AVS › AVS Forum › Audio › Speakers › Making CMT-340 SE Look good
post #1 of 27
Hi Im new to the forum and super noob.
Ive been doing lots of research on what speakers to buy. I recently bought a SC-1522-k and am now looking for some speakers.
I'm want to start with Ascend CMT-340 SE L/R/C and will later add a sub and rears.
I showed pictures of the speakers to my wife but she is not convinced floorstanding towers will look good.
I showed her this picture and she isnt happy.
Do any members here have pictures of a nice HT setup that would convince my wife to let me buy them?
Also, has anyone mounted the CMT-340 to the wall? Im not sure how achievable this is. And Im curious to see how such a setup would look.
Or are there any other better looking speaker alternatives that will achieve similar quality at similar budget?
Thanks in advance
post #2 of 27
The CMT-340 SE are rear ported so that is a challenge for wall mounting. Not sure that it would be recommended.
Those speakers didn't pass the WAF test for me... So instead I bought some B&W 683's. I am very happy with my purchase.
post #3 of 27
post #4 of 27
Or just show her some Revel Salon2's or something like that.....and look surprised when they show up lol.biggrin.gif
post #5 of 27
You know that's not a picture of 340's except for the center, right? It's a fairly large speaker so you might need to build a shelf or something or drill your own mounting gear into the speaker since it doesn't come with any. You can get the 340 in a nicer custom finish but you may as well get one of their better speakers that already come in a nicer finish at a better price.
post #6 of 27
ousooner,
I didnt realize ascend also has those types of stands:
http://www.ascendacoustics.com/pages/products/access/spkstnds/sp30stands.html
Ill see if my wife likes those ones better. thanks for showing that.
Mounting is still an option, but id have to have a good 6 -8 inches of clearing off the wall and Im not sure how far some of these mounts push the speakers out.
A shelf may be possible but something tells me it would look awkward with such a long speakers.
I could probably mount the CBM-170 to the wall.
Im curious with a good sub how much am I really losing by swapping CMT-340s with CBM-170s
post #7 of 27
Thanks in advance
Hi aamirnshah,
Those left/right speakers in the picture do indeed look like our CBM-170SE speakers, not our CMT-340SE. I am also not sure what stands those are.
If you do not like our TP-24 stands for the 340's, check out the Sanus SF-22 stands. http://www.amazon.com/Sanus-Systems-Foundations-Bookshelf-Speakers/dp/B004STEH08/ref=sr_1_2?s=electronics&ie=UTF8&qid=1364451011&sr=1-2
post #8 of 27
340 give you more dynamics and can give you "crisper" highs and deeper bass. They are specifically designed for "wide disbursement"... That being said the 170's will probably work fine...but your not gaining a ton of WAF. Now Ascend Sierra and Aperion Veres are works of art...just pretty to look at and listen to.
I didnt have to contend with WAF so the 170SE wall mounted work prefect fer me.
post #9 of 27
It should work fine, in my opinion (and in my experience with the CBM-170 SE), provided that you could find a mount that could support it. I'm pretty sure that this one could, as long as you don't tilt the speakers much:
http://www.amazon.com/VideoSecu-Clamping-Mounting-Surrounding-MS56B/dp/B000X9O8SI
post #10 of 27
I have convinced my wife that a tower look can look good if done stylishly by showing her this picture (no idea what brand these are)
BUT, now she is convinced we should get a wood finish.
lovinthehd and newbie01 suggested I upgrade to better ascend speakers as I can get the finish for free plus get better speakers. Ive heard some good reviews about the sierras, but I've also read that the CMT-340's work better with movies due to it being more dynamic. Our habits are 75% music 25%
My living room is 17x33ft, where most of the HT will be on one side and the kitchen on the other. For this type of setup, would Sierra-1s perform better than cmt-340 for home theatre? Would it be better to get a custom finish on the cmt-340s?
Edited by aamirnshah - 3/28/13 at 9:28pm
post #11 of 27
Those look like B&W speakers, 800 series I think. If you can afford the Ascend towers, those would be sweet! That's a fairly big room, the 340s may fill the room a bit easier but the Sierra-1s do well in a large room as well, as do they work well for a ht/multichannel setup (my living room is about 4500 cu ft). Mind you I haven't had the pleasure of the 340s, or the towers....yet.
post #12 of 27
I must like dull things because I don't think my 340's are ugly. In fact when I ordered them I was a little concerned after reading comments about the looks, but after I unboxed them I was happy, it's just a black speaker that sounds great. Exactly what I was looking for.
Now if only my fondness of dull and unattractive looks carried over to the dating scene I would probably have better luck!! biggrin.gif
post #13 of 27
Well I just realized ascend is in san clemente which is driving distance from me. So we are lucky enough to be able to look and listen to their speakers.
My wife is now also accepting of buying sierra towers if they look better. Do you guys think its worth the 700 dollar tweeter upgrade on the towers? 2100 + 700 for the upgrade is a pretty penny. Ive heard lots about the CMT-340, but not much about the sierra towers. Are they really worth the extra money? Wont buying a high quality subwoofer negate the need for the towers vs the CMT-340s?
post #14 of 27
There's a discussion thread for the towers here on AVS: http://www.avsforum.com/t/1290568/official-ascend-acoustics-tower-thread
I would imagine some of the people there have probably done that upgrade and can answer your question.
post #15 of 27
http://www.parts-express.com/pe/showdetl.cfm?partnumber=261-626
post #16 of 27
The tweeter upgrade impacts music the most I suspect. Perhaps less noticeable just for TV and/or movies. Also ribbons tend to have poorer vertical dispersion--good if you are just at the seating location, but maybe worse if you want party speakers where people are standing or sitting all over the place.
The tweeter upgrade is definitely a good deal though. I don't know how much Ascend is being charged for the RAAL 70-20 tweeters, but $700 is below cost for per pair if you were to buy it from RAAL directly (with a business license). Just looking around the web, most DIYers are selling used RAAL 70-20s for over $800 a pair.
post #17 of 27
Ascend buys a good quantity of RAALs. They are the number one seller of RAALs in the past year of all speaker manufacturers.
post #18 of 27
They must also save a little because they are no longer using the NrT (a $300 upgrade on the Sierra-1's).
post #19 of 27
Curious why you're leap-frogging the Sierra 1's? With a good sub it seems like they might be a good fit ...
post #20 of 27
The NrT is the stock tweeter on the towers....
post #21 of 27
Yes of course. The point was that they charge $700 for the RAAL upgrade. And that price seems low for the RAAL. But the cost is really $700 + the cost of the NrT because the NrT is no longer included.
post #22 of 27
You are speaking of retail cost, not the cost to the speaker manufacturer when bought in quantity.
post #23 of 27
On Ascend forums Dave F actually said if he was going to sell 70-20XR RAAL tweeters direct to customer, they would cost $585 each or $1170 per pair, but removing the NRT ($300) is offsetting the cost somewhat. However, if this was true, that means Ascend is actually eating $130 for every RAAL system they sell.
I saw a thread about a possible Sierra-1 RAAL coming in at $1798. That would be $950 above the stock Sierra-1 ($848). However, as Dave said himself, the stock tweeter of the Sierra-1 about 1/4 to 1/5 the cost of the NRT tweeters (implying the stock Sierra tweeters are about $67/pr). In this case, they'd be eating $173 for every pair of Sierra-1 RAALs.
This doesn't seem very economical--if the numbers add up, Ascend would be actually losing money on their higher end speakers. Of course, maybe the marginal cost of producing speakers has gone down sufficiently for Ascend that they can eat away at their margins with their top end products. Either that, maybe when Dave said he would sell the RAALs at $585/ea, he wasn't quoting at-cost value but rather a number he would be comfortable selling them for (i.e., already includes an extra $130 on top of vendor price).
Edited by astrallite - 3/31/13 at 1:59am
post #24 of 27
I saw a thread about a possible Sierra-1 RAAL coming in at $1798. That would be $940 above the stock Sierra-1 ($858). However, as Dave said himself, the stock tweeter of the Sierra-1 about 1/4 to 1/5 the cost of the NRT tweeters (implying the stock Sierra tweeters are about $67/pr). In this case, they'd be eating $163 for every pair of Sierra-1 RAALs.
Dave will sell you a pair of Sierra-1's with the RAAL tweeter. It's a custom order.
post #25 of 27
Well, no one pays retail price in a business. After all Dave is in a business not charity. im pretty sure he is getting a great discount on his custom raal, providing that he is offering his product at competetive and reasonable price. You would get 10% off from madisound if you buy over 10 and madisound would still be profiting. Dave gets his direct from manufacture. This thread had no pun intended.
post #26 of 27
The Sierra 1's will also be a consideration. I am still leaning more towards the towers or the CMT-340s as they will probably fill up my living room more; plus I am using these speakers majority for movies & tv.
Either way, when we go to Ascend we will sample all 3 options. Just need to save up enough $$$.
Question: With the SC-1522-k, would I require an amp with these ascend options. It supposedly outputs 130 watts for 9 channels.
post #27 of 27
The Pioneer receivers use discrete Class D amps for each pair of amp channels, so they can produce 100+W/channel into all channels as claimed.
Ascends don't have particularly low sensitivity either, 100W/channel should be plenty.
  Back to Forum: Speakers
