AVS › AVS Forum › Audio › 2 Channel Audio › How much should I spend?
post #1 of 6
Is a $1,000 pair of speakers too much for a $500 receiver?
post #2 of 6
No, unless it is happens to be a really crappy receiver. At $500 its probably adequate for many/most speakers made unless they are terribly inefficient and/or present really demanding impedance loads.
Think about upgrading the receiver if/when you find it lacks features,.surround processing modes,.connectivity, etc you need or want, or if you fall in love with one of those aforementioned difficult speakers.
I wouldn't bat an eye if you told me you bought $10k speakers to pair with it.
post #3 of 6
It better not be cause mine cost more than that and they sound fantastic.
post #4 of 6
If you're in love with the speakers, NO.
post #5 of 6
As long as that purchase is within your budget go for it, going forward you may want to upgrade the receiver (if you are not happy with it).
post #6 of 6
Certainly not!
I would recommend the PSB Image T6 speakers for almost any receiver in that price category.
They run $1300 per pair and are some of the best speakers you can get for under $2000.
Other excellent ones are the Monitor Audio Silver RX-2 for $900/pair and the Monitor Audio Silver RX-6 for $1300/pair.
The Wharfedale Diamond 10.4 speakers are also very good for around $800 per pair.
By the way, if you have not already purchased a receiver, I would strongly recommend the Harman-Kardon HK-3490 receiver, which is only $400 and IMO is worth twice the price; an incredibly good unit at a steal of a price.
