AVS › AVS Forum › Display Devices › Display Calibration › latest hcfr fork + display2 and dark reading...
post #1 of 4
I recently got back into calibrating since I purchased a new plasma recently and was wondering if the Display2 still needs to have a dark reading performed upon first starting a calibration sequence. I noticed the new HCFR fork when I go to calibrate the sensor, it asks for a white pattern. What I had been then doing was provide a 100 IRE gray pattern and then hitting calibrate.
Is this totally incorrect and should I have used a 0 IRE pattern or just placed the sensor on a black surface (like a black DVD case)?
If the latter is the case, I guess I'll have to perform my calibrations again on my P50S60 and verify everything is still reading correctly.
Thanks in advance if anybody can lend some assistance.
post #2 of 4
Not much input here, guess most moved on to different calibration instruments. wink.gif
I went ahead and just re-calibrated using HCFR 2.1 and did the black reading initialization and hope my soon to be 2 year old Display2 is still reading accurate. The picture is pretty nice so hopefully it hasn't drifted much.
I'm still debating whether to get a used eye-one pro spectrometer or a colormunki display colorimeter.
post #3 of 4
For the i1D2 and the new HCFR version 3, use the same dark initialization method (meter on a flat black surface) as used with version 2.
HCFR users have moved to this thread: http://www.avsforum.com/t/1393853/fork-of-hcfr-started-whats-needed
Larry
post #4 of 4
Rightio, thanks Larry. Guess we can just disregard that it's asking for a white panel when you calibrate the meter, and just feed it the black surface.
