Originally Posted by
bebop86
Decided to add a lumagen to my theater- Not sure which one to get- I have a Sim2 PJ, Classe SSP-800 processor,Oppo 93 BR, cable box, HDDVD, and maybe an x box- I can get an 3dxe demo or the new 2021 for roughly the same price- Which one would you guys recommend and why- Also can i run my Pj and my plasma from the Lumagen or only one - Thanks so much for the input!!
Hello.
The question is: what do you need for your setup ?
If you need:
- 6 HDMI inputs
- many Analog video and audio (2ch) inputs
- many coax and optical inputs and outputs
- PiP/PoP video processing but no Darbee
Then you should buy a XE-3D.
If you don't care about analog inputs/outputs, PiP/PoP processing and you need:
- 4 HDMI inputs
- 1 coax output
- Darbee
Then you should buy a 2021. Moreover the 2021 has a new FPGA with some room left so Lumagen might add some features later on (this is my guess)
XE and 2021 are identical except for the things listed above.
