AVS › AVS Forum › Audio › Speakers › Energy Rc-70 Volume
Energy Rc-70 Volume
post #1 of 7
I was watching TV yesterday and for whatever reason the speakers just dont get as loud as I would expect. I was watching the voice with the girlfriend and had my denon 3313 set to stereo, and at -12.5 on the dial. The volume was not as loud as I would have thought. For reference I had Athena AS-B2 speakers and a Yamaha RXV-1900 and the speakers would get much louder, I wouldnt increase the volume past -20 before it became quite loud. Now with the RC-70 which are roughly the same sensitivity seem to require much more power. Even when I put a blu ray the volume does get a bit louder but i still turn it up to -15 or -10.
My question is regarding the amp mostly. Is there something wrong with pushing this amp to -5 for the duration of a movie or while watching tv. I would assume as long as there is minimal distortion in the single it wont hurt the speakers but is this so. The room is mid-sized the towers are 7.5 and 8.5 feet away for the LP. The room is 11x20x8 so 1760 cu.ft. The sub doesnt seem to struggle at all.
post #2 of 7
Well you switched speakers and receiver so its difficult to do a comparison. Do you still have the Yamaha 1900?
-20 on the Denon and -20 on the Yamaha do not necessarily mean the same thing.
post #3 of 7
Have you run Audyssey on the Denon yet? If so, describe your procedure.
To answer your question, I have a 2113ci and watch movies at -5db all the time, perfectly fine.
post #4 of 7
We were watching that last night also & I felt like the volume was lower than usual. At least lower than it was last year from my initial thought. I think I had it on -15ish range also.
Alan P -- Is there something you're thinking of that Audyssey might do? Maybe it set all of his speakers too low, but wanted to know if you know something I dont....b/c I'm running MultEQ XT
post #5 of 7
The yamaha died. So i cant test it anymore. I ran audyssey at 6 positions looked over what the distances and xover was made some modifications. The speaker ports are open right now but soon i will shut themas they are too close to the rear wall. Roughly 6-8inches.
Crossover is set to 80hz sub is a velo eq-max 12
post #6 of 7
Nope, no secrets here. biggrin.gif It's just that sometimes people screw up the calibration, but from his reply below it sounds like he did it right.
Sounds like you know what you're doing. Do you have a SPL meter so you can verify your speakers are all at 75db? Otherwise, I would just accept that the master volume controls are just calibrated differently from AVR to AVR like afrogt said and that program material/TV channels can vary widely in volume.
post #7 of 7
I dont have an spl meter but it might be worthwhile to pick one up. Living in Canada is there any place that has decent meters for relatively cheap?
  Back to Forum: Speakers
