this
www.minidsp.com
There is other equipment that has DSP functionalities built into them like a Behringer DSP1124, Behringer iNuke amps or the Crown XTI series amps (I think.)
post #443 of 801
Originally Posted by NGiovas View Post
NYGiantsfan,
Yes, I did get your PM, been real busy at work so I have not had a chance to get back to you. I did look at the site you recomended.
post #444 of 801
Any updates biggrin.gif ?
post #445 of 801
stay tuned its in the works.
post #446 of 801
post #447 of 801
Big,
How far away are your risers from surrounding walls and do you anchor the riser to the concrete floor in any way?
Schlemstar
post #448 of 801
NYGF23 - Your theater looks great! We were thinking of going with a dark brown/cream color palette for our media room (thread coming someday), and I think yours just sold me on the idea!
post #449 of 801
Thanks Schlemstar. At first we thought it would be too dark and then I said the hell with it and decided to go for it. The trim work really made it popp. I am Hopi g to have everything complete real soon.
post #450 of 801
keep us updated thinking to bring the wifey up and get some pics of the completed projected plus i wanna hear them speakers jeff built ..
