AVS › AVS Forum › Audio › Receivers, Amps, and Processors › Toroidal Transformer, is it really needed...
post #1 of 13
Toroidal Transformer, is it really needed more than once?
I see some of these "High End" processors advertised that they have "Large Toroidal Transformers" which I assume is cleaning up the power, but if your processor is already connected to a line conditioner that also has a large toroidal transformers is it really needed?
If the electricity goes thru your line conditioner transformer for cleaning and then again does the same thing thru your processor does this help or hinder it?
post #2 of 13
The advantages of a torroidal power transformer are:
  • Less interference due to EMI from the transformer magnetics
  • More compact, increased voltage/current output capability for its size
But these come @ a higher transformer component cost, a nice touch in a higher end component..
Just my $0.02... 👍😉
post #3 of 13
Yes it is a nice touch, but how many times does power need to go thru these toroidal transformers?
Does that mean if your processor has a toroidal transformer it can go plugged in directly to the wall instead of a line conditioner?
Is there any harm or good hooking it up to a line conditioner that already has a toroidal transformer?
post #4 of 13
Toroidal transformer's have pluses and minuses.
PLUS
Less external magnetic field.
Smaller size.
Less weight.
MINUS
Wider band-width so line noise can pass through.
Poorly designed or mis-specified are sensitive to high line voltage and DC offset.
post #5 of 13
"Is there any harm or good hooking it up to a line conditioner that already has a toroidal transformer?"
Seems to me like overkill.
post #6 of 13
Line conditioner is the overkill, not the toroidal transformer inside per se. Your assumption that the TT inside AVR is for 'cleaning up power' is incorrect.
post #7 of 13
Most transformers are just fine if designed properly. Toroids are just lighter and cheaper to make. And as for anything between the wall power and your equipment , forget it, nothing really works good. Just be sure and unplug during lightning storms.
post #8 of 13
Thanks, I did have a misunderstanding on the function of the TT, but are you saying that the power coming into the home can not be cleaned up with a line conditioner?
post #9 of 13
Lets clear up some inaccuracies...
  • The power transformer is the single most expensive component in an AVR
  • The traditional EL type power transformer is cheaper to build than a torroidal
  • Due to the high cost of the power transformer whether EL or torroidal this is where many brands cut cost using small guage wires for its internal windings which can saturate under load
  • A torroidal has certain advantages for minimal EMI radiation interference, ie. less hum
  • A torroidal can be made more compact than an EL type if used in a smaller footprint component
  • A power transformer be it torroidal or EL does not kleen up the power
Just my $0.02.... 👍😉
post #10 of 13
Unless it is used as an isolation transformer.
post #11 of 13
'kleen up'? Is it US spelling of 'clean', or something related to Kleenex? biggrin.gif
No I wasn't saying that, just in most homes cleaning up power isn't necessary.
post #12 of 13
Isolation transformers don't clean up noise....they just isolate. The fact that noise is AC..will get through the transformer pretty much by their very nature.
post #13 of 13
Originally Posted by M Code View Post
[*] Due to the high cost of the power transformer whether EL or torroidal this is where many brands cut cost using small guage wires for its internal windings which can saturate under load[/quote.]
Not quite correct; saturation happens in the iron core; less copper increases power loss because of its higher resistance.
