Welcome to the 2013 Denon AVR-E/X model thread.
If this is your first visit to this thread, and you want to ask a question about one of the 2013 Denon AVR models, either one that you own or one that you are thinking of buying, please provide the following information to allow for better responses to your questions:
(a) Identify the model number in question (eg. E400), as there are 7 different models (E and X series) discussed in this thread. Also if you have not posted in several days since your initial post, please post the model # again so we don't have to back track to learn which model you are referencing.
(b) Identify what you've done so far to troubleshoot the issue and what the front panel is displaying if an audio issue, (also take a few minutes to review the Troubleshooting section provided at the bottom of this post to see if your question is answered there),
(c) Unless you indicate what settings have been changed, the assumption will be that all settings are on the factory defaults (ie. usually "Auto"),
(d) If the advice given seems to simplistic or obvious, don't shoot the advice giver as we have no idea of the level of your technical understanding,
(e) If there is no response to your post, it either means no one knows the answer or it has simply been overlooked so repost if you still haven't resolved your issue,
(f) If you post a question in this thread and are given advice and either it or some other advice (eg. Denon phone support, Denon "Ask a Question" email support) resolves your issue, have the common courtesy to post back what solution resolved your issue so others can learn from it as well,
(g) If the issue is not user error or not just a misunderstanding on how the AVR works, please call Denon support so the issue is registered,
(h) When responding to another post that is providing assistance to you, please press the "Quote" button in the lower right corner of that other poster's response so that response is also listed with your new post, and,
(i) If you don't live in either the USA or Canada, please either indicate your country location in your profile or your post as some Denon models from other regions in the world differ in configuration from their USA/Canada counterparts (eg. European 2313 has 7.2 pre-outs) otherwise responses made will be regarding the USA/Canada model.
2012 and 2013 Denon AVR FAQ, Setup, and Troubleshooting Guide
This guide provides general information on the following Denon AVR models:
Calendar year 2012 - (
1513, 1613, 1713, 1913, 2113CI, 2313CI, 3313CI),
Calendar year 2013 - (
E200, E300, E400, X1000, X2000, X3000, X4000)
however, some areas may apply to previous model years as well (esp. Troubleshooting).
Some of the new features of the 2013 models include:
1. Return of AM tuner to all models (so all models have AM/FM tuners).
2. Easier to use color coded speaker clips (E200) / speaker posts (E300 and higher) - note that although the new posts on the E300 and E400 will not be able to accept banana plugs, they should be much easier to use bare speaker wire than the speaker posts on previous year's models. The "X" series model speaker posts will accept banana plugs.
3. Return of HDMI input assignment and addition of analog audio input assignment for first time (E300 and higher).
4. Listen to USB/Tuner/Network audio source while watching separate video source (to include HDMI for first time) (E300 and higher).
5. Listen to external audio source connected to analog CD input (E400/X2000/X3000/X4000) while watching a video source not otherwise assigned to CD input (X4000 also adds capability of listening to Phono input as well while watching a video source).
6. New "HDMI Pass Through" setting which acts separately from the HDMI Control setting and factory defaults to ON with the "Pass Through Source" setting defaulting to CBL/SAT, such that right out of the box the CBL/SAT box should pass audio/video through to the TV when the AVR is in Standby without making any further setting changes.
7. IP CONTROL setting defaults to ALWAYS ON such that once the networking model is connected to your home's Wifi router/modem and working correctly, you should be able to control the AVR from your smart phone app without making any further settings changes (E300 and higher).
8. Network Diagnostics feature added (E300 and higher).
9. "All Zone Stereo" feature to pass the same HDMI, optical, or digital coax audio source playing in the main zone to Zone 2 while downmixing main zone audio to stereo (E400 and all X series).
10. Independent HDMI/optical/digital coax PCM 2.0 to Zone 2 speaker posts or pre-outs (X3000/X4000) and independent optical/digital coax PCM 2.0 to Zone 3 (X4000) speaker posts or pre-outs.
11. Audyssey MultEQ XT32 drops down to the X4000 (formerly only on the 4XXX models) along with Sub EQ HT for dual sub level and delay setting with the capability to expand the X4000 to 9.2 via an external amp.
TABLE OF CONTENTS
1. Audyssey MultEQ
.......... a. Audyssey Mic Not Included
.......... b. Audyssey Setup
.......... c. Subwoofer Settings
2. AVR General Info
.......... a. Component --> HDMI Video Conversion
.......... b. GUI/Menu
.......... c. HDMI --> Component Video Conversion
.......... d. Master Volume Adjustment
.......... e. Microprocessor Reset
.......... f. Mute Icon
.......... g. Power OFF AVR
.......... h. Power Ratings
.......... i. Power Indicator Light when AVR in Standby
.......... j. Protection Mode
.......... k. Remote Control
.......... l. Settings - Memory Retention
.......... m. Setup Lock
3. Denon Website Info
.......... a. Owner's Manual
4. Features
.......... a. 1080p/4K Video Upscaling
.......... b. 3313CI/X4000 - Extra Speaker Posts/Pre-outs
.......... c. Amp Assign - Bi-Amp
.......... d. ARC (Audio Return Channel)
.......... e. Bluetooth Adapter
.......... f. CI/X Models
.......... g. HDMI Audio Out
.......... h. HDMI Standby Pass Through
.......... i. SAVE/LOAD config settings
.......... j. Stream iPhone/DLNA server music to non-network models
.......... k. Watch TV while listening to a different audio source
5. Known Issues: 2012 (XX13) models:
--->Post 4 of 2012 Denon XX13 thread. 2013 (E/X) models:
--->Post 4.
6. Miscellaneous
.......... a. Bitstream vs. PCM
.......... b. HDMI Cable 1.3 vs. 1.4
.......... c. Keep the box
.......... d. Older AVR w/o HDMI jacks
.......... e. USA/CA vs. Europe/Asia Pacific Models
.......... f. Used/Demo/Open Box/Refurb
7. Networking
.......... a. Airplay
.......... b. Connecting to Home Network
.......... c. Firmware Updates
.......... d. Network Reset
.......... e. NET/USB
.......... f. Remote Control Smartphone Apps
.......... g. Rhapsody Smartphone apps
.......... h. SiriusXM Smartphone apps
.......... i. Spotify Smartphone apps
8. Purchasing Info
.......... a. Best Buy/Magnolia
.......... b. On-line Dealers
.......... c. Warranty
9. Rear Panel Connections
.......... a. 12v Trigger
.......... b. IR Extender/Repeater Kit
.......... c. Switched Outlets
.......... d. Turntable/Phono
10. Speakers/Subwoofer
.......... a. Dual Subwoofers
.......... b. Front Height / DSX Wide minimum requirements
.......... c. Minimum number of speakers
.......... d. Speaker Recommendations
.......... e. Speaker/Subwoofer Volume
.......... f. Speaker Wire
.......... g. Subwoofer - Best Location
.......... h. Subwoofer - Cable option
.......... i. Surround Speaker Placement/Connections
.......... j. Tower Speakers w/built in subwoofer
11. Troubleshooting
.......... a. Airplay Icon not showing up
.......... b. “Airplay Speaker Not Available”
.......... c. AVR randomly changes to other sources
.......... d. AVR shuts down at higher volumes
.......... e. AVR switches to TV source when first turned ON
.......... f. Cannot see networked Denon on my WIN XP computer/laptop
.......... g. Center Channel dialog too weak watching TV
.......... h. "Connection failed. Check the device"
.......... i. Green screen on TV
.......... j. HD Channel (DD 5.1) in Stereo
.......... k. HDMI Handshake Issues (audio/video dropouts)
.......... l. HTPC won't pass audio/video
.......... m. Intermittent HDMI audio/video
.......... n. No audio from single speaker
.......... o. No Video on AVR front panel display
.......... p. Projector - no video displayed
.......... q. PS3/Blu Ray Player (BDP)/Game machine - No Video or Intermittent Video Issue
.......... r. Speaker volume change won't stick
.......... s. Subwoofer not working
.......... t. Surround mode changes
.......... u. Unresolved Issues
.......... v. Volume drops randomly from AT&T U-verse box
.......... w. White sparkles on TV
.......... x. Why do my small speakers get set to LARGE?
.......... y. Why does front panel display read "Multi Ch In" and not DD TrueHD/DTS HD MA?
.......... z. Why only "STEREO" or "PLII" and not DD TrueHD/DTS HD MA?
.......... z1. Wii only displays in 4:3 aspect
.......... z2. WIN 7/8 PC shows up as "Not Authorized"
.......... z3. WMP 11/12 audio files won't play from PC via wireless network
12. Zone 2
.......... a. 2-CH Amp
.......... b. Source Limitations
.......... c. Whole House Audio
.......... d. Wireless Headphones
1. Audyssey MultEQ
a. Audyssey Mic Not Included: If you think Denon forgot to ship the Audyssey mic with your new AVR ... check again. The mic is located inside a small white box that may be
embedded inside the styrofoam packaging itself so check all around the styrofoam.
- 2012 (1613 and higher)/2013 (E300 and higher): These models ship with the Audyssey ACM1HB mic which is interchangeable with the Audyssey DM-A409 (2008-2011 Denon models) and Audyssey ACM1H (Onkyo/Marantz) mics.
If the mic is indeed missing, you cannot use just any mic from another brand (other than Onkyo or Marantz) as the DM-A409/ACM1H/ACM1HB mics have been calibrated to work with the Denon AVRs. Contact Denon for a replacement or you can usually find one on eBay for about $25 (although don't purchase one from outside the USA as they may be knockoffs).
b. Audyssey Setup: The Setup Wizard and Speakers - Audyssey Setup can be run at any time. Just because you only have the front main (FL/C/FR) speakers or even just a set of 2.0 stereo setup is no reason not to run Audyssey Setup. If you add more speakers, simply run it again. You'll also want to rerun it if you move the speakers or any furniture in the room.
Regardless of how many actual seats are in your listening room and where they are physically located, ideally you will want to run all 6 (MultEQ) or 8 (MultEQ XT/XT32) positions using a
camera tripod or
(boom mic stand +
mic adapter) within no more than a 2'-3' radius around the
#1 mic position (ie. main listening position (MLP)) in order to provide the most data points for the Audyssey filters. Note that on the 1713/2113CI/2313CI/3313CI models, although Audyssey MultEQ XT can measure up to 8 mic positions, Denon has reduced this number to only 6 mic positions when running the Setup Wizard to shorten the setup time (this is no longer the case with the new 2013 "X" series models as you can run all 8 mic positions using the Setup Wizard). On the XX13 models, in order to get all 8 mic positions (recommended), you will have to run Audyssey from the Speakers - Audyssey Setup menu. One of the reasons you likely bought a Denon AVR was for Audyssey, so take advantage of its capability by providing it with as much data as possible. The whole process shouldn't take more than 20 minutes, although ensure it is completely quiet in the room (ie. no pets or kids running around, no A/C noises, no PJ noise). Also, the test tones can be quite loud (75db), so best not to do this at night (especially if living in an apartment).
The Audyssey mic cable length is 25'. If you have the AVR located in a closet or some distance from the main zone, you can buy a 25' extension cable like
this one; however, 50' from the AVR to the mic is the maximum length that Audyssey recommends.
Prior to running Audyssey Setup, you'll ideally want to have your front main speakers toed in towards the main listening position, the center speaker angled up/down (as appropriate) to aim towards the main listening position (ear height) and if using front height speakers, aimed down towards the main listening position.
It doesn't matter what settings you have set prior to running Audyssey Setup as they will be ignored and any previous Audyssey settings will be written over each time Audyssey Setup is run. Simply follow the directions listed in the SETUP WIZARD or follow along in the Denon Owner's manual. Also note that some speakers are intentionally wired "out of phase" by the mfr so if you get a PHASE error and have confirmed the speaker is wired correctly (i.e. +/+ and -/-) then simply press SKIP and move on to the next speaker. Initially just run 1 mic position with the sub volume/gain knob set to 12 o'clock (middle volume) and check to see what the Denon set the sub volume to ... if it's -12db (ie. this means the sub is too loud and the Denon has reached the maximum limit of -12db in attempting to lower it to the 75db calibration volume), you'll want to lower the volume knob on the sub a few notches (eg. to 10 o'clock) and run Audyssey Setup again for just 1 position. As long as it's < -10db (eg. -9db, -8db, -7db, etc.) you're good to go to complete the remaining 5 (MultEQ) or 7 (MultEQ XT/XT32) positions. There is no reason to get it as close to 0db as possible (unless the sub signal is not causing the sub to turn ON and in that case, get the trim closer to 0db so the AVR sends a stronger signal to the sub) as doing so simply allows more room to adjust the sub volume lower even more with the remote (which isn't what most will want to do, rather most will likely want to raise it a few db louder).
The AVR will generally set any speaker that is capable of playing a < 50hz frequency (regardless of what the mfr's spec is on paper) in your room to LARGE. Note this setting is NOT about the physical size of the speaker, rather simply whether it can play low frequencies (LARGE) or not (SMALL). However, after running Audyssey Setup, if you are using a sub, go into the Denon GUI and change ALL speakers to SMALL and raise any crossovers that were set below 80Hz up to either 60Hz or 80Hz (whichever you prefer). This not only transfers those lower frequencies to the sub (which is generally able to handle them better as it's got it's own amp) but also frees up some extra headroom for the AVR. Also note that there are 64x (MultEQ) and 8x (MultEQ XT) more Audyssey filters used for the sub then for the speakers so your setup will likely sound better by transferring more to the sub (note that XT32 employs the same number of filters for the speakers and sub). Feel free to adjust the sub or speaker volume level higher/lower using the GUI menu to suit your preference as doing so will not affect the Audyssey filters. For better center channel dialog during TV viewing, make sure the center speaker is angled up/down (as required) towards ear height of your main listening position. You can also set the Audyssey Dyn EQ Reference Level Offset setting to "10db" for the cable/sat box source.
- 2012 (1613 and higher) and 2013 models (E300 and higher): feature a “Dialogue Level” setting which can also be adjusted to increase/decrease center channel volume level.
Note that in order to use Audyssey MultEQ, as well as the Audyssey related features Dyn EQ (increases bass and surround audio at lower volumes below 0db) or Dyn Volume (tames loud commercials/explosions for late night viewing), you must run Audyssey Setup. Generally most folks will want to use Dyn EQ for all sources, all the time (as most everyone listens at below 0db), and use Dyn VOL (EVENING/MEDIUM) for TV and late night movie viewing only (when it's important to keep the loud explosions down due to sleeping kids, etc.), leaving it OFF for regular movie viewing when there's no need to be quiet.
c. Subwoofer Settings: Prior to running Audyssey Setup, the sub knobs should be set as shown below. Refer to your AVR Owner's manual section on "Setup Speakers (Audyssey Setup) - Setup subwoofer." For information on setting up dual subs, refer to the
Audyssey Setup Guide para III. If you have an AVR with dual sub pre-outs (2313CI/3313CI/X3000/X4000), simply connect a digital coax cable from each pre-out to each sub, otherwise, you can also use a RCA “Y” splitter cable from a single sub pre-out to each sub.
- Volume : “12 o'clock position” (or middle volume) •
- Crossover frequency : “Maximum/Highest Frequency” (eg. if 80hz-150hz, then set to 150hz) •
- Low pass filter : “Off” or maximum/highest frequency (eg. if 80hz-150hz, then set to 150hz) Note: This is not the same as the "LPF for LFE" setting on the AVR which should be left at it's factory default setting of 120hz •
- Standby mode : “Off” (ie. sub should be powered ON and not in AUTO) •
- Phase : 0
Once Audyssey Setup settings are saved and you are satisfied with the settings (ie. sub is not set to -12db),
DO NOT make any further volume adjustments on the sub itself (other than possibly changing the power from "ON" to "AUTO"), rather adjust the sub volume using the remote control, the GUI menu. Although the speaker "distances" will likely be spot on, the sub "distance" will likely be considerably longer as it is actually a value that allows for a delay due to filters in the sub
so do NOT manually change the sub distance to its actual distance.
- 2012 (1613 and higher) and 2013 models (E300 and higher) - There is no box around the word Audyssey icon on the front panel display (which is the case on 2011 and earlier Audyssey models) so there is no change to the front panel display when changes are made to the speaker settings (ie. the word Audyssey remains lighted as before whereas on 2011 and earlier models, the box around the word Audyssey will disappear).
- Although there is a note in the manual that specifies "After performing Audyssey Setup, do not change the speaker settings or subwoofer volume. In event of a change perform Audyssey Setup again.", this really should say "if adding additional speakers or changing the location/orientation of the speakers/sub" as neither changing the speaker settings or subwoofer volume will require you to rerun Audyssey again.
For more questions about Audyssey, refer to the
Audyssey 101/FAQ Guide or go to
Ask Audyssey.
2. AVR General Info
a. Component --> HDMI Video Conversion: Only the 2012 (1913 and higher) and 2013 (E400 and higher) can convert an analog video source to HDMI. Another alternate option is to use a component --> HDMI converter or if you have a Wii you can use the
Wii2HDMI.
b. GUI/Menu display All 2012 (XX13) and 2013 (E/X) models can ONLY display the GUI/status menu over an HDMI connection to your TV. Although much of the information can be read on the front panel display, some setup information is NOT displayed so you are much better served reviewing the GUI setup on the TV. To display the GUI, simply press the appropriate menu button on the remote (ie. INFO, OPTION, or SETUP). If you only use a projector with no HDTV, you may want to consider purchasing a small 12" HDMI display for setup use only.
Note: The GUI is displayed in 480i resolution so if you have an older TV that cannot display 480i over HDMI, try playing a video source and displaying the GUI over the non-480i video source. The GUI display defaults to 30sec for the NET/USB, TUNER, and iPOD menus. This setting can be changed to 10sec, OFF, or always ON. When using the Video Select feature, eg. to watch cable TV with the TUNER as the audio source, you may have to set the TUNER GUI display to OFF. One piece of information that is not displayed on the front panel display is the AVR's IP address; however, one owner (w/o an HDMI TV) was able to get the IP Address by using the iPhone remote app
DeRemote.
c. HDMI --> Component Video Conversion: If you have an older non-HDMI TV, note that there is no HDMI--> Component video conversion by any current AVR on the market. Either you must use the 2313CI, 3313CI, or X4000, which have (2) component video inputs AND (1) output, or you can use an external device that can do the conversion.
d. Master Volume Adjustment: Unlike perhaps your older receiver that was really loud at say 1/4 of the maximum master volume scale, Denon AVRs use a logarithmic scale and will require the volume turned to roughly 2/3 of the maximum for average volume levels. Denon AVRs have two volume scales, the default being "absolute" (0-98) and "relative" ( -79.5db to +18db), although note that the terms “relative” and “absolute” are no longer used in the XX13 and E/X manuals. If you have run Audyssey Setup, then average volume for most folks with 8Ω speakers and at least 87db+ efficiency, will be around -30db to -20db (51-61 absolute) for TV listening and -20db to -10db (61-71 absolute) for movie/music listening. Each model has a "Volume Limit" setting that defaults to OFF although can be set to 60(-20db), 70 (-10db), or 80 (0db). Setting this to 70 (-10db) is a good idea to ensure that others in the house cannot raise the master volume too loud which might cause the AVR to shut down in protection mode or clip the speakers. Also, to ensure the AVR doesn't shut down in protection mode, it's a good idea to not raise the volume above 80(0db) (little additional volume gained at the price of an extreme increase in power required). Also note that when adjusting the volume using the remote, it's better to tap the volume up/down buttons as pressing and holding it down for several seconds results in a HUGE change in volume. This is common to ALL stock Denon remotes.
e. Microprocessor Reset:
2012 (XX13) models: Post 5 of 2012 XX13 thread. 2013 (E/X) models: Post 5.
f. MUTE Icon: There is currently no way to remove the MUTE icon from the TV display when in the MUTE mode. To prevent the relays from clicking when pressing MUTE, change the “Mute Level” setting from “FULL” to “-40db.
g. Power OFF AVR: The only way to turn the AVR completely OFF is to unplug it, otherwise it is either ON or in Standby. Each model will use anywhere from roughly 65W-85W when ON (no audio playing) to 80W-100W at reference volume (0db) using 8Ω speakers of at least average sensitivity (ie 87db+). In Standby they will use 0.1W with HDMI Control OFF, 0.5W with HDMI Control ON, and about 2.7W with IP Control set to ON.
h. Power Ratings: For marketing purposes, Denon generally uses 6Ω ratings (ie. gives a higher wattage rating) on the lower level AVRs which is why you will find them advertised (eg. Best Buy) at higher power ratings than listed in their Owner manuals or in these info posts both of which use the 8Ω rating. For example the 1913/E400 are 90W AVRs; however, are marketed as being 125W. Remember to read the fine print when checking the power ratings of an AVR. Also note that the difference in power ratings between these models is moot as going from the 75W (1613/E300) to the 125W (3313CI/X4000) will result in less than a 3db increase in volume .... 3db being the lowest amount of volume that can generally be detected by most people. This is the reason that if you truly want additional volume capability, you are better served adding an external amp of at least 200W+ (although this can only be done with the 3313CI/X4000 models as they are the only models with main zone pre-outs to connect to an external amp) or simply buying speakers that are at least 3db more efficient (eg. from 86db to 89db efficiency/sensitivity rating).
i. Power Indicator Light when AVR in Standby: When either "HDMI Control" or "HDMI Pass Through" are set to ON or "IP Control” is set to ALWAYS ON, the power indicator light above the power button on the AVR's front panel will change to solid "red" when placed in Standby mode.
j. Protection Mode: If the AVR shuts off in protection mode and the power indicator light
flashes red, it generally means the following based on the frequency of flashes:
- Every 1/2 sec = speaker wire from one post touching another post (most common); driving 4Ω speakers too loud (ie. >-10db); or amp failure
- Every 2 sec = temperature of the AVR is too hot (provide more ventilation)
The most common cause for shutting down, is a loose speaker wire strand touching another post. A great way to shore up loose speaker wire strands is to use
banana plugs on those models that accept banana plugs (ie. 1613 and higher and "X" series). Visually check the speaker connections at both the AVR and the speakers themselves to guarantee that speaker wire from one post isn't touching another post. Pull the AVR out of the rack or cabinet if you have to in order to ensure this is the case. If you have in wall speaker wire, it's very possible a nail may have split the speaker wire casing causing it to short. If you have confirmed there are no speaker wire issues and are not running 4Ω speakers excessively loud, then disconnect all sources and add one at a time to see if the issue is being caused by a particular source. If not, then disconnect all the speakers and add one speaker back at a time to see if the issue is caused by a particular speaker. If not and you are using a power strip, try connecting directly to the outlet as you may have a bad power strip. If still no joy, then try resetting the microprocessor as a last resort. If still no joy, you're likely looking at having to send the unit in for repair as it could be amp failure.
k. Remote Control: The Denon 2012 and 2013 stock remotes cannot operate other 3rd party devices (except 3313CI/X4000). If you want to boost your Wife Acceptance Factor (WAF), your best bet is to purchase a Harmony (or other universal/programmable) remote which can be used for not only most every function on the Denon stock remote but also to control your other devices as well. Simply download the remote codes for your particular Denon AVR model (and other devices) from the Logitech data base. Numerous Harmony models from $50 on up are available.
l. Settings - Memory Retention: All settings in the AVR to include the Audyssey settings should be retained for at least 1-2 weeks if the power cable is disconnected from the AVR. In some instances, if the power is interrupted (eg. power outage) while the AVR is powered ON, the settings may return to their factory default settings.
m. Setup Lock: When you have small kids in the house, it may be a good idea to consider setting the "Setup Lock" feature to ON. This setting defaults to OFF from the factory. Also, with cats around, check for loose cable connections at the rear panel if you suddenly start having connection issues.
a. Owner's Manual: Denon no longer provides a hard copy Owner's manual, but rather a CD with a .pdf file of the Owner's manual. This same .pdf file can be downloaded from Denon's website
here. The X series manuals are especially formatted for the iPad and tablets.
4. Features
a. 1080p/4K Video Upscaling:
- 2012 models (1913 and higher): The 1913 includes a video chip that upscales to 1080p/24 while the CI models use the ADV-8003 that upscales to and passes through up to 4K video
- 2013 models (E400, X2000 and higher): These models include the ADV-8003 video chip that can upscale to and pass through up to 4K video. Note that the X1000 can only pass through up to 1080p and does no video analog--> HDMI conversion or upscaling. The Silicon Image chip used on the X3000/X4000 is used for the InstaPreview feature.
Note: With the release of HDCP 2.2 (2015), and the fact that pretty much all 4k content is now encrypted with HDCP 2.2, 4k/HDCP 2.2 video will not pass through any Denon AVR released prior to 2015.
b. 3313CI/X4000 extra speaker posts: Although the 3313CI and X4000 both feature 11 sets of speaker posts, they can only provide 7 (3313CI) and 9 (X4000) channels of audio at a time ... the extra speaker posts are merely provided for convenience so as not to have to rewire for other configurations. The newer X4000 also has 11.2 pre-outs with the capability to expand from 7CH to 9CH audio using an external amp. If you want to run more than 9 speakers in the main zone, you will need to upgrade to the 4520CI which is a 9.2 AVR (capable of up to 11.2 w/external 2 CH amp).
c. Amp Assign - Bi-Amp: Using this mode (known as "passive bi-amping") generally produces
no noticeable improvement in either audio quality nor extra power as you're simply sending the same full range signal to each set of posts on the bi-ampable speaker (which they would still get with a single connection) from the same single power supply in the AVR. If you want extra power for the speakers (which in most cases is not necessary for 8Ω speakers with an 86db+ efficiency in small/med sized rooms), the only USA models that will allow for an external amp connection are the 3313CI and X4000 both of which have main zone pre-outs.
d. ARC (Audio Return Channel): This is the feature that will pass audio from the TV (eg. OTA, Netflix, Hulu, Vudu, etc.) back to the AVR over the same HDMI cable that connects the AVR from the Monitor Out jack to the TV. In order for the ARC feature to work, it must be offered on
both the TV and the AVR. Just because the TV and AVR are HDMI 1.4 DOES NOT mean they offer the ARC feature.
Note the 1513 and E200 do NOT offer ARC and therefore ARC will not work when either model is connected to a TV with ARC. In order to use the TV's ARC feature you must set the TV's "HDMI-CEC" setting (LG - SimpLink; Phillips - EasyLink; Panasonic - VieraLink; Sony - BraviaSync; Samsung - Anynet+; Toshiba - CE-Link,RegzaLink) to ON as well as setting the AVR's "HDMI Control" setting to ON as the factory default is OFF. Some TV's also require the audio to be set to external speakers (eg. Samsung - set to Home Theater). Also make sure the HDMI cable from the AVR is plugged into the ARC labeled jack on the TV (eg. HDMI1 - Panasonic, HDMI2 - Samsung, Panasonic). Note that with the 3313CI, only one of the HDMI Monitor Out jacks will support the ARC feature at a time and must be set using the HDMI Control (Control Monitor) setting (p. 109/?). Once these settings are made, turn all devices OFF for a few minutes and then ON again ... TV first and then the AVR. Note that a side effect when using the TV's HDMI-CEC/ARC set to ON is that
the AVR will always shift to the "TV" source input when first turned ON rather than going to the last input that was on prior to the AVR being put into Standby (as is the case when ARC is OFF). Note also that with some TVs (ie. Samsung) the AVR will also revert to the TV input while in Standby which will prevent you from using the HDMI pass through feature (eg. cable/sat box) without turning the HDMI-CEC setting on the TV to OFF. If this is too annoying, either turn off the HDMI-CEC/ARC setting on the TV when not using it or forgo the ARC feature (set HDMI-CEC/ARC to OFF) and use an optical cable from the TV to the AVR. The optical cable will pass the same audio (PCM 2.0 or DD 5.1) that the HDMI cable would have passed with no loss in audio quality. Another option, if not trying to pass audio from the TV back to the AVR is to simply delete the "TV" source using the SOURCE DELETE feature in the OPTION menu. If you have the cable/sat box connected directly to the TV (eg. due to an HDMI handshake issue), check your TV owner's manual to see if the TV will pass DD 5.1 from connected sources when using the ARC connection (as most down mix to stereo only). If not, then connect an optical cable from the sat/cable box to the AVR instead if it passes DD 5.1 over the optical audio out.
e. Bluetooth Adapter:: Although Denon AVRs do not feature bluetooth connectivity, you can connect a 3rd party bluetooth adapter (eg.
Logitech or
Belkin) to the AVR's analog input and wirelessly stream audio from any bluetooth capable device (eg. iPhone, iPad, android phone, etc.).
f. CI/X Models: The 2012 "CI" and 2013 "X" models include such features as remote control jacks (used with IR extenders/repeaters), RS-232 jack for remote access (eg. home automation systems like Crestron), maintenance mode (pro installer or service tech only), and Audyssey Pro installer ready (2313CI/3313CI/X3000/X4000 only) - using an
Audyssey Pro installer kit via a registered Pro Installer or the kit can be purchased by consumers for $700 ($550 kit/mic + $150 license/AVR). Refer to the
Audyssey website for more information). The "CI" and "X" models also offer a 3 year warranty (vice 2 years for the non-CI and E series models).
g. HDMI Audio Out: This feature only works with devices connected to the AVR with an HDMI cable. It's an "either/or" setting in that the audio can be set to pass to the "AVR" or the "TV", but not both at the same time.
h. HDMI Standby Pass Through: This feature allows you to pass
HDMI connected sources only through the AVR (when in Standby) to the TV. On the 2012 models, set HDMI Control to ON (factory default is OFF) and set the Standby Source to either LAST (default) or to a specific HDMI jack # (eg. that the cable/sat box is connected to). On the 2013 models, HDMI Control does not need to be set to ON as there is a new "HDMI Pass Through" setting which defaults to ON with the "Pass Through Source" defaulting to CBL/SAT. Once making these settings, turn the AVR and TV off for a few minutes, then power both back on, the TV first, then the AVR. If this feature is not working for you, try setting the HDMI-CEC/ARC setting on your TV to OFF.
i. SAVE/LOAD config settings: The 2012 (1713 and higher models) and 2013 (X models) come with the feature to SAVE/LOAD the config/settings file (includes Audyssey settings) to a PC using the on board Web Control feature via the AVR's OSD.
Note: Although this feature is not offered on the 1613 or the E300/E400 networking models; both the Web Control and the SAVE/LOAD features can still be accessed using the procedure noted below.
If you are having difficulty SAVE(ing) a file, make sure to stop any network playback by first playing something on the network and then either pressing the Stop Playback (black square) or the ENTER button on the remote for a few seconds. You may also need to set "IP Control" to "OFF in Standby" (contrary to what the Owner's manual indicates). The config.dat file should be about 348kb for all models but the X4000 (952kb); however, it's a good idea to confirm the AVR is actually saving data in the file as the file size will be 348kb or 952kdb whether it's all zeroes or filled with zeroes and some data. If it is all zeroes, it will not LOAD successfully. Use a Windows hex viewer (eg.
http://download.cnet.com/HxD-Hex-Editor/3000-2352_4-10891068.html) or Mac hex viewer (eg.
http://hexedit.en.softonic.com/mac) to view the file and confirm whether it is all zeroes or not. If you do get a file with all zeroes or if a file with data won't load properly, then set IP Control to "Off in Standby", cycle the AVR OFF/ON and then try a SAVE again which should result in a config.dat file with non-zero data. It's also a good idea to SAVE the settings prior to a firmware update even though firmware updates generally don't change the system settings. If you are having difficulty using IE, try using Firefox or Chrome (see
Post #2775). If still no joy when trying to LOAD the config.dat file, try setting IP Control to "Off in Standby", cycle the AVR to OFF, then ON again and try the LOAD. If yet still no joy, try resetting the microprocessor and then do the LOAD again.
How to gain access to the Web Control and SAVE/LOAD features using the 1613, E300 and E400
Enter the AVR's IP address (eg. 192.168.XXX.XX) in the web browser of a laptop. If the Web Control menu does not display, enter the following additional information after the IP address. Using the previous example IP address ....
Web Control: 192.168.XXX.XX/MainZone/index.html (note that although the E400 does have the Web Control feature, the AVR's OSD does not provide access to the SAVE/LOAD feature without using the URL below)
SAVE/LOAD: 192.168.XXX.XX/Setup_Index.asp or 192.168.XXX.XX/SETUP/OTHERS/f_others.asp
j. Stream iPhone/DLNA music to non-network models: If you have a PS3, xbox360, or laptop that is connected to your home network as well as hard wired to your AVR, you can use the
AirMusic iPhone app to stream audio to these devices and play it through your surround setup. There are also several other devices that can be used to include Apple TV, Airport Express, as well as converting the audio to a FM frequency and playing it via the built in TUNER. Read
this article for more details. You can also use a Bluetooth adapter to wirelessly stream audio from a bluetooth device (iphone, iPad, android phone, etc.) to either a non-network or networking model as mentioned a few items above.
k. Watch TV while listening to a different audio source:You have a couple of different options here. One option is to connect the cable/sat box HDMI directly to the TV w/optical from the cable/sat box to the AVR. That way you can use the HDMI to the TV for video and then select whatever audio source you want on the AVR. Another option on the 2012 models is to use the "Video Source" feature noting that you cannot select an HDMI video source. Rather you must connect the cable/sat box to the AVR with a component video/optical cable and then while the audio source is selected (eg. TUNER), change the "Video Source" setting to the component video source. Note that on the 2012 models, with a "network" audio source selected, this feature cannot be used; however, with the 3313CI there is a work around in that you can connect the Zone 2(HDMI) monitor output to another input on the main zone TV and then while listening to a network audio source, select the Zone 2 input on the TV. On the newer 2013 models, this also applies to the E200 using the "Video Select" feature and with the E300 and higher models, any video source (to include HDMI) can be selected while listening to USB, Tuner, or network sources using the "Video Select" setting. On the 2013 models with a CD analog audio input (ie. E400, X2000/3000/4000) you can connect an external source to the CD input (as long as there is no video assigned to CD) and listen to it while watching a separate video source. The X4000 also adds the Phono input which can be used with "Video Select" as well.
6. Miscellaneous
a. Bitstream vs. PCM: When playing audio from a BD/DVD, you can set the Blu Ray player (BDP) to either "bitstream" or "PCM/Direct". By setting it to "PCM/Direct" the BDP will decode (or unzip) the file which will then pass the audio in its original uncompressed format (ie. multi-channel PCM) to the AVR which will then display "MULT CH IN" on the front panel, or you can "bitstream" the audio and just let the BDP pass the compressed file directly to the AVR to let the AVR decode (or unzip) it in which case you will see the compressed file codec used (eg. DD, DTS, Dolby TrueHD, DTS HD MA, etc.) on the front panel display.
Either way the audio quality will be the same, although the bitstreamed audio will likely sound a bit louder, and most prefer to see the compressed file codec on their AVR's front panel display rather than just "MULT CH IN". When bitstreaming the audio, ensure the "Secondary audio" or "Audio Mix" setting (if there is one) on the BDP is set to OFF. Also note that HD audio tracks can be either 5.1 or 7.1; regardless, it will be downmixed to however many speakers are in your setup.
b. HDMI Cable 1.3 vs. 1.4: There is no difference between a "High Speed" HDMI 1.3 cable and a "High Speed" HDMI 1.4 cable. Cables are either “High Speed” (1080p) or “Standard speed” (720p/1080i). If it is an HDMI 1.3 cable and can pass 1080p video, you don't need to buy new cables because you upgraded to an HDMI 1.4 AVR. For cable and switch needs consider forum sponsors
Monoprice and
Blue Jeans Cable where good quality "High Speed" 6' HDMI cables can be had for about $5 each. There's no reason to get ripped off buying overpriced Monster cables at Best Buy.
There's also no reason to pay more for an HDMI cable w/Ethernet as none of the current models can take advantage of the Ethernet feature in this cable.
c. Keep the box: The original Denon box the AVR comes in should be kept for the life of the AVR as it will be needed if the AVR has to be returned to the vendor you purchased it from or if it needs to be shipped to a repair facility for firmware updates or repair.
d. Older AVR w/o HDMI jacks: If you have an older generation AVR that lacks HDMI jacks and the only reason you want to upgrade to an HDMI AVR is to get the new HD codecs (DD TrueHD and DTS HD MA), then unless you want to spend more money, keep your old AVR as the lossy DD/DTS tracks on BD's are created at a higher bitrate (~640kbps vs. 430kbps) on a regular DVD. You will likely be hard pressed to discern any audio difference between these tracks and the HD audio tracks via HDMI.
e. USA/CA vs. Europe/Asia Pacific Models: Although the USA/CA and Europe/Asia Pacific models are very similar, there are some noted differences to include: (1) the Europe/Asia Pacific 1913 also includes a Source Select knob and Audyssey MultEQ XT whereas the USA/CA 1913 only uses MultEQ, (2) the Europe/Asia Pacific 2313/X3000 feature main zone 7.2 pre-outs whereas the USA/CA 2313CI/X3000 do not, (3) The USA/CA X1000 features Zone 2 pre-outs whereas the Europe/Asia Pacific X1000 does not, and (4) none of the "E" series are offered in Europe/Asia Pacific, rather they are replaced by the X500 instead. Also note there is a 2 digit code on the OEM shipping box with the model number that identifies the region of the AVR (eg. 1913 E3): EU or E3 = USA, EC = Canada, E1 = Asia, E2 = Europe, and EA = Australia.
f. Used/Demo/Open Box/Refurb: When purchasing an other than new in box unit (ie. demo/used/refurb), you'll want to reset the microprocessor before starting the setup process which will ensure all settings are returned to their original factory defaults.
7. Networking
a. Airplay: The Airplay feature (audio only) is offered on the 1613/E300 and higher networking models. It allows you to stream your iTunes songs wirelessly from your laptop, iPhone 3GS or newer (
will not work with iPhone 3G), or iPad to one of the above models when both are connected to your home network. This feature can also be replicated on non-networking model by using an Apple TV (audio and video) or Airport Express (audio) connected to the AVR. Also note that Apple currently has only licensed AVR mfr's to use Airplay in "audio only" mode (ie. no video). If you want to pass video, you'll to need to add the Apple TV (ATV). Note that in order to pass the ATV's optical audio to all of the 2012 Zone 2 AVRs (ie. 1713 and higher) as well as to the 2013 E400, you will also need to buy an optical to RCA analog converter similar to
this one as these models can only pass “analog” audio from externally connected sources to Zone 2.
A "wired" connection from the AVR to the router/modem is preferred to reduce connection issues and reduce audio dropouts due to buffering (eg. AVR front panel display reads “Buffering 60%). If you don't want a networking model, adding an Apple TV will give you Airplay, although there are noted issues with the ATV having audio dropouts regardless of the brand of AVR connection.
Some have noted that turning off bluetooth and closing background applications on your iphone, ipad, etc. will reduce/eliminate the Airplay audio dropouts. Also, if having connectivity issues, try unplugging the AVR for a few minutes and then power on again.
Notes: (1) When using Airplay,
the source controls the initial volume so make sure it is turned down on your laptop, iPhone, iPad, etc. before starting to stream the audio through your surround speakers. (2) If you want to turn the AVR ON to use Airplay, make sure IP CONTROL is set to ALWAYS ON (default setting on the 2013 models), and download one of the REMOTE apps listed in para 7(f) below. (3) In order to use Airplay with an Android phone, you can use the
doubleTwist app. (4) When selecting Airplay to play to Zone 2, the main zone will initially be hijacked and play the same Airplay source selected for Zone 2, although once playing in Zone 2, you can reselect the source that was playing in the main zone. Note that with the XX13 models you cannot turn the main zone off while Airplay is playing to Zone 2 while this is no longer the case with the new E/X models.
b. Connecting to a home network: None of the 2012 or 2013 models are "wireless" or include the capability of being wireless by adding a Wifi dongle/USB adapter. You must either connect the network capable AVR directly to a router/modem with an ethernet cable (recommended) or connect the AVR to a wireless bridge like
this one or
this one or
this one. The Airport Express can be setup as a wireless bridge as well as provides Airplay capability. If you're having problems with connecting with the Airport Express, disconnect the Airport Express from the AVR and connect it to a laptop and try to make that connection work first, turning off the wireless adapter in the laptop.
A couple of alternatives to a wireless bridge are: (1)
Powerline adapters that plug into nearby outlets that can then connect to your wireless router/modem which effectively turns your house wiring into a "wired" network, or (2)
Ethernet over coax MoCA adapters which use your existing coax cable used for your TV.
If you don't plan on using the network capability for other than firmware updates, 100' Cat 5/6 ethernet cables are fairly inexpensive and available from forum sponsor
Monoprice. You can also purchase 1000' Cat 5/6 bulk cable if longer length is required; however, note the maximum length without signal amplification is 100m or roughly 300'.
If you are experiencing intermittent audio dropouts while using the network streaming feature, consider connecting the AVR directly to the router rather than a wireless connection or consider upgrading to a newer, better quality router that is able to handle more bandwidth. Additionally, if you have a NETGEAR router which is causing problems, try disabling the UPnP mode. Also make sure that the router's SSID is not "hidden", nor should it have a blank (" ") in its’ name. If you are using a XFinity cable/modem, try setting it to "bridge" mode.
c. Firmware Updates: 2012 models: Click
here. 2013 models: Click
here.
d. Network Reset: 2012 models: Click
here.
e. NET/USB: When finished using the NET/USB input source, it's important to back all the way out of the menus otherwise the connection will remain open.
f. Remote Control Smartphone apps: The Denon REMOTE app is a FREE app that can be downloaded from the iTunes website
here and used by an iPhone, iPod touch or iPad to control the networking models from anywhere in the house (where wireless internet is available). For the more experienced iPhone/iPad remote users, you may want to try the iPhone GUI Design application,
Demopad . The Denon REMOTE app for Android phones is also FREE and can be downloaded
here. Android phone users can also download
AVR-Remote free as well which works on both Denon and Marantz AVRs.
A couple of other similar apps (fee required),
DenONOFF and
DeRemote can also be used on prior year models going back to XX08. Or if having audio/drop out issues using Airplay, consider using the
2Player android app. Make sure the Network Standby setting is set to ON in order to turn the AVR ON from Standby. If the remote app should suddenly stop working, try powering off the AVR and unplug it for a few minutes.
g. Rhapsody Smartphone apps: Rhapsody audio can be streamed to the AVR (w/monthly subscription) using either the
Rhapsody iPhone app or the
Rhapsody android phone app.
h. SiriusXM Smartphone apps: In addition to the on board SiriusXM capability on the networking models, you can also stream SiriusXM Internet Radio (w/monthly subscription) via either the
SiriusXM iPhone app or the
SiriusXM android app.
i. Spotify Smartphone apps: In addition to the on board Spotify capability on the networking models, Spotify mobile audio can be streamed to the AVR (w/monthly subscription) using either the
Spotify iPhone app or possibly the
Spotify android phone app. Using an iPhone, in Spotify, start a track, click the information sign and next to the volume, click the TV icon with an arrow in it to then select the Airplay speakers. If the Airplay icon fails to show up, try cycling the iPhone OFF then ON again. Using an android phone, you may need to read the following
article and may need to load Airfoil to a PC in order to get it to work. Note: If someone can confirm what is required to make this work with an Android phone, please PM me with the details. Another method to play Spotify is using the "
Spotimote" android app. Download the software to your PC running Spotify and connect the PC to an input on the AVR. Then download the app to your phone and you can control Spotify on the PC from your phone.
8. Purchasing Info
a. Best Buy/Magnolia: Best Buy is Denon's largest customer so you can generally find the full line of Denon AVRs at their stores, although specific models will be limited depending on whether there is a Magnolia in the store or not. Best Buy stores with no Magnolia will generally only sell the lower level models (E series) while those with a Magnolia will sell the mid level X models. Do you have Best Buy gift cards but would prefer to buy at one of the on line authorized resellers that offer a discount? There are several sights that will buy your gift cards at roughly 90% of face value including
CardCash. Although you will generally always pay full MSRP when purchasing the current year models at a Best Buy/Magnolia with a 10% discount for open box/demo units, the benefit of purchasing here is there is no restocking fee if returned within 15 days (longer if Rewards Member), regardless of whether it's defective or not, whereas the on-line authorized resellers that provide a discount will normally charge a 15-20% restocking fee plus require you to pay return shipping. Also note that Best Buy has some great deals when clearing out previous year's models so be sure to visit the store before considering a 2013 model to possibly get a higher 2012 model and still stay within your budget.
b. On-line Dealers: AVScience (877-823-4452) is an AVSForum sponsor and is an authorized Denon dealer, but is listed on Denon's store front authorized dealer webpage (as opposed to the on line dealer webpage).
c. Warranty: In order for the Denon warranty to be valid,
the AVR must be purchased from an authorized reseller, either
on-line or
B&M store. Although Amazon is an authorized reseller, that is only if they are the "seller" so check where it says "Ships from and sold by XXXX" to ensure the XXXX company is either Amazon or another Denon authorized reseller. Unless they are listed on Denon's website as an authorized reseller, the warranty may not be valid (ie. some vendors are not listed on the website but purchase from authorized resellers and therefore the warranty is still valid so call Denon if in doubt). If purchasing from an unauthorized reseller, you may want to purchase a 3rd party "Date of Purchase" warranty which is often times offered by the unauthorized vendors. In some cases the reseller will offer their own in house warranty.
Warranty period (when purchased from authorized reseller)
- New or demo or "open box": 2012 Non “CI” models and 2013 "E" Series - 2 years ; 2012 “CI” models and 2013 "X" series - 3 years
- Refurbished (any model) – 1 year
Notes:
(a) Denon has been known to extend the warranty period up to 45 days beyond normal expiration.
(b) If your unit requires service and the service center cannot repair/return it within 30 days, the repair facility "should" offer a refurbished unit if available. If you accept the refurbished unit, rather than wait, your warranty on the refurbished unit would be the time remaining from the original new unit purchase.
(c) Buying refurbished units can be a good way to save some money, although receiving a defective "refurbished" unit is not uncommon. There's also no guarantee that the refurbished unit will have any updated firmware installed. In some cases you can get a brand new, fully warrantied unit from one of the authorized resellers (eg. AV Science) for a price comparable to the refurbished unit when taking into account the cost to purchase an extended warranty.
(d) "Open box" deals from an authorized dealer will generally come with a full mfr's warranty (although note that Amazon Warehouse deals are no longer warrantied by Denon at all). In general these can be great deals as often times the previous buyer simply didn't understand how to set up the AVR (and obviously didn't know about AVS forum) and so there's often nothing wrong with the AVR. Check to make sure you have all the included accessories, although if the mic is missing, you can generally buy one off of eBay (ACM1HB - US distributors only) or from Denon directly for about $25.
(e) Some credit card issuers will add an additional year to the mfr's warranty (new or refurbished), so before you give up on your old AVR, or consider adding to the Denon warranty with a 3rd party warranty (eg. SquareTrade), if you purchased with a credit card, check to see if they offer a free Extended Warranty benefit. Note that although Accessories4Less (refurbs) currently does not accept AMEX, you can purchase using Pay Pal with an AMEX card attached which would still qualify for the 1 year additional warranty.
(f) Denon has changed the return policy when purchasing a refurb from Accessories4Less (AC4L). Rather than returning the refurb to AC4L, you will contact Denon directly to troubleshoot the issue and if still no joy, you will deal with Denon directly for an exchange/return. Often time’s returns are not warranted, rather simply the new owner not understanding how to setup the AVR.
a. 12v Trigger: When connecting a trigger jack to an external device that also has a trigger jack, use a 1/8" to 1/8"
Mono cable like
this one to connect the AVR to the device you want to trigger (eg. external amp, projection screen, lights, etc.). Although triggers are more sophisticated than switched outlets, the simple ON/OFF feature of a trigger can be replicated using a
smart power strip (although note this particular model doesn't work with all AVRs) rather than getting the 2313CI/X3000 (1 trigger) or 3313CI/X4000 (2 triggers). If you are using an external amp that goes to Standby when powered back on (eg. Emotiva), consider using this
trigger switch from Emotiva along with the smart power strip.
b. IR Extender/Repeater Kit: An IR extender/repeater kit can be used to extend the IR signal of the Denon remote when the AVR is located in a closet or other room.
There are numerous 3rd party kits on the market which will include a powered "blaster" and a receiver, although not all may work with your model so before buying, ask the reseller if it's been tested with your model. The powered "blaster" will have either a single or multiple wired emitters connected to it (generally with no more than 6' wire) that are placed over the IR sensor on the front panel of each device you want to control and as such,
can be used with ANY Denon AVR model. The receiver is then placed in the room in which you will be using the remote control.
Some kits cannot be used in close proximity to a LCD or plasma TV and others have limited range so be sure to read the fine print before buying one of these kits. On Denon AVRs the IR sensor is located about 1/3 from the left side of the front panel display (see picture in your Owner's manual). The "CI" and "X" series models include a Remote Control IR IN jack which can provide a cleaner connection in the rear panel of the AVR rather than having to place an emitter over the IR sensor on the front panel display. If you have a CI/X model and would prefer to use the Remote Control IN jack, there are kits that use a 3.5mm plug instead of an emitter or AFAIK, you can simply replace the emitter with a 3.5mm mono-to-mono cable. Google "IR extender kit" or "IR repeater kit" and ensure you read the fine print to get a model that is appropriate for your particular requirements. Also make sure it is returnable if it doesn't work correctly.
c. Switched Outlets: Denon AVRs no longer include switched outlets; however, they can be easily replicated by using a smart power strip like
this one or
this one. Also, as a reminder, when using an AVR with switched outlets, never plug the subwoofer into them as they are not designed for a high amperage device like a subwoofer.
d. Turntable/Phono: Although the 3313CI and X4000 are the only models with a Phono input, you can connect a turntable to any model using a phono pre-amp similar to
this one (if one is not built in to the turntable). Simply connect the pre-amp to any of the analog inputs on the AVR.
a. Dual subwoofers: If you have 2 (or more) subs that you want to connect, but don't need the features offered in the 2313CI/3313CI or X3000/X4000 (all of which have 2 sub pre-out jacks), simply pick up a
RCA "Y" splitter at Monoprice (or Radio Shack or Walmart) and connect it to the single sub preout on the 2113CI/X2000 or lower models and you'll create the same result. The 2313CI, 3313CI, and X3000 simply use an internal "Y" splitter. Note that on the X4000 only, the sub pre-outs are used separately for each sub by the Sub EQ HT feature to level match and set the delay for each sub independently.
b. Front Height / DSX Wide minimum requirements: To add either PLIIz (Front Height) speakers or DSX (height/wide) speakers you will need a minimum of a 5.0 setup (FL/C/FR/SL/SR).
c. Minimum number of speakers: All models can run with a minimum of 2 speakers up to 5 (or 9) depending on the model. Audyssey will work just as well with 2 speakers as it will with up to and including 9 speakers.
d. Speaker Recommendation: When considering speakers, the general rule of thumb for a good 5.1 setup is to budget at least 2x the cost of the AVR (ie. $500 AVR -> $1000+ 5.1 speaker setup), the bottom line is you're much better served with a lower quality AVR and better quality speakers, then a higher level AVR and lower quality speakers. If you're considering one of the lower level models (or your budget is < $500 for speakers), a good setup is either the
Energy Take 5.1 Classic ,
Klipsch HDT 300 5.1,
Jamo 5.1, or the
Fluance 5.0 (so you'll need to add a sub). If you don't mind spending some time in the used market (eg. Craigslist), you can sometimes find a $1000-$1500 5.1 original MSRP setup for $500 or less.
Although Denon AVRs are designed to work with 6-8Ω speakers, you can generally safely use 4Ω speakers if the volume is limited to average listening volume only (ie. max volume roughly -20db). However, it's generally better to stick with 8Ω speakers unless using the 3313CI/X4000 in which case you can add an external amp if necessary. Review
this post for more information on the impact of speaker efficiency. Bottom line is that going from speakers rated at 86db efficiency to 89db efficiency is like going from a 75W AVR to a 150W AVR so
look for more efficient speakers rather than a higher powered AVR. Ideally you would want to demo different speakers at a Best Buy/Magnolia or other Hi Fi shop, keeping in mind these stores generally do not run the AVRs EQ program (eg. Audyssey) so if you like their sound in the store, they'll likely sound even better when in your home after running Audyssey Setup. If you are just starting to build your speaker setup, it's better to have better quality front three speakers L/C/R and sub and hold off on the surround speakers until you can afford them. If TV and movies will make up the majority of your audio listening, you'll ideally want the center speaker to be of the same (or better) quality than your front L/R speakers as 80%+ of the dialogue will come from the center speaker.
If you have a 5.1 surround setup from a HTIB that you want to use with your new AVR ... DON’T, at least not without checking what impedance the speakers are rated. More often than not, HTIB speakers are generally only 2-4Ω speakers designed to work only with the receiver that came with the HTIB and in some cases have special wire connectors. If they are 6Ω or 8Ω speakers (as is the case with Denon Boston Acoustics setups), you're good to go, otherwise, sell the HTIB speaker setup on Craigslist or eBay and buy a stand-alone 8Ω speaker setup. Also, ideally stay away from Bose speaker systems as they generally don't work well with Audyssey due to having to be connected to the Bose Acoustimass module first so the AVR never sees the sub.
e. Speaker/Subwoofer Volume: Press the SETUP button on the remote and change the speaker levels in the Manual Setup menu. These adjustments can be made without impacting the Audyssey filters. However, before making adjustments to the sub (esp. increasing the volume), try leaving it at the current setting (after running Audyssey Setup) for at least 2-3 weeks to adjust to the "reference" setting the mixer intended rather than the boomy bass many are used to hearing from older model receivers. If after that time, you still feel you want the sub volume louder, then bump it up a few db using the AVR menu to suit your "preference."
f. Speaker Wire: For speaker wire runs up to 80', a 16AWG wire will be sufficient. Longer runs should use 14AWG wire. A good place to buy speaker wire is from forum sponsor Monoprice.
g. Subwoofer - Best location: To learn more about the best place in your room to place your subwoofer, follow the
h. Subwoofer - Cable option: If you don't have a digital coax cable handy to connect the sub preout on the AVR to the sub, you can use the "yellow" composite video cable as a suitable substitute.
i. Surround Speaker Placement/Wire Connections: With a 5.0 or 5.1 setup, the surround speakers are considered "side" surrounds and should be connected to the speaker posts labeled "Surround" and ideally be placed about 2'-3' above seated ear height and within 90-110 degrees from the main listening position (ie. to the "sides" of the main listening position and NOT the rear). When you add a 2nd set of surrounds in a 7.0 or 7.1 setup, or "rear" surrounds, they should be connected to the "Surr Back/Amp Assign" speaker posts and also ideally placed about 2'-3' above seated ear height and about 3' directly behind the main listening position. See the Dolby Digital website
here for more information. Note: If you only have a 5.0/5.1 setup and the surround speakers are already wired in the rear, then you must still connect those speakers to the "side" SURROUND speaker posts as this is the proper setup for a 5.0/5.1 setup. If you want to connect Front Heights or Front B speakers, you would also connect these speakers to the Surr Back/Amp Assign speaker posts as well (except with the 3313CI or X4000) and set the AMP ASSIGN setting accordingly.
j. Tower Speakers w/built in subwoofer: When using this type of speaker (eg. Def Tech) and no external sub, connect the LFE cable from the AVR sub preout to a "Y" splitter and then to each sub. After running Audyssey Setup, you will still want to set the front mains to SMALL (regardless of what the mfr's speaker manual recommends) as there are 8x (MultEQ XT) and 64x (MultEQ) more Audyssey sub filters than speaker filters. This configuration will also then allow you to adjust the sub channel volume to suit your preference. Note with XT32, there are an equivalent number of speaker and sub control points, so without a dedicated sub in the setup, you can go either way with either a LARGE or SMALL setting.
11. Troubleshooting
a. Airplay icon not showing up If the Airplay icon is no longer displayed, try one or more of the following steps to resolve the issue:
- Set the AVR to Standby and unplug it for 10 minutes. Then plug back in and turn on again. You may need to do this several times.
- If using an iPhone or HTPC, try cycling it OFF/ON/OFF/ON while it's connected to the network.
- Close/Open iTunes a few times.
- Power cycle the router, wireless bridge, or Powerline adapters OFF/ON/OFF/ON.
- If your router has a "multicast" option, try setting it to YES.
- Cycle DHCP OFF/ON/OFF/ON.
- Assign the AVR with a static IP address of its own. Turn off DHCP and select an IP address out of the normal range (1-100, eg. 192.168.1.101 ) and then leave the subnet address that's there. Give it a few minutes after you type it in and you should see the icon pop up on your device.
- If using a Verizon Actiontec router .... on the router, go to the Advanced tab (accept the warning) and go to the IGMP Proxy menu and disable "IGMP Proxy" which should resolve the issue. On newer Actiontec routers, if you don't see the IGMP setting, but do see a "Routing" setting, then select Routing/Routing Protocols/IGMP and disable "IGMP Proxy" there. Another setting which has been shown to work is to enable the setting just above the setting on the main Advanced menu. The issue here generally only presents when the AVR is wired directly to the Actiontec router and the iDevice is connected wirelessly. Note however, that if streaming IPTV, disabling this proxy will also disable the IPTV connection, so in that case you'll need to leave IGMP enabled and place an ethernet switch between the Actiontec and the rest of the network.
Regardless of the type router being used, if there is a "Disable IGMP Proxy" setting that is checked, try unchecking it and see if that resolves the issue. Otherwise, try toggling the "IGMP Proxy" setting ON/OFF/ON.
b. “Airplay Speaker Not Available”:This issue may be a result of not turning OFF the NET/USB source on the AVR (as opposed to just changing inputs). When you are finished with the Airplay audio, press/hold the remote ENTER button. Another solution is to uncheck the Airplay symbol on the iPhone/iPad (putting it on the iphone/iPad speaker and thus breaking the handshake). This issue has also known to present when changing the "Video - Audio Display - Audio" from the factory default of "30s" to "Always", so change it back to "30s".
c. AVR randomly changes to other sources: This may indicate a defective HDMI board. If you have Network Standby/IP Control set to ON, try setting it to OFF as this has resolved the issue for some owners. The final option would be to reset the microprocessor as listed in your Owner's manual and if still no joy, then give Denon a call to have it repaired.
d. AVR shuts down at higher volumes: A good rule of thumb is to not raise the master volume above 0db (relative) or 82 (absolute) as it may result in clipping/distortion from the speakers. You can set the "Volume Limit" setting to 0db to ensure this doesn't happen. If the AVR is shutting down at volumes lower than 0db (eg. -10db) then it is most likely the result of a loose speaker wire from one post on the back of the AVR touching another post so verify all speaker connections are clean. Pull the AVR out of the cabinet or rack if you have to in order to visually check the rear panel as more than one owner has learned a cursory look with a flash light may not be good enough to see the single wire strand that is causing the problem.
e. AVR switches to TV source when first turned ON: This occurs because you have the HDMI-CEC/ARC feature on your TV set to ON as well as HDMI Control on the AVR set to ON. There are several work-arounds to prevent this from happening depending on whether you:
want to pass audio from the TV back to the AVR:
- Only set ARC to ON when you want to actually use that feature, or
- Connect an optical cable from the TV to the AVR and don't use the ARC feature which will result in the same level of audio quality;
Or,
don't want to pass audio back to the AVR but do want to use the HDMI Control feature to turn the TV ON/OFF with the AVR:
- Use the Hide Sources feature (except 1513/E200) to delete/hide the TV/TV Audio source, or
- If using a universal/programmable remote, insert a long delay (eg. 10 secs) after the AVR is turned ON, and then program the remote to select the actual source device you want to use.
f. Cannot see networked Denon on my computer/laptop: Try doing the following: Go to "control panel"..."my computer"... "my network places"..."show icons for networked upnp devices." If using a Verizon Actiontec router .... on the router, go to Advanced (accept the warning) and go to the IGMP Proxy menu and disable IGMP Proxy which should resolve the issue. Note however, that if streaming IPTV, disabling this proxy will also disable the IPTV connection, so in that case you'll need to leave IGMP enabled and place an Ethernet switch between the Actiontec and the rest of the network.
g. Center Channel dialog too weak watching TV: Adjust the Dynamic EQ "Reference Offset" setting from 0 to 10db. You can also try increasing the center channel volume by adjusting the Center Dialogue setting. Setting Dynamic Volume to ON(Evening/Medium) will also help to improve lower level dialogue. And lastly, another option is to use the "Multi CH Stereo" mode which will add the dialog to the surround speakers bringing it closer to your main listening position.
h. "Connection failed. Check the device": This error occurs with the networking models when the AVR is unable to connect to the home internet router/modem. Place the AVR in Standby and unplug for a few minutes. Reset the router or connect directly to the router if connecting wirelessly. You also may want to consider replacing the router if it is more than several years old with one that is capable of handling higher bandwidth. If you are using an Apple device, make sure that "Home Sharing" is turned ON (as it may have been turned OFF by updating the firmware/iOS). If you use a NETGEAR router, try disabling the UPnP mode. If the SSID of your router contains a "space", rename the router without the space.
i. Green screen on TV: This is usually the result of either a bad HDMI cable or HDMI handshake issue with the TV. Try replacing the HDMI cables with "High Speed" (1080p) cables. Also try the HDMI Handshake resolution tips listed in item (k) below. If after doing the suggested tips, you are still seeing a green screen, give Denon a call as there may be an issue with the AVR's HDMI board.
j. HD Channel (DD 5.1) in Stereo: Sometimes when a TV station indicates the HD show is in DD 5.1, they will only broadcast a stereo signal but do it over a 5.1 audio track with blank channels so although the front panel display will say Dolby Digital you will only hear audio from your front L/R speakers. And because it is detected as DD 5.1, you cannot use a simulation mode (eg. DD PLII) to simulate 5.1 audio. Note also that not all HD channels are broadcast using DD 5.1 audio and even those that are advertised as DD 5.1, the station may only broadcast stereo 2.0.
k. HDMI Handshake Issues (audio/video dropouts): Handshake issues will most often present as "audio dropouts" or sometimes video display issues. Ensure the source device having the issue has the latest firmware installed and has been reset (ie. powered down, unplugged for a few minutes, then powered back ON again). For a more detailed HDMI reset try the following procedure ....
- HDMI HDCP reset
- With all devices powered on, remove the two HDMI cables at both ends from the source device to the AVR and from the AVR to the TV.
- Power off all devices and disconnect power cables to all devices.
- Wait 10-15 minutes.
- Reconnect HDMI and power cables to all devices.
- Power on the devices in this order ... TV, wait a few secs, AVR, wait a few secs, and then source device (although this is the generally recommended order, in some instances, you may have better luck powering on the AVR first and then the TV, then the source last ... bottom line if it's still not working, try a different power on sequence).
If the issue only involves the cable/sat box, HDMI handshake issues with cable/sat boxes are quite common (with any brand of AVR) and are usually always the fault of the cable/sat box not being designed to be connected to an HDMI repeater (ie. AVR) which is why they work without issue connected directly to the TV. Give your cable/sat box provider a call to see if there is a separate firmware update that can be applied to the box to resolve the issue although note that in some cases, a future firmware update to the cable/sat box may very well cause an HDMI handshake issue as well, so your best option to avoid the issue now (or in the future) is to connect the cable/sat box HDMI directly to the TV and also connect an optical cable from the cable/sat box to the AVR for surround audio. If you don't have an optical cable available, and your cable/sat box has a coax digital "orange" output, you can also use a coax digital cable (note: a "yellow" composite video RCA cable is a suitable substitute) and connect it to the SAT/CBL coax digital input on the AVR (ie. right next to the optical jack). Note that with this configuration (ie. HDMI straight to TV) you will lose the GUI/status menu for the cable/sat box, but you retain the capability to watch TV using the TV speakers only with the AVR in Standby (eg. news, sports, wife, kids). Another option, if your AVR features a component video input is to connect both a component video cable and an optical (or digital coax) cable from the cable/sat box to the AVR noting that although you gain the GUI/status menu feature, you will lose the capability to watch TV using the TV speakers only. You may also want to try upgrading to a different model cable/sat box.
Other possible solutions:
- Try inserting an HDMI switch in between the AVR and the TV.
- Ensure there is proper ventilation around the AVR (at least 3-4" above the unit) and if enclosed in a cabinet, use a PC fan to exhaust the heated air out the back of the cabinet
- HDMI performance can also vary between the different HDMI input jacks due to quirks of circuit board design so be sure to try each of the other HDMI inputs as one may work better than another
- With the 1913 and higher XX13 models, A400, X2000 and higher models, if you are having a video issue, try setting the "Resolution" setting to the resolution of the TV(eg. 1080p) rather than using the "Auto" setting.
- Try inserting the Dr. HDMI between the AVR and the TV/PJ.
l. HTPC won't pass audio/video: HTPC connections can be "iffy" at best. If you are having problems trying to connect your HTPC to the AVR, ensure the HDMI port on the HTPC is selected for audio/video output and that the latest firmware is installed on the HTPC video card or try a different video card if one is available. Try each of the HDMI inputs on the AVR (especially the one closest to the HDMI Monitor Out jack) as well as ensuring the HTPC is set to a standard TV resolution rather than the default resolution of the HTPC's display. If using a 6' HDMI cable, try using a longer HDMI cable (12'+) as this has been known to work in some instances. The issue likely involves incorrect EDID information being passed to the HTPC video card from jhe AVR. Refer to
this post and
this post both of which discuss an
EDID Override procedure. Sometimes simply placing an HDMI switch/splitter between the HTPC and the AVR will work. If you are having problems using Windows Media Player then try using
TVersity. If you are having problems playing .flac files, try using
ffdshow. Sometimes connecting a
Gefen HDMI Detective between the HTPC and the AVR has been known to resolve the EDID issues. The HDMI Detective also works well with DVI TV's that are having EDID issues. If you are trying to connect to a Panasonic plasma, and getting the 10 red blinking light on the Panny, check out
this post for several solutions.
NVIDIA video card owners: Try the following: Bring up the NVIDIA control panel. For display options, select the AVR (not the HTPC display). AVR->Adjust desktop color settings->Apply the following enhancements->Content type reported to the display->Full-screen video (vice the default of AUTO).
If the HTPC is having issues reconnecting after coming out of "sleep" mode, then refer to this
ATI solution or this
NVIDIA solution for more info to resolve the issue.
Another option is to set the “Video Mode" setting to either "MOVIE" or "GAME" vice "AUTO."
m. Intermittent HDMI audio/video: Other than the possibility of an HDMI handshake, try connecting the HDMI cable to each of the other inputs on the AVR to determine if one HDMI jack works better for you with that input (previous year's models have shown that HDMI1 and HDMI2 react differently than the other inputs). Also try all the HDMI inputs on your TV as well as ensuring there is a tight, secure connection at both ends of the HDMI cable as sometimes the cable can just be loose. Note that just because the HDMI cable works when connected directly to the TV, doesn't necessarily mean it will work when connected to the AVR. When in doubt, try another HDMI cable that is confirmed to work with the AVR. You may also want to try inserting an HDMI switch between the AVR and the TV.
n. No audio from single speaker: If there is no audio coming from a single speaker, try swapping the speaker with another speaker to ensure it works. If it works, it's not the speaker. Place it back in its’ original location. Unhook the speaker wire at the AVR posts and connect it to a AA battery (+/+ and then tap the - to the -). If you hear static at the speaker, then there is no short in the wire itself and the issue is with the AVR channel. Try resetting the microprocessor as noted in post
#5 to see if that resolves the issue. If not, time to call Denon or your local authorized repair facility.
o. No Video on AVR front panel display: If you suddenly find no video being displayed on the front panel display, check to see that the PURE button on the remote wasn't pressed and changed the surround mode to PURE DIRECT which turns off the front panel display. Also check to make sure all your cable connections are securely inserted into their jacks as kids, cats, and cleaning folks have a habit of getting to the back panels and can accidently loosen the connection.
p. Projector - no video displayed: If you are running an HDMI cable from the AVR to a projector that is longer than 20' and it won't pass 1080p video but will pass 720p, then the signal is too weak. Test this by using a shorter cable to the PJ. HDMI generally only works to about 15'-20' without issues, although some owners have indicated with a Monoprice 50' HDMI cable they have no issues. Monoprice also now sells
“active” HDMI cables. . If replacing the cable is not possible, you'll likely want to try a powered HDMI extender. Check Monoprice as there are several models offered. For those of you using HDMI--> CAT 5/6 converters, and having video display issues, you may want to try using this
HDMI voltage enhancer.
q. PS3/Blu Ray Player (BDP)/Game machine - No video or intermittent video issue: On the PS3 or Blu Ray player, set the "Deep Color Output" setting to OFF. Ensure the game machine is set to a standard TV resolution otherwise the AVR won't recognize the signal. Additionally, on the xBox, try turning off “auto-detect display settings” and forcing the display settings to match the TV.
r. Speaker volume change won't stick: When you make individual speaker/sub volume changes, the changes are global and will apply to all inputs unless you use a Quick Select for that particular input. After making the channel volume change, make sure to re-memorize the Quick Select button by pressing/holding the button for a few seconds until MEMORIZE is displayed.
s. Subwoofer not working: If there is no audio coming from the sub, it could be the sub is dead, the sub's power cord isn't plugged in and the sub powered ON, the sub coax digital cable is bad, there is an issue with the AVR sub preout, or the AVR's speaker settings are incorrect. First make sure the sub is plugged in and powered ON. Remove the cable from the AVR sub preout jack and rub your finger over the connector tip. You should hear some static from the sub. If not, replace the cable with another cable (use a "yellow" composite video cable to test with) and try again. If still no noise from the sub, then you may have a busted sub. Otherwise if there is noise from the sub, the issue is with the AVR. Make sure that all speakers are set to SMALL (Manual Setup as well as 2CH Direct/Stereo custom settings if your model has this feature) with no lower than 80hz crossovers which will then pass all audio below 80hz to the sub. If you have your front speakers set to LARGE and the sub set to LFE, then although the sub will play the low bass in the 0.1 (LFE) channel during DD/DTS 5.1 movies, it will not play the low bass in stereo (2.0) music unless you change the sub setting to LFE+Main, although the issue with no bass during music is alleviated if the front mains are set to SMALL w/80hz crossovers as is suggested after running Audyssey Setup.
t. Surround mode changes: You change the surround mode for SD channels from stereo to DD PLII - Cinema but it changes back to stereo the next time you turn on the AVR. The most common cause for this is that you are using a Quick Select button to select the source and didn't re-memorize the new surround setting to the Quick Select by pressing/holding the QS button for 3-4 seconds after making the change. Otherwise, the Personal Memory Plus feature of the AVR will remember the setting and use that same setting the next time that source signal is received.
u. Unresolved Issues: If you are experiencing an issue with your AVR that is not listed in post
#4 of either the 2012 or 2013 Denon AVR threads, and for which you cannot get a resolution either by (a) reviewing the information in this thread, (b) unplugging the AVR for a few minutes, (c) resetting the source device, (d) ensuring the source device has the firmware updated (if possible), (e) ensuring the AVR has it's firmware updated (if a networking model), (f) resetting the microprocessor using the procedure in your Owner’s manual, or (g) posting the issue in this thread, then call Denon CSR at 800-497-8921 and report the issue.
If you have not reported it to Denon yourself personally, don't assume that Denon is aware of the issue. If the CSR response is "I've never heard of your issue before," ask the CSR if they can test it out on one of their units there and call you back. If they don't comply, go to Denon's website
here, review their FAQ and if still no resolution, then register, and submit your issue with the AVR as well as the response provided by the Denon CSR via the "Ask A Question" tab. Regardless of how you submit your question, if you receive a response from Denon that resolves your issue, please post Denon's response here in the thread so others might learn from it as well.
v. Volume drops randomly from AT&T U-verse box: Setting Audyssey Dynamic Vol to OFF for the AT&T U-Verse source input should resolve this issue, otherwise you can bypass the AVR with HDMI from the box to the TV and optical from the box to the AVR.
w. White sparkles on TV: If you see white sparkles (ie. snow) displayed on the HDTV when the source is connected via HDMI, this may be a sign the HDMI cable is defective. Before replacing the cable; however, try powering on your equipment in this order: TV, AVR, source device and see if that resolves the issue. If not, you can find inexpensive High Speed (1080p) or Standard (720p/1080i) replacement cables at forum sponsor
Monoprice. If it's happening with your Blu Ray player only, try setting
Deep Color Output to OFF. Some LG BDP's output in Deep Color and don't have a setting to turn it OFF. If you are having issues with it, you may want to consider changing to another brand of BDP.
x. Why do my small speakers get set to LARGE?: The AVR will set any speaker to LARGE if it detects it can handle frequencies < 50hz in your room (regardless of what they are rated for on paper). If there is no sub in your setup, the front mains must default to LARGE, otherwise if there is a sub, then manually set the speaker to SMALL with at least a 60hz or 80hz crossover. For more information on bass management and the LARGE/SMALL settings refer to
this article.
y. Why "Multi Ch In" and not Dolby TrueHD/DTS MA HD?: This is because your Blu Ray player is set to "PCM" and so it is decoding/uncompressing the audio to PCM. If you want the AVR to do it (won't matter audio quality wise which one decodes it) so you can see the compressed audio track on the AVR's front panel display then set the Blu Ray player to "bitstream" with either the Secondary Audio or BD Audio Mix set to OFF.
z. Why only "STEREO" or "PLII" and not DD TrueHD/DTS HD MA?: This is because you likely had your Blu Ray player or PS3 connected directly to your TV (prior to adding the AVR) which could only receive a stereo signal. Reset the BDP/PS3 while connected to the AVR so it will pass a multi-channel signal (also see above para (x)). For the PS3, press/hold the Power ON button longer than usual until you hear a series of beeps which will reconfigure it to the AVR. Refer to your BDP or game box owner's manuals on how to reset them to pass multi-channel audio.
z1. Wii only displays in 4:3 aspect: If you have a 1713 or lower model (ie. no video card), there is no ASPECT setting, so regardless of what you have the Wii set to, it will only display to 16:9 if you change your TV setting from "AUTO" to "Fullscreen" (or whatever the setting is to expand 4:3 content to 16:9). Note that any other picture display/format changes must also be made using the TV as there are no video display setting changes on the 1513/1613/1713 and E200/E300/X1000 models.
z2. WIN 7/8 PC shows up as "Not Authorized": On the AVR, set DHCP to OFF, then put in a manual address for the router and set DHCP back to ON. Also check Control Panel --> Network and Internet --> View Network Computers and Devices --> Denon AVR-XXXX .... change setting from "Blocked" to "Allowed."
z3. Windows Media Player (WMP 11/12) audio files won't play from PC via wireless network: If you have an extremely large media library which includes artwork with the files and some of the files are not playing on the AVR, try using
MediaMonkey to strip/hide the artwork from the AVR. First when adding the library to MediaMonkey, you have to go to tools\\options\\library and uncheck “scan file directory for artwork”. After the transfer you still have the artwork for every single song embedded in the tag. You can easily remove that by hitting the right button over the picture and after choosing “remove image” also check the option “remove image from all the tracks in the album”. Doing so should then allow you to play the album wirelessly to the AVR. Removing the artwork can be done with the FREE version, although review the website for the benefits of using the Gold version if additional capabilities are needed.
12. Zone 2
a. 2-CH Amp: The 1713, “CI”, and "X" models each have Zone 2 pre-outs (the 3313CI/X4000 also have Zone 3 pre-outs) which can be used to connect a red/white RCA cable to an external amp if you want to run a 7.1 setup in the main zone plus Zone 2 and/or Zone 3 speakers, otherwise, if you only want to run a 5.1 setup, you can use the Surr Back/Amp Assign speaker posts to power the Zone 2 speakers (7.1 models only). You can generally find used 2CH amps on Craigslist for ~$50 or you can buy
this one or
this one new. You can also use another AVR as well by connecting the RCA cable to one of the 2nd AVR's stereo analog inputs and connecting the Zone 2 speakers to the FL/FR speaker posts on the Zone 2 AVR.
b. Source Limitations:
2012 Models: No 2012 model can pass HDMI audio to Zone 2 (except 3313CI using the Zone 2 (HDMI) monitor out jack). The 2012 networking models will only pass Airplay, Pandora, Spotify, internet radio, USB, and external “analog” sources to Zone 2,
but cannot pass HDMI or other “external” digital audio sources connected to the AVR to Zone 2. This limitation is common to the vast majority (98%) of all AVRs on the market today. It applies whether you're using the powered Surr Back/Amp Assign speaker posts or the Zone 2 pre-out jacks to an external amp. So for example, if you want to connect an Apple TV and have the audio play in the main zone and Zone 2, in addition to the HDMI cable you would also have to connect an optical cable to pass audio to Zone 2 using an
optical --> analog converter.
2013 Models: Depending on the model, the new 2013 Zone 2 E/X models have up to two ways to pass HDMI audio to Zone 2. The E400 and all "X" models feature an "All Zone Stereo" feature that can pass the same stereo HDMI audio playing in the main zone to the Zone 2 Amp Assign speaker posts or Zone 2 pre-outs. Additionally the X3000/X4000 models are able to pass the same or an independent HDMI1-6 (rear panel only) audio source to the Zone 2 (HDMI) monitor out jack (note that when the same HDMI source is selected for both main and Zone 2, the main zone will be down mixed to the lowest common denominator of the two TVs connected to the monitor outputs even with Zone 2 set to OFF such that if the Zone 2 TV can only process a stereo 2.0 signal, the main zone will be down mixed to stereo as well). The X3000/X4000 are also able to pass an independent HDMI, optical, or coax digital PCM 2.0 signal to the Zone 2 speaker posts or Zone 2 pre-outs such that another source can be selected in the main zone.
A work around if you want to pass ANY source (HDMI, digital, analog) to another room using a 7.1 2012 model is to use the "Amp Assign - Front B" setting with the understanding that the Front B speakers can only play the same source as is playing on the Front A speakers and the volume of the Front B speakers will be controlled by the volume of the Front A speakers. The 2012 "CI" models have separate 2CH STEREO settings, so if you prefer not to use the STEREO mode in the main zone, you can setup a "custom" STEREO setting using the Front B speakers only (ie. Front B speakers set to LARGE and no subwoofer playing) to get audio only in the room with the Front B speakers whenever you use the remote to change to STEREO mode. If you want an independent source and volume control for Zone 2 (other than Airplay - see Networking - Airplay), you will have to use the "Amp Assign - Zone 2" setting.
c. Whole House Audio: If you have a 7.1 Zone 2 model (1913 or higher/X2000 or higher) and want to send the "same" audio to more than just one zone/room, you can connect a multi zone impedance matching speaker selector (eg.
4 zone speaker selector) to the Surr Back/Amp Assign speaker posts. If adding more than 2 additional rooms; however, you will want to consider an AVR model that has Zone 2 pre-outs so that a separate 2CH amp can run the whole house speakers. You would then connect the speaker selector between the speakers and the external amp. For more information on whole house audio setups, review
this website.
d. Wireless Headphones: One advantage of having a model with Zone 2 pre-outs (ie. “CI” or "X" model), is that you can connect a set of analog wireless headphones (eg. Sennheiser) and listen to music elsewhere in the house while someone is watching a movie or playing a game in the main zone (noting the Zone 2 limitations listed above).
Disclaimer: All information posted above is believed to be accurate. If you find that to not be the case, please PM me with the corrected information to include links which may no longer work. Also if you have any other 3rd party product recommendations please PM with that information as well.
