AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Subwoofer Plate amp Help
post #1 of 6
Hi, I got this plate amp from ebay but how do i connect to my subwoofer?
I only see high out and no sub out?
I already have amp to run center, front, rear speakers.
I'm planing to use this plate amp to my car subwoofer.
post #2 of 6
There should be two wires to connect the amp to the driver.
post #3 of 6
I don't see any other wires.
Item link
post #4 of 6
Can you take another picture showing the "face" of the PCB(printed circuit board)? That's the board on the left on the top picture you posted. There should be a couple of terminals labeled + and - somewhere on that board.
EDIT---see you beat me to it by a few seconds!
Anyway----I see the negative terminal in the first picture " SPKR - "
Look for another terminal labeled SPKR +
Tom V.
post #5 of 6
Thank you very much!
! found the +. Is this one?
post #6 of 6
Yes that appears to be it.
I have no experience with that particular amplifier so if the seller seems knowledgeable enough it wouldn't hurt to verify things with him/her of course.
Tom V.
