AVS › AVS Forum › Display Devices › Rear Projection Units › Searching For Signals Problem
post #1 of 2
Problem: When turning on my Samsung HLT6187SAX connected via HDMI to a Comcast DCX3400 STB, it displays multiple "Searching For Signals" screens before displaying a picture.
I've read here that the Searching For Signals problem can be fixed by changing a setting in the STB, and I'm hoping someone can tell me specifically what the correct setting should be on the STB menu.
Edited by bwflorida - 3/26/13 at 9:15pm
post #2 of 2
Sounds as a typical HDMI handshaking issue or a problem with the set and the resolution setting of the box.
Try using the component instead and a optical or coaxial audio feed to your receiver.
  Back to Forum: Rear Projection Units
