AVS › AVS Forum › Display Devices › Digital Projectors - Under $3,000 USD MSRP › Some Movies Won't Play on my Projector...Why?!
post #1 of 10
I have a Sony VPL-BW5 projector that I have been enjoying for the past few months; however, I have recently discovered that some Bluray movies won't play on the projector (but they do on my TV). Specifically, the movies are Total Recall (1990) and Terminator 2: Skynet Edition. I figured that the Skynet Edition wouldn't play because the the projector - for whatever reason - could not support the start-up features. I tried getting the movie started (get to Scene 1) on my TV and then switch to the projector...
The problem is that this action requires me to turn off the TV in order for the signal to pass over to the projector...but when I turn off the TV, it also turns off my receiver because they are linked...and when the receiver turns off, my PS3 also turns off, because they are linked...so this approach did not work. I have no idea why the Total Recall does not play; I have tried 2 different copies of this disc.
My other equipment consists of:
-Onkyo 709 receiver
-Panasonic ST30
-PS3
Everything is connected via HDMI, and again - it works fine with all of my other movies.
Any help?!
post #2 of 10
Bad batch of Lionsgate discs maybe? http://forum.blu-ray.com/showthread.php?t=152652&page=4 or the auto BD Live option in the ps3 is causing an issue? Settings > Video Settings > BD internet connection > Confirm. I don't think the pj is your problem, but you might want to make sure the ps3 firmware is updated? Strange they seem to work on your tv.
post #3 of 10
You could disable CEC/HDMI control on your devices so you could do your switching experiment.. but that's not really a solution since it will try the HDCP handshake on the new display anyway. A display wouldn;t have anything to do with disc features - that's all the player/firmware and updates. You could turn off bdlive just to see.
For troubleshooting, manually set ps3 hdmi to 720p, bypass the receiver and try it. it could be the longer cable is marginal, the receiver is breaking the chain with processing. Only being those 2 discs, and every time is odd tho.
just isolate each component if possible, then when you find the one thats causing the probelm, work thru settings or hardware until you find the cause. DRM/HDCP is black magic tho.. major PITA if that's the issue and nothign you can do about it except wait for updates. good luck tho
post #4 of 10
Do not know what this^ means, so can you please elaborate?
Sorry for taking so long to reply; I had just shrugged off the problem because it was getting me so frustrated. I just didn't even bother watching anymore discs until tonight (also gave me an excuse to use the Netflix that I pay for).
I tried the movie tonight (Terminator 3: Rise of the Machines), and again it won't play on my projector, but does play perfectly on the TV. I manually set the PS3 to 720p as suggested, made sure everything is updated, etc. What boggles me is the fact that:
a). All of these movies that give me problems through the projector work fine through my TV, and
b). Several movies (DVD, Bluray, and even all of my PS3 games) work perfectly through the projector, while some don't.
Another really weird thing is that when I first put Terminator 3 in I heard all the disc's startup audio and what not while the screen was black, but then - right as a movie trailer was about to play - the blue screen that reads "the following movie is rated R" showed, but then the screen went black again and didn't show anything else. Why would this one particular frame show up, but nothing else?! confused.gif
post #5 of 10
Maybe the ps3 is maintaining the video settings for the tv. After your connected to the pj, go into the video settings and redo them. The cable may still be an issue as well.
"DRM/HDCP is black magic tho"
He's just saying it's hard to work with sometimes, due to the way the tech works. Isolate the component causing the issue, and go from there.
post #6 of 10
What settings are you referring to specifically? I manually went in and changed Output to 720p, if that's what you were referring to...
And would the cable cause issues with only some movies/discs? If so, is there any specific reason to this...why some movies work fine while others don't?
post #7 of 10
Tried some movies that had previously worked in the past, and they didn't this time around. I went back through this thread and reset the "BD internet connection" setting to "confirm." After doing that, some movies (ones that worked in the past) worked again, if I selected "No" for using internet connection to access disc information.
However, I tried another movie that I previously hadn't (Terminator Salvation) and it did not work. This is driving me nuts!!
Edit: I did some Google searching and found some others with similar problems; ended up being that I needed to
Video Settings --> 1080p 24 Hz Output (HDMI) --> Off ...it was previously set to "Automatic" and was not working, but works fine when set to "Off"
Edited by KtrainHurricane - 5/21/13 at 2:07pm
post #8 of 10
Glad you got it sorted. Thanks for the update so others having the same issue might also find an answer. My "black magic comment" was as explained.. some certain combination of hardware only works with certain settings (very few of which are explained or standardized.) There's so many variations and versions all you can do is methodically try every permutation of options.. or hope someone else has already found a solution and try that. Now you can finally just watch movies and forget about the science experiments.
post #9 of 10
Exactly! ...Thanks again!
post #10 of 10
I just got an EPSON 730HD projector and I had the same problem, the PS3 wouldn't play some Blu Rays. Turning HDMI Automatic off did not help. But I turned the internet connection off and that worked. Now when I load a disc the player asks me if I want to turn the internet connection on and I just click no. I
