AVS › AVS Forum › Video Components › DVD Recorders (Standard Def) › ImgBurn Downloads and Alternate Programs
post #1 of 6
For several years I had used the ImgBurn freeware to copy non-copy protected DVDs. With the purchase of a new desktop PC of course my ImgBurn application has gone away and I'd be happy to download it again--except that, when I go to the ImgBurn site, there appear to be several download options. none of which are provided by ImgBurn. I always wonder if these various download options are safe, i.e., I don't want to be downloading a monster virus inadvertently.
1) Should I be looking at a reliable commercial program? Several years ago I used some fairly comprehensive Nero application but it was cranky and hung up from time to time. When I purchased a new computer, the manufacturer suggested ImgBurn and it had served me well up to this time. I'm just a little nervous in downloading from ImgBurn's web site but not from ImgBurn itself, so.
2) Is there any way to identify safe downloading utilities?
post #2 of 6
Imageburn's mirrors are reliable. I've contacted the author about several things with the program, and I have no problems with using any of those mirrors. Having said that, the one I would trust the most is www.videohelp.com. You can download it directly from their site, and I would rely on it as reputable and not something that is going to infect your computer.
It is still the best program by far to burn discs.
SMK
post #3 of 6
download.cnet.com has been good for me and somewhere they used to say their SW has been virus-tested before being posted?
post #4 of 6
I would second Videohelp.com. It is my primary site for acquiring software and utilities. I've never had a problem and if in doubt you can always have your virus software scan the download file (if it doesn't do so automatically).
Also a good and reputable site that I would second -- until recently. I have downloaded much from them over the years and never had anything undesired sneak through. But now it seems they want you to install a stub installer in order to download software. Ad-supported, no less. I refuse to do that.
Edited by Kelson - 3/23/13 at 10:09am
post #5 of 6
SUBJECT: Reputable Download Sites...
  • Quote:
    Imageburn's mirrors are reliable. I've contacted the author about several things with the program, and I have no problems with using any of those mirrors. Having said that, the one I would trust the most is www.videohelp.com. You can download it directly from their site, and I would rely on it as reputable and not something that is going to infect your computer...
  • Quote:
    Originally Posted by Kelson View Post
    I would second Videohelp.com. It is my primary site for acquiring software and utilities. I've never had a problem and if in doubt you can always have your virus software scan the download file (if it doesn't do so automatically)...
    ...Also a good and reputable site that I would second -- until recently. I have downloaded much from them over the years and never had anything undesired sneak through. But now it seems they want you to install a stub installer in order to download software. Ad-supported, no less. I refuse to do that.
I've been using VCDHelp.Com, now Videohelp.Com, for almost a decade without problems. VCDHelp and Doom9 were my "Go To" sites for info. You'll find *MANY* useful programs at both sites.
Download.Com / CNET.Com *WAS* a good site *MANY YEARS* ago, but since they added the intermediary download LINK at least a couple of years ago, I've avoided them.
post #6 of 6
Thanks for helping me with my question. I used vide help.com and it went quite smoothly.
  Back to Forum: DVD Recorders (Standard Def)
