AVS › AVS Forum › Home Entertainment & Theater Builder › Dedicated Theater Design & Construction › Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater
Beam and Pole interruptus NOT - BIGmouthinDC and NYGiantsFan23 launch - The Rawlinsway Theater - Page 16
post #451 of 799
You and the wife are more than welcome to come up anytime. Jeff should be here this coming Tuesday so the thread will commence then.
post #452 of 799
Enough work, time to reflect on the last six days
First up was two loops of clear warm 3/8 inch incandescent rope like up in the cornice molding. it will be a bit until I get a decent picture but if you look close in this picture you can get a preview.
Next I had this big roll of Linacoustic , I don't know what I was thinking when I said sure I'll take the 59 inch wide stuff.
two layers on the front wall.
post #453 of 799
Speaker Columns
I made some frames from two layers of 1/2 inch Sandply. Glued and Stapled . Basically 1x1 frames with overlapped joints and a mid span spreader to resist bowing
Painted the leading edge black, wrapped in fabric and added Velcro. Added insulation to the interior of the columns and a layer of Linacoustic
Edited by BIGmouthinDC - 7/28/13 at 5:51pm
post #454 of 799
Fabric Panels
The design called for panels surrounded by wood frames of a contrasting color, so I elected to build the panels on wall with 1 inch thick furring ripped from 2x4s
So one morning I said "let there be frames" and there were frames glued and stapled (2 inch) to the wall.
Painted the frames black and added linacoustic in key areas, Linacoustic with scrim in other areas. Used large head screws (Powerhead) and press on black covers.
Edited by BIGmouthinDC - 7/28/13 at 5:57pm
post #455 of 799
Saturday was all about the FABRIC
The secret to working with the fabric is to be one with fabric,
If you compliment the fabric constantly telling it how good it will look on the wall it will generally cooperate with the process resisting snags and runs.
I like to start with a straight factory edge on top, staple it all across with the proper tension then roughly position the fabric with tacks to make sure I have it positioned correctly hanging down straight.
Fast forward
Edited by BIGmouthinDC - 7/28/13 at 6:14pm
post #456 of 799
Very nice Big, really like the clean lines and colors give it a very classy look, you know what part i am most looking forward to seeing get hung biggrin.gif
post #457 of 799
are the fabric panels going to have another piece of trim around them to hide the staples ? i think i see a test piece up in place ?
post #458 of 799
Lets talk about the contrasting color frames.
NYGF23 prepainted the rake molding and today I installed it. I used the outside measurement technigue with tape and a scrap of the molding to located the outside corners, then measured, cut and installed.
Edited by BIGmouthinDC - 7/28/13 at 6:31pm
post #459 of 799
well i was always told patients is virtue lol
post #460 of 799
This build just keeps getting better, already one of my favorite looking spaces. NICE!!!
post #461 of 799
I used the tacks across the top edge to get the tension the way I wanted it and then tacked down the sides. It made it much easier working alone to get the weight of the fabric on the frames and was repositional until you get the way you want it, Then it's easy to go along and staple everything. And I used the solfege (the factory end with the band along it on the top) as a straight edge. Then I went back with a razor knife and trimmed it off. SHARP blade is a must!
GREAT work as always, Big!
post #462 of 799
WOW!!!!!
Another amazing local build and Mr. Big being the center of it all.
This is a thing of Beauty - Subscribing to see more and ultimately the finished product which should be shortcoming.
Ohhh BTW - Go GIANTS!
post #463 of 799
That the "selvage"
Sorry, it's my schoolteacher side coming out...
post #464 of 799
Did you use Linacoustic in each of the framed panels above the wainscotting?
1" or 2" ?
I really like how you attached the fabric to the furing strips then trimmed around. It looks great.
Edited by Jeff in Canada - 7/29/13 at 9:34am
post #465 of 799
Nice! Can we get a close up of a corner of one of the fabric frames with molding/trim? Just curious what the reveal looks like.
post #466 of 799
That the "selvage"
That's "solfege." Sorry that's my music teacher training side coming out.
post #467 of 799
Just stumbled on this thread. Looking sharp! Keep it up!
post #468 of 799
Great job guys. I see the end is getting closer and closer! I assume carpet will be next NYGFan?
post #469 of 799
Looks great!
post #470 of 799
Thanks D.
Today we blocked the view of all the work of many who contributed to the wainscotting and built the shell of the third row sit/stand bar. Tomorrow we'll dress it up a bit.
post #471 of 799
PRICAN2000 thanks and yes sir GO GMEN... I think we might have trouble this year on offense, but we will see.
post #472 of 799
Hey Landshark, the carpet is coming this Thursday. I the middle of my order I changed my mind and went with a lighter brown instead of the chocolate brown. I hope it looks good. If not, I am stuck with it and I will learn to love it.
post #473 of 799
post #474 of 799
Wow not sure how that happened but sorry folks
post #475 of 799
The lights will all be on dimmers, I'm sure there will be a setting that makes the carpet look "just right".
post #476 of 799
THAT is a profile pic...Ninja Jeff!
can I get a little commentary on the bar - looks like 2x4's - what is the covering material? doesn't look like drywall? you make it look super easy...
post #477 of 799
Bar: 2x4s, wired for outlet, stuffed with insulation, covered with 3/4 MDF. Mid span brace is 3 layers of MDF glued together.
post #478 of 799
Some great progress! Looks great.
post #479 of 799
Big - what is the height of that rake molding profile you used for the perimeter panels?
post #480 of 799
Great job guys! Keep it up!
