AVS › AVS Forum › Audio › Speakers › Just bought mythos 8
post #1 of 4
Can i use it as a Center channel only with my previous L/R speakers?
post #2 of 4
Can some one please help. Can i use it as a center only? or do i need to set it up as LCR and then use my other two fronts i have now as front highs? im not realy sure if the first would work or if the second option would be better? Thanks
post #3 of 4
Sure, although it would be best if your front three were a matching set. What L/R speakers are you using right now?
Wait a minute, maybe I'm misinterpreting what you said, but you appear to be implying that the Mythos 8 is a soundbar. Actually, it's just a single speaker.
post #4 of 4
yeah i got confused while looking at its owners manual. it showed multiple connectors in a diagram. anyways im using hd300 sats right now. from my first HT system. and now im slowly upgrading. because i have a small budget
  Back to Forum: Speakers
