AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Basement build cabling question
post #1 of 7
Gotta few questions about my cabling for my basement build. I have run 4 drops of 3/4" smurf tube. I wanna drop cat 5e or cat 6 down a few, can I put both in 1 tube? Or should I put rg6 and cat 5or6 in one together?
I will have my tv, blu ray, stream box and DTV box to this area. How many runs of coxial and cat cable would you drop to this area. Thanis
post #2 of 7
No reason not to put it all in one tube (up to the capacity of the tube, of course). As to how many, just count up the number of jacks you have to feed...
post #3 of 7
Oh forgot one more question. Do I need a shielded cable for this bulid. Currently I have a box of comtran cat 5e Riser. Good cable?
post #4 of 7
If you're running new cables plus conduit now, run all your cables OUTSIDE the conduits, leave those empty for the future. If that's not the case, then, no problem stuffing a conduit full of those wires...
If this "basement build" is a theater or otherwise a primary A/V location (which I assume it is), at least 4 cat5e/cat6 lines and 2RG6. And no one here would laugh at you for running a couple more of each, either... smile.gif
No need for shielded cables. Cable is fine, nothing special...
Jeff
post #5 of 7
Thanks for the responses. Yeah I've already put 1 rg6 cable in 3 of them all ready. So would you stick with the cat 5e or I can get cat 6 tomorrow at HD. I've found out 3/4 isn't big enough for HDMI. So I've read something about going hdmi over cat 5.
Thanks again, Jeff
post #6 of 7
If you already have the cat5e on-hand use it. If you need to run HDMI over cat5e, run two cables per room to give you the most flexibility. The best HDMI-over-cat5e devices are the HDBaseT products that work with a single cable. But there are much cheaper solutions that can do the job but they will need two cables. And a third if you want Ethernet to those locations as well. (HDBaseT does all of that on one cable)
post #7 of 7
Thanks Jautor. I will go ahead and you the cable I have and drop 3 or 4 lines behind the main tv in the basement.
  Back to Forum: Home A/V Distribution
