AVS › AVS Forum › Audio › Subwoofers, Bass, and Transducers › Logitech Z-5500 sub with Onkyo TX-NR609 receiver
post #1 of 3
Is there a way to connect the subwoofer of my Logitech Z-5500 to my Onkyo TX-NR609 receiver ?
This sub seems to be designed to use with logitech's amp that comes with the kit...
post #2 of 3
IIRC, the logitech Z5500 only functions with its own control pod which is specifically matched to the subwoofer itself. I don't think it can be done TBH.
post #3 of 3
I believe it's been discussed on AVS before, and IIRC correctly it will work if you connect the AVR's subwoofer output to one of the inputs on the Logitech unit (but I can't recall which one). OP, search this site for more info.
-- Edit --
See post #18 in this thread. (Note: The OP in that thread has an AVR with dual subwoofer outputs, which is why he talks about running two RCA connections from his AVR.)
Edited by eljaycanuck - 3/28/13 at 9:05am
