AVS › AVS Forum › Display Devices › Screens › DIY Screen Section › painting today in case anyone wants to help me make certain I don't screw up!!!
post #1 of 21
wall is mudded, and taped off.
getting ready to prime. using bullseye 123.
should I use my mixer on the primer?
post #2 of 21
*squirrel cage mixer
post #3 of 21
also, how long between primer coats? was it 30 - 40 min? or just until the surface is room temp?
post #4 of 21
Always a good idea, and absolutely so if thinning Primer with water for spraying.
Bullseye primer is Thinner out of the can that Kilz2, so if your rolling, effective stirring (at slow speed) helps disperse any clumps that might be in the paint.
If spraying...30-40 min. Rolling...at least the 1 hour as recommended. No matter how you apply it, the safest judgement is made when the surface no longer feels "cool".
post #5 of 21
I am spraying.
should I add water right out of the gate? or see how it's coming out? how will I know?
ps, I've done more homework on existing threads this time as to circumvent mind numbing redundancy smile.gif
post #6 of 21
right now i'm sanding. it's taking longer than I thought to get it BB smooth.
post #7 of 21
correction....MUCH longer. done sanding...finally.
what flow setting should I have the trigger governer set at?
as for the spray nozzle...I'm guessing that I want to have it set to a narrow, vertical stream...correct?
post #8 of 21
ps, do I have to strain the primer?
post #9 of 21
Yes
post #10 of 21
Originally Posted by rengep View Post
Yes
thanks! on more...when priming or applying maxx mudd, do I have to do anything between coats such as cleaning the the spray nozzle...or remixing?
also, I'm still not sure what settings the sprayer should be on for the tip shape and the flow amount.
post #11 of 21
post #12 of 21
Most tips that are 2.0 mm to 1.5mm should be ran "Wide Open" and the flow amount controlled by distance from the surface and the speed across the surface.
The strength of the Gun's output also has an effect. A Wagner Control Spray Max has almost 2x the output of a Graco 2900, so both speed and distance is adjusted accordingly.
post #13 of 21
after priming, I'm noticing a few air bubbles are still evident in my mud. I was hoping...very optimistically...that doing 3-4 primer coats would fill the bubble holes. they are stil lthere in full force.
I'm thinking spackle the holes...re-prime the affected areas, then spray my max mudd.
post #14 of 21
You are talking about Drywall Compound "Mud" correct?
You have to lightly sand the affected areas, wipe them clean with a damp cloth, and apply only a very small amount of "Mud" to the "hole-y" areas. Just enough to fill the holes. Apply too much and all you do is trap air in the holes and it bubbles out as the "Mud" shrinks as the Primer you apply gets the "Mud" wet on the surface, and then the air is drawn up / out as it dries.
Let the "Mud applied-to" areas completely dry....then repeat. Then prime with very light coats, letting each dry completely to avoid excessive re-wetting of the underlying "Mud".
DO NOT USE SPACKLE !! It has a different texture than "Mud" and will not blend easily, if at all. Spackle is good for filling a hole, but only to a point. Afterward, you should sand Spackle and then apply a skim of "mud" to equalize out the appearance.
post #15 of 21
ok, the holes appear to be corrected. now I'm repriming. I kind of feel like my (new) first prime coat went on to heavy. I'm seeing some 'rippling' in the surface. I'm guessing one of the following is to blame:
- too much water, leading to faster spray rate.
- standing too close
- going too slow.
I'm thinking I will prime 2 more coats, allow that to dry, sand out the ripples, then move to my maxx mudd coats. sound about right?
post #16 of 21
- going too slow.
As for the three reasons, they all are linked.
A very thin paint? Just move faster and from a slighter greater distance.
Standing too close? Hmmmmm.................how about stepping back a little?
Going too slow? Speed up.....OK?
Very thin paint + standing too close+ going to slow = a serous case of SOOL syndrome.
Remember, the best finishes go on as successively applied thin coats.
No,No,No,No,No,No,No,No,............................, sand out the ripples first! You don't want to build up paint over a mistake, or you'll have to sand down to the mistake anyway.
post #17 of 21
this is my 3rd coat of maxx mudd. I sanded the primer down before applying my first coat of maxx mudd.
this is pretty up close...camera is about 2" from the screen surface.
my first 2 coats were quick dusters. for the 3rd coat, I tried to mimmick what you did on your 2nd duster in your video (the one w/ the edge lit screen)
is it normal to have this much texture?
post #18 of 21
here's my 4th coat while still wet. you can see the speckling
post #19 of 21
again, this is VERY close up. kind of makes it look worse than it is.
post #20 of 21
that doesn't appear to be bad.
personally i'd like sweep sand it with a fine 3m sanding sponge then put on a couple more dusters.
post #21 of 21
that's what I was thinking. thanks!
  Back to Forum: DIY Screen Section
