AVS › AVS Forum › Audio › Receivers, Amps, and Processors › *Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread
*Official* Pioneer SC-1522 9.2 Network ready AV receiver owners thread - Page 55
post #1621 of 1712
Has anyone used the SC-1522 with the 4k pass through to a ultra 4K HD TV?
I own this receiver and was looking to purchase a LG-84LM9600 TV and was hoping the 4-k pass through would work fine.
post #1622 of 1712
Has anyone tried the icontrol app with the new ios7?
post #1623 of 1712
Yes, works just fine.
post #1624 of 1712
Thx
post #1625 of 1712
Just got a 1522 off EBay. Looks perfect, powered up, have it connected to ps3 and my desktop PC and two speakers for now while I try it out.
1 major problem. The remote does not communicate with the receiver. I changed out for fresh batteries, the red light illuminates on the remote when a button is pressed, Ie the remote has power and is working. The receiver simply does not respond to anything I press on the remote. Volume, inputs, anything.
Does the remote have to be paired with the receiver it was made for? Any ideas? Initial reading in instruction manual does not say anything about pairing the remote to the receiver. You can teach it to "learn" other devices, but I'd think it should be working 100% with the receiver it came with.
# on the remote is AXD7668
post #1626 of 1712
You've got to push " RECEIVER" on the remote first to control it. The iControlAV2012 is better.
post #1627 of 1712
AXD7668 is the correct model number for the remote. Check the remote control setup under Home Menu > System Setup > Other Setup > Remote Control Mode Setup.
post #1628 of 1712
Wow, RECIEVER four rows down, four columns over. THAT receiver button, not the one top left on the remote. I don't know who failed harder, Pioneer for making it that way, or me for missing it. Thanks! I am remoting now. Enjoy your Sunday evening.
post #1629 of 1712
Anyone found a "surround" setting that let's you hear the umpires voice at a reasonable volume on a NFL game? Extended stereo is ok but I'm not found of having all the same sound on all 7 speakers.
post #1630 of 1712
Did you try the Sports setting? If I remember correctly from when I tried it, it put the crowd in the surround speakers and the announcers on the front main.
post #1631 of 1712
I just tried the sports setting and didn't really notice any difference. I kept on rewinding a penalty and went through every setting and the only one that made the ref somewhat audible was extended stereo. I feel like there is something wrong with my setup as no one else has complained about it.
post #1632 of 1712
Check the settings on your source. In this case the cable / satellite box. The AVR will play whatever audio format is behind sent to it. If setreo is the only source then that's all it's going to play.
post #1633 of 1712
Good point. And now for a fun fact: How many of you knew there are videos explaining most of the sound explorer settings in iControl2012?
post #1634 of 1712
Hey all. I just experienced a strange problem with my SC-1522k I've been using problem free for several months. I turned on the unit (no error messages or other indicators that something was wrong) and no sound was being emitted from the speakers, but I was getting LFE from my subwoofer. I tried turning the unit off and back on several times, cycling the amp (receiver+speaker option on the remote) and even removed the power for ~1 minute. Nothing seemed to work. I even switched over to the MCACC setup screen and tried to adjust speaker levels where I got nothing from anything but the subwoofer. After about 10 minutes of playing with the unit I switched the amps off then on again using RECEIVER+SPEAKERS on the remote. This time there was a 'pop' emitted from the speakers and sound started to play correctly. I've now been playing music for about 20 minutes with no problem.
Any idea what might be going on? Do you think the amp or caps might be going bad?
post #1635 of 1712
Sounds like amp section is the problem. LFE channels don't go through amp at all.
post #1636 of 1712
For some reason (I don't know why or how), I cannot seem to access or control my iPod Touch at all from the remote or front panel of the receiver. It seemed to work fine a couple of times before this, but now it's unresponsive to any commands. I've tried pressing the "iPod Control" button on the remote, but that doesn't do anything. The receiver seems to connect okay to my iPod Touch and I get the iPod main menu to show up on the TV, I just can't do anything beyond that. Has anyone run across this problem before? I'm afraid to do a system reset, because I don't want to lose all my settings, or will they be unaffected?
post #1637 of 1712
Mine sometimes does this and holding down the power button on the front of the receiver for something like 10 seconds does a soft reset. You don't loose any settings.
post #1638 of 1712
Hey Guys, I purchased the Pioneer 1522-k receiver at Costco last month (last one in the state) for 540 + tax and it was a significant upgrade over my 7+ year Onkyo receiver.
Around 5-6 years ago I purchased 3 Athena WS-60 speakers used as my fronts/center and a pair of Athena WS-15's for the rears. Here is a link to the WS-60's - http://www.woot.com/offers/athena...ker-mar-28. Also here's a link to an Athena AS-P4100 subwoofer I purchased at that time as well - http://www.woot.com/offers/athena...fer-mar-28
I currently live in an apartment-style condo and can't run my speakers on full blast. With that being said, I feel that there is a lot to be desired from the Athena's. I don't hear everything I should (for instance if I put my ear to the speaker I can hear subtle effects that get lost when I move a few feet away from the speaker). I ran MCACC several times and have tweaked my speakers as much as possible. It's still difficult for my ears to hear dialog at times and subtle effects. I spend 60% of my listening for TV/Movies and 40% for games. I'd like to start listening to more music though.
My question is this. I purchased 2 Monitor 70's from Newegg to replace my fronts (plan on bi amping), and will pick up a CS2 for my center. http://www.newegg.com/Product/Product.aspx?Item=82-290-208&SortField=0&SummaryType=0&Pagesize=100&PurchaseMark=&SelectedRating=-1&VideoOnlyMark=False&VendorMark=&IsFeedbackTab=true&Page=2#scrollFullInfo
Since the Athenas are are rated at 8 ohms I am likely going to replace my rear WS-15's with the WS-60's I'm freeing up. I may eventually add the WS-15's back in for a 7.1 setup when I get a new home. I feel that my a subwoofer is currently more than adequate unless someone objects. Taking all of this in account, do you guys feel that this will be a good upgrade? Should the Monitor 70's and CS2 (also open to other center channels) sound a lot better than my Athenas? I know these are still budget speakers, but I want to make sure it's a good upgrade or I can hold off for another deal on others.
Any feedback before these puppies ship would be much appreciated!
Edited by psamona - 10/27/13 at 11:06am
post #1639 of 1712
I've got no experience with Athena' speakers. However, I do own Polk Audio Monitor speakers.
1) Passive bi-amping will not do anything.
2). I wouldn't consider going for the Polk Audio Monitors an upgrade. They are an entry speaker. If you want better detailed sound you have to buy better speakers.
post #1640 of 1712
Thanks I think you're right. I know that the Monitor 70's would definitely be an upgrade, but I may hold off for a deal on some entry level mids instead. For now I can deal with my Athena's, but would like to eventually put my receiver to some real work wink.gif
post #1641 of 1712
I could not find an answer to this in the search. So I'm asking here.
My friend has this unit and bought it 6 months ago, but just finished his theater and is using it now. The unit will power off periodically when around -5 dB driving 9 speakers. I'm trying to find out if it flashes the power button.
It does not appear that any wires are near touching, so it does not appear to be grounding. Everything is in 12 gauge speaker wire.
Overheat?
post #1642 of 1712
Overheat?
I'm thinking more like preventing from blowing up your speakers. Mine did the same, but I am using external amps. It will do it with certain high bass dance / techno music at +7 dB's with +10 dB's gain.
post #1643 of 1712
I just realized too that I've got all of my tower speakers set to large. The 4 surround / surround back are 6 ohm speakers. So, I am going to set the 4 back speaker and center to small. Let the 4 front towers be large and test again.
post #1644 of 1712
Do you have a subwoofer in this system? If so set all speakers to small. This will take a load off your receiver to produce low frequencies.
post #1645 of 1712
Don't have subs. Sold both of them last week. Thus, the reason why I set my towers to large wink.gif
post #1646 of 1712
He says that the problem happens in dance music when it peaks or in an explosion in a movie. I thought he might have an issue with shorting. New wiring, speakers, etc. I told him to check to ensure that at no point (behind the receiver or behind speakers) is there a chance of a vibration making wires touch.
post #1647 of 1712
Most of the time it is a short like you've mentioned. I've checked all of my cables, and I don't haven't found anything lose or touching.
post #1648 of 1712
How good is the video conversion on this receiver? I just got a VT60 Panny plasma and am trying to figure out if I should turn conversion off on the receiver and let the TV do the work or if I should have the 1522 do it...any opinions?
post #1649 of 1712
As an owner of your display and of a different Pioneer receiver with the same chip - turn off any processing in the receiver and let the Panasonic do it. If anyone is buying a receiver for its video chips, that's very debatable on whether it is really worth it. Love the D3 amps though.
post #1650 of 1712
I will say this, I own a Samsung LN46A650 TV - http://www.amazon.com/Samsung-LN46A650-46-Inch-1080p-Touch/dp/B001413D94 and ended up getting the SC-1522-K in September. I run all video through my receiver and have to say that it looks fantastic. I heard similar feedback regarding video quality on this receiver. With that being said, part of this is likely due to having an older TV with a maybe not so good upscaler. I also don't know how much scaling my receiver actually does since I'm running a lot of content from my Xbox/PS3, PC, etc. which in most cases upscaling is handled by those devices respectively.
To be honest, the single biggest thing I did to improve my picture quality was calibrating my set using the AVSForum video calibration discs. If you have not done this already (or something comparable), you're really missing out IMO. I LOVE this receiver!
